"Challenge" Electric Stapler
  • waveydavey
    • Mar 2019
    • 9
    I have an electric stapler that has stopped working. It's a Challenge Xtreme brand (UK cheapie)
    When I pull the trigger it is completely dead. I've traced the 230V which is present on the board so it is not a fuse/wiring issue.
    I know these are often simple devices (basically a solenoid), but this one has some sort of anti-latching circuit, and I'd like to keep it standard instead of modifying/bypassing it completely.
    I think there is a component that switches the solenoid on/off as part of the anti-latching circuit, and may have failed. When desoldered and connected to a transistor tester, it is reporting it as an NPN transistor, but reading a Vbe/hFE of zero
    Click image for larger version  Name:	1731501647272.jpg Views:	0 Size:	1.93 MB ID:	3506686 Click image for larger version  Name:	1731501647260.jpg Views:	0 Size:	623.8 KB ID:	3506687 Click image for larger version  Name:	1731501647249.jpg Views:	0 Size:	2.05 MB ID:	3506688
    My issue is that there is no model number or identifier whatsoever on the component, so I can't just buy a replacement to see if it fixes it.
    The tool is rated at 720 watts on the label, and the voltage across the solenoid will be 230V.
    Does this really look like an NPN transistor? Is it likely that it is switching 700+ watts? Maybe silly questions, but I'm a novice.
    Thanks for any help!
  • CapLeaker
    Leaking Member
    • 8179
    Clean that transistor up with 99% IPA and look at it under the microscope. If that doesn't work try Acetone. The transistor isn't ground off, but there seems to be a coating of something or other on it. That must come off and then hopefully there is a very faint print on it.
    • waveydavey
      • Mar 2019
      • 9
      Thanks for the response.
      I've cleaned it with IPA and put it under the microscope, but it looks completely blank, like it was never laser etched.
      I'll try with some acetone tomorrow, too, and report back.
      • CapLeaker
        Leaking Member
        • 8179
        Maybe look at it when wet?
        • CapLeaker
          Leaking Member
          • 8179
          Can we see the whole board, so we can see the circuit? I think it is something else, not a transistor
          • waveydavey
            • Mar 2019
            • 9
            The black wire at the bottom is live (230V), the blue neutral.
            The component I've removed is marked BT, which I guessed to be "Bipolar Transistor".
            There is a 47ohm resistor at the top of the board which is out of frame.
            Thanks!
              • 31044
              it's probably an SCR or triac - some of those have a "BT" prefixed part number.
              component testers hate triacs - they dont have a high enough voltage to test them.
              remove and test the film capacitors - i think it uses a capacitive dropper circuit - those kill film caps.
              • CapLeaker
                Leaking Member
                • 8179
                It looks to me there is supposed to be an SCR in there, not a transistor. Just like stj already mentioned. Measure it with a regular DMM in diode mode, not with a component tester.
                • harp
                  • Jun 2022
                  • 599
                  • Planet Earth
                  My bet is that is specialized chip ic with integrated triac inside and pwm controller of constant current or so, what is setup via external resistor of 47 ohms... I see simillar chip on some led lights, and messing arround with settup resistor can control power and heat disipation, so, longer life...
                  • redwire
                    • 3910
                    I think it's just a triac, PCB label is "BT" likely a BT136 or BT137.
                    Test it the old fashioned way - use a multimeter on Diode-Test and then on Ohms.
                    Many triacs have a built-in gate resistor so a low ohms reading between Gate-MT1 is normal for high-commutation triacs to get their better dV/dt rating. It's not mentioned in datasheets.
                    Around 150-250Ω or so, some people read 400Ω but these are no-name triacs from the gutters of guangdong. If you read that resistance, the part might be OK.
                    Check C5 is not shorted and 12VDC power is across the zener. I think this is just a one-shot timer for the solenoid, made up of a couple transistors and maybe an IC? There's no snubber for the triac so it does see stress.
                    • harp
                      • Jun 2022
                      • 599
                      • Planet Earth
                      Something like this...
                      • R_J
                        • 9549
                        Is this a J-123? if it is, have you checked the anti firing safety switch?
                        • waveydavey
                          • Mar 2019
                          • 9
                          I've pulled both. One is marked 474J and measures 458nF and the other is marked 103J which measures 10.15nF, which I believe is correct based on the 3 digit capacitor marking?
                          I think you are right, it is a triac! I've never tested these before, so it took a while for me to test it properly..
