Tefal Pro Express GV8975
  • jimmy2022
    • Feb 2021
    • 42
    • united kingdom
    we have been trying to get this iron to work, but the problem is that the relay clicks and then the no water sign flashes.
    the micro controller is pic16f1933.
    all other parts like water pump , boiler, solenoid ect are working.
    • 31063
    be logical - how does it detect water?
    • jimmy2022
      • Feb 2021
      • 42
      • united kingdom
      it seems that the 6th pin on the pic chip had 36 ohm resistance to ground, after replacing the chip, the iron started to function again. how did this happen?
      • jimmy2022
        • Feb 2021
        • 42
        • united kingdom
        hello
        there is a similar problem with the same model. is there a way to trick the pic chip into thinking there is water in the iron? since i dont have programming software, what other solution is there?
        • jimmy2022
          • Feb 2021
          • 42
          • united kingdom
          this steam generator doesn't have a water sensor.
          boiler gets hot
          water pump activates
          then it switches on a relay which causes the "no water" led to flash even when there is water . i am assuming it is a programming issue.
          • CapLeaker
            Leaking Member
            • 8193
            You replaced the PIC chip? Did you program / flash it too?
            • jimmy2022
              • Feb 2021
              • 42
              • united kingdom
              tefal doesnt want to share the firmware it used to programme this chip .
              • jimmy2022
                • Feb 2021
                • 42
                • united kingdom
                I bought a used board of ebay and replaced the pic chip. same problem
                • CapLeaker
                  Leaking Member
                  • 8193
                  If you bought a whole board, why didn’t you replace the whole board rather than the chip? I suppose you wanted to know if the chip is the problem?
                  • jimmy2022
                    • Feb 2021
                    • 42
                    • united kingdom
                    because the lady wanted 16 quid with the wires and 9 quid without,
                    • CapLeaker
                      Leaking Member
                      • 8193
                      7 bucks extra for wires? WTF is wrong with people?!
                      • jimmy2022
                        • Feb 2021
                        • 42
                        • united kingdom
                        managed to trick the pic chip and confirmed that the board is working. the problem is either the ntc in the hand set or the boiler.this means i wasted 9 quid for no reason, there was no problem with the original pic chip.
                        • CapLeaker
                          Leaking Member
                          • 8193
                          Does the boiler heat up?
                          • jimmy2022
                            • Feb 2021
                            • 42
                            • united kingdom
                            everything works. 5 volt for one of the ntc's was missing.
                            • CapLeaker
                              Leaking Member
                              • 8193
                              Ahh! Good find!
                                20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                by sam_sam_sam
                                I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                04-09-2023, 08:04 PM
                                HP ProBook x360 440 G1 + Tefal Daily Cook Saucepan Set Hybrid (2-in-1) Specification for Upgrade or Repair
                                This specification for the HP ProBook x360 440 G1 + Tefal Daily Cook Saucepan Set Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 440 G1 + Tefal Daily Cook Saucepan Set boardview and 440 G1 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                09-06-2024, 09:00 AM
                              • beetle1303
                                Tefal GV8962 Pro Express steam iron - no power
                                by beetle1303
                                I am trying to save a donor steam iron with no power supply.
                                Dismantled and initial visual check on the power supply PCB - there is no fuse anywhere, and resistor is quite obviously burnt. Can't really read to color code, guessing it could be 100ohm (brown, black, brown, gold) or 180ohm (brown, grey, brown, gold).
                                Replaced the burnt resistor with a trial 5W 100ohm resistor for quick test, power on, and it immediately blown a 100nF 50V capacitor nearby.
                                Suspect a short circuit somewhere, I try to checked a few more obvious components before seeking...
                                10-22-2020, 04:34 AM
                              • liquidzorch
                                862D+ solder station iron out of control when fan on
                                by liquidzorch
                                Hello.
                                I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
                                First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
                                06-09-2022, 08:49 PM
                                HP Elite Slice G2 + Tefal Daily Cook Saucepan Set Elite Slice i5-7500T Specification for Upgrade or Repair
                                This specification for the HP Elite Slice G2 + Tefal Daily Cook Saucepan Set can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Tefal Daily Cook Saucepan Set boardview and Elite Slice G2 + Tefal Daily Cook Saucepan Set schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                09-12-2024, 02:20 PM
