Samsung WD80N645OOW died mid-cycle
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 7988
    That t4 diode is probably in parallel with the relay coil and is similar to a 1n4148 small signal diode. It is there as a high voltage protection for the coil drive when the relay is triggered. It should show up almost as a short, since you measure through the coil of the relay.
    edit: so if you measure across the coil and it is open with the diode, that the relay is fuxed.
    The voltage at the rectifier is not normal. So you probably have a weird AC voltage on the bridge rectifier input, or the bridge rectifier is bad.
    • mrsith
      • Mar 2021
      • 146
      • Wielka Brytania
      #42
      There's 152 ohms there on the coil, same in the spot where diode was. There is a slight chance that I damaged it when pushing probes through the resin though. Ordered a replacement.
      Gonna try measuring ac input on the rectifier again, it's difficult to stick probes there.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 7988
        I guess we have to wait for parts now? Or can you continue with the old relay?
        what is the diode saying now out of circuit?
        • mrsith
          • Mar 2021
          • 146
          • Wielka Brytania
          #44
          I'll continue with that relay, like I said I got excited too quickly and thought it's a different pin that conducts the N line. Relay seems good.
          I've been measuring that diode out of circuit. Seen 152ohms both ways in circuit, so I was scraping the silicone around the relay off to have a better view on that diode, and it fell out with the silicone. Soldering pads healthy at least.
          One of the rectifier's legs connects straight to the N ac line, trying to figure out which way the positive line goes there. Doesn't seem to conduct against L ac input. There's a NTC resistor measuring 25ohm, I can see trace from it coming under the main relay, there's a trace coming on another side that connects to the main fuse, but there's no continuity there.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 7988
            Hopefully you can figure out which way the diode was. If the old diode is bad, just put something like a 1n4148 in there. If you don’t it will damage the coil driver.
            • mrsith
              • Mar 2021
              • 146
              • Wielka Brytania
              #46
              It's marked on pcb thankfully.
              Would I get any dc reading at all if only one ac terminal was connected to a rectifier? Maybe I actually shoved my probes right there, just only one pin was getting ac power so the reading was 0? That'd explain no continuity between rectifier and ac L input, and pretty much everything else that's happening with the board.
              ​​​​​​I'm afraid I'll have to take the relay out anyway, just to see the traces underneath.
                • Jul 2011
                • 6024
                Sometimes you might not get a resistance on some relay coil if it has more than one of the same type of relay check the coil on each one to make sure that it is really open
                One note if this is a double sided board make sure that you heat the soldering joint completely but not too the point that you burn the board or you make the trace from pealing off the board
                • mrsith
                  • Mar 2021
                  • 146
                  • Wielka Brytania
                  #48
                  That could be it, maybe I have burnt the trace coming from fuse to the smaller rectifier. I'll take out the fuse tomorrow and check the traces around it. I was quite gentle with soldering iron, but heated the solder quite long to make sure it flows where it needs to. Maybe that was too long.
                  There are similar relays on the board, coil resistance looks similar. That main relay only activates when the power button is touched, so I guess even if something was wrong there, I should still be getting 5v and 12v to power to control panel.
                  • petehall347
                    • Jan 2015
                    • 4423
                    #49
                    Originally posted by mrsith
                    Edit: also found a tiny T4 marked diode, just next to the relay (looks like it's connected to the relays coil), which is open, doesn't conduct anything any way.
                    flyback diode . relay will switch on without it .but if its open the relay drive circuit might be damaged .
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 7988
                      just place a jumper wire for now.
                      • mrsith
                        • Mar 2021
                        • 146
                        • Wielka Brytania
                        #51
                        Trace was bad. Looked alright to eye, but didn't conduct fromain fuse to that NTC resistor. Had to take the relay out to make sure it's actually the same trace lol. Made a jumper, found a similar diode on one of scrap TV mainboards I had in cupboard (was a bit bigger, marked T4 P with P being rotated), put it together and the machine turns on again. Need to assemble. It back, connect water and drain and see if it manages to finish a program.
                        • mrsith
                          • Mar 2021
                          • 146
                          • Wielka Brytania
                          #52
                          Quick wash finished with no issues. Thanks so much everyone for help, I learned a lot during the whole process!
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 7988
                            Hope it stays working now.
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • m1ch43lzm
                              by m1ch43lzm
                              05-12-2025, 08:37 PM
                            • ohren
                              Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                              by ohren
                              I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                              I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                              The models launched in 2018 and 2019 respectively....
                              09-08-2023, 05:24 PM
                            • C152Heavy
                              Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                              by C152Heavy
                              Summary for TL-DR readers:
                              • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                              • Have obtained Samsung schematic & service documents - Can upload if helpful.
                              • Have read ALL applicable threads
                              • C1818 and CP820 replaced as low hanging fruit
                              • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                              • VCC pin (18) of PFC...
                              01-11-2023, 02:53 PM
                              09-07-2024, 05:50 AM
