Microwave HV transformer
  • davph
    • Apr 2014
    • 23
    Hi
    Can anyone tell me the difference between MD-801FMR-1 / MD-801FTR-1 and MD-801EMR-1 microwave HV transformers?
    All I can see is they are all 800W but wondered if they are inter changeable
  • CapLeaker
    Leaking Member
    • 8285
    Probably region codes. AMR for America, EMR for Europe etc. As long as the primary winding has the same voltage than you have in your country, the mounts fit, wattage is the same and the connectors are the same, you should be all right.
    • R_J
      • 9578
      seems to be a slight difference in where one of the secondary leads comes out? they should be functionally the same
      • CapLeaker
        Leaking Member
        • 8285
        That may explain the last picture, but not the first two.
        • R_J
          • 9578
          • Agent24
            I see dead caps
            • Oct 2007
            • 5008
            • New Zealand
            Looks like the differences mainly lie in the connector arrangement, for different design styles of oven, I would guess.
            Also one (MD-801EMR-1 by process of elimination) seems to have an electrical connection to the core, while the others don't appear to?
            -David VanHorn
            • R_J
              • 9578
              The high voltage winding has one end connected to the core (ground) they all have that., the other end of the high voltage winding is either a wire lead with spade connector or just a spade connector on the transformer. The other leads are for the filament and are only a couple turns around the core to provide around 3 volts
              The FTR and EMR seem to be more similar, maybe lead length is different?
              Is the one you have defective?
              • davph
                • Apr 2014
                • 23
                I think the one I have is defective. HV fuse blows instantly when start button is pressed.
                Door switches, diode and capacitor are ok and have swapped the magnetron as I had a good replacement.
                There is a tap on FMR that the HV fuse connects to. From what I can see the FTR doesn't have this lead connects straight to capacitor.
                I've never had a faulty micro transformer.
                • R_J
                  • 9578
                  You say there is a fuse in the high voltage secondary lead that blows? if this is the case, it is not the transformer and more likely the diode or cap.
                  Usually, the problem is the door switch is bad (stuck closed) and the monitor switch closes blowing the main fuse.
                  I supplied a diagram, your transformer connections to the magnetron, cap, diode should be similar
                  I have had shorted components (cap, diode etc.) on the secondary and they would load the transformer causing it to hum very loud but not blow the fuse instantly.
                  it is rare for the transformer to go bad, and it is usually the high voltage secondary that shorts or arcs.
                  Post the make and model number or maybe a couple pictures
                  • davph
                    • Apr 2014
                    • 23
                    Model is Bosch HMT75M451B/35
                    I re checked switches which are ok and no shorts on cap or diode. Decided to swap capacitor and diode and Its now working!!
                    I only had 0.95uF instead of 1uF
                    • R_J
                      • 9578
                      It is likely the diode that is bad, you can't really check them, they are a stacked diode, the cap value is not critical. Good to hear it is working
                      It is possible the cap is shorting under load, but the diode is more likely.
                        • Jul 2011
                        • 6057
                        The high voltage diode is very hard to test with a multi meter and the capacitor might be damaged so when I see the main fuse blows I change both the diode and capacitor which works most of the time unless you have a bad magnetron that is partially shorted which is causing the fuse to blow
                        • ohren
                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                          by ohren
                          Hello!
                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                          Measured voltages with no load:
                          After rectifier diodes
                          12V: 6.17 V
                          5V: 5.67 V
                          Secondary transformer pins AC measurement (really don't know if this says anything)
                          12V: 2-2.5 V
                          5V: 1.04 V
                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                          03-18-2023, 10:33 AM
                        • mikey5791
                          Is it possible for transformer substitution?
                          by mikey5791
                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                          My questions are
                          1. How do i test to see if the transformer is in good working condition?
                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                          Hope you guys understand what i was asking. My intention is...
                          11-03-2022, 02:11 AM
                        • dennis_elx33
                          3PHASE STEP-DOWN Transformer in Check
                          by dennis_elx33
                          Hello All,
                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                          Problem statement: Power tripped Off
                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                          Action Done:
                          1) Replaced the faulty parts with good spare.
                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                          12-02-2024, 06:52 AM
                          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 04:40 PM
                          ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                          This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 12:00 PM