                          I measured no voltage drop in diode mode on the multimeter between pins 1 and 2 (both polarity), but around 200Ω resistance (as you said) between pin 1 and pin 3 (gate). I used my current limited power supply to load pin1 and pin3 (gate) with around 35mA at low voltage and diode mode on the multimeter then shows a 0.7v voltage drop between pin1/pin2.
                          Both C4/C5 are fine, the three transistors are all NPN BJT and measure fine too
                          I will check the Zener.
                          The label shows J-105, and the PCB is marked DW J-105.
                          The anti firing safety switch on this model is just a mechanical interlock. You can't physically pull the trigger unless you depress the metal guard. With the case open, and the mechanism removed, the anti-firing is bypassed completely.
                          • waveydavey
                            • Mar 2019
                            • 9
                            With the Stapler powered on and at rest, the multimeter shows 5.1VDC with probes at each end of the Zener. I've pulled the Zener and it is correctly recognized as a 12V zener on the multifunction tester..
                            • CapLeaker
                              Leaking Member
                              • 8179
                              I don’t see an electrical reason then why this thing doesn’t fire. Maybe an issue with the trigger or some safety crap?
                              I mean it’s got a few transistors, some diodes, a triac, some caps and that’s about it.
                                • 31044
                                did you meter the solenoid coil?
                                • redwire
                                  • 3910
                                  What are the markings on the TO-92 semi's on the board.
                                  • waveydavey
                                    • Mar 2019
                                    • 9
                                    Great news, it lives!
                                    I decided to call it quits - reassembled it with the intention of throwing it back In the garage.
                                    The last thing I soldered to the board was the solenoid connections. I gave it one last test, and it works flawlessly.
                                    My only conclusion is that the solenoid solder joints (or one of the other components I've removed) were cracked.
                                    The board was originally coated in anti-vibration goo, and when this thing activates, it is pretty violent. I can see why it could crack joints over time.
                                    Things I have learned:
                                    (1) Always start with the basics (The first things checked were voltage presence on the board, the switch, and the solenoid resistance, but I should have checked solder joints under the microscope - the anti-vibration goo was a clue).
                                    (2) That a triac will not often be detected on a cheap multifunction tester, that they often have an internal resistor between MT1 and Gate, and how to test them.
                                    (3) That Badcaps rocks! Thanks for your patience and all of the help, guys!
                                      • 31044
                                      dont forget to remove the safety interlock - that bit is boring
                                      • CapLeaker
                                        Leaking Member
                                        • 8179
                                        Muhaha! Congrats!
                                        • rddube
                                          Help with blowing transistor NAD T752 receiver
                                          by rddube
                                          I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
                                          Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
                                          I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
                                          09-01-2022, 05:19 AM
                                        • amigo744
                                          xbox series x u82 5 pin transistor voltages ?
                                          by amigo744
                                          hello there,
                                          xbox series x hdmi u82 transistor 5 pin,
                                          can anybody tell me voltages of this transistor in standby and power on mode ???
                                          on which pin of this transistor are the voltages ?
                                          regards
                                          08-16-2023, 08:05 AM
                                        • dicky96
                                          B1186A Digital Transistor?
                                          by dicky96
                                          Hi guys
                                          I have this power transistor, it's taken from a Class G Power Amplifier. I already found two short circuit diodes on the Faulty Channel, but I decided to remove the other transistors and test them.
                                          They all test OK but this one is marked B1186A and on my Peak DCA55 it analyzes as a PNP Digital Transistor (which I believe is a transistor with integral base resistor) but if it is a 2SB1186A then it should detect as a regular PNP Transistor.
                                          Having said that I put it in my LCR-4T semiconductor analyzer and that just says it is a PNP Transistor.
                                          06-21-2021, 04:38 AM
                                        • Nilssen
                                          Need help identifying a SOT23 NPN transistor, labeled 6CE
                                          by Nilssen
                                          As topic sais, i need help identifying a SOT23 NPN transistor.
                                          Marking on the transistor is labeled 6CE, will try uploding a picture.
                                          10-12-2023, 12:53 PM
                                        • dicky96
                                          R9 390 8Gb - Broken Transistor and missing components?
                                          by dicky96
                                          Hi guys
                                          I have a R9 390 here. The owner sent it to me with a smd 1AM transistor (one leg broken off) taped to the heatsink
                                          He says he bought this used as 'working' on ebay, put it on one side for about a year (never tested it) and when he came to use it, it does not work
                                          He then spotted the broken transistor in the bottom of the box
                                          At this time it was much too late to return it
                                          He sent me some pics where he says the transistor comes from (not sure how he knows for sure).
                                          Under the microscope it does look like some transistor...
                                          08-14-2021, 03:40 AM
