How to repair ffc connector on microwave panel
  • Peterpies
    • Sep 2025
    • 6
    • New zealand
    I have a sharp microwave front panel connectors which link to the motherboard via ffc strips into push in connectors, see images, the connector strips are worn I have cut them back but they still don’t make a good connection any ideas how I can overcome this would be appreciated. All switches on panel which are touch type work fine, have thought about conductive pen or paint anyhelp appreciated.
  • CapLeaker
    Leaking Member
    • 8327
    Either hardwire it or conductive paint. I just find the paint makes a mess and don’t really like it. I’d rather find a different way. If you are really careful and got low melt solder and flux you can actually solder a wire to that carbon track on the plastic strip.
    • Peterpies
      • Sep 2025
      • 6
      • New zealand
      Capleaker, thanks very much for that I did think it would be messy haven’t used it myself, perhaps if I use copper strips, very thin, and solder with low temp solder may be an option, thanks I will try that and update you after my efforts
      • CapLeaker
        Leaking Member
        • 8327
        It’s not easy, but I did that before. It is very delicate work,
        • howardc64
          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
          by howardc64
          Failure Symptom
          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
          Where is the short?
          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
          05-27-2025, 02:56 PM
        • mecha1166
          75UK6190 blank screen, shorted caps on panel strips
          by mecha1166
          I have 2: 75UK6190 units. One has a broken panel - it lights up and shows a bit of graphics. The other LG tv lights up but has no video. Turns on/off ok, and I swapped all the boards to check them all. I exposed the strips on the bottom of both panels. I tested the caps along the LED strips on the bottom of the panel. About 12 smd cap chips on the tv with no video, test shorted. I talked to LG tech support but they do not repair to this level, they just replace the panel. Now, there is a Philips mainboard that a smd capacitor chip shorts and causes a squeal from the power supply, and the fix is...
          12-17-2021, 02:00 PM
        • Tomylee
          No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
          by Tomylee
          Sorry for the person who’s going to read all this !
          I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
          While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
          During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
          07-11-2025, 11:52 AM
        • howardc64
          LG 49UJ6500 LCD panel lighter band that goes away
          by howardc64
          49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
          Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
          02-19-2023, 12:13 AM
