Frigidaire Refrigerator Model FFHS2612LS0 Water Inlet Valve Diode Kit cost around $40 and is just two wires, each leading into a $0.25 diode which then exit into one wire. Does anyone know the type diodes used for controlling this water solenoid bank of three?
Frigidaire Refrigerator Model FFHS2612LS0 diodes
Tags: None
Re: Frigidaire Refrigerator Model FFHS2612LS0 diodes
I looked at Frigidaire Refrigerator Diode Repair Kit 5303918287, 789911908505.
It's got three wires, two diodes inside. Seems to be an OR-gate such that the inlet-water main solenoid turns on if either the water dispenser is pressed OR the ice maker turns it on.
Just use a plain vanilla 1N5408 diode 3A 1,000V rated. A smaller 1N4007 1A 1,000V might work fine as well but solenoids have inrush current and not sure if it's over the 30A surge rating. It is likely the solenoid spike voltage is what is killing the original diodes or Whirlpool cheaped out.
Ultimate BY448 2A 1,500V $0.67 ea. at Digi-Key or Mouser.
I found this schematic but will check the diode's polarity...
edit: seems to jive with other wiring diagrams. To test, multimeter on diode-test and (+) to common lone tan wire, (-) to each single wire for each diode.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thank you Redwire for your fine info. I am so glad you gave me just what I needed. I printed it out and will get the parts today. I been under that frig so many times. I am too darn old for this.
So am I
I would consider putting a fuse on each input to the diodes just for good measure
The reason I am recommending this is because of the fact that you have already had this failure already because on rare occasions these solenoid value coils short out and make a mess of things if the coil or coils look very discolored or warped change the coilsLast edited by sam_sam_sam; 01-25-2022, 06:45 PM.Comment
People complain the diodes either go open-circuit or short or one guy had smoke but that seems strange.
Shorted diode: pressing the water dispenser, and water comes out of both the dispenser and ice maker tube.
Open (dispenser) diode: no water dispensed
Open (ice maker) diode: ice maker won't fill (it typ. runs for 8 seconds).
The water solenoids are driven by 120VAC mains, their common leg goes to Neutral. But the single inlet solenoid gets the 1/2-wave DC from this diode module. I don't know what controls them on the board(s), it looks like relays but Service bulletin advice is a little strange:
Water dispenser - yellow (dispenser) coil should have mains 120VAC, and the inlet solenoid (single valve) will have 54-78VAC.
Ice Maker - green (ice maker) coil should have mains 95-105VAC, and the inlet solenoid (single valve) will have 42-58VAC.
The voltage measurements are a big wonky? Fridge runs off 120VAC and ice maker gives 95-105VAC? It must have little triacs or something?
You'd think by now Whirlpool would know how to reliably turn on a solenoid lol. Putting diodes in a wiring harness is expensive and this affair goes for $40!
I think the back-EMF from the solenoid is damaging the diodes because they see two solenoid's worth of spike, there is one on each side. I've also seen a water solenoid kick back even more due to the water pressure kick on the pintle so they act like a generator and make an extra big pulse with the residual magnetism.
As far as current drain, the one should only draw under a hundred mA plus inrush. The original diodes must be cheap or only 400V or something.
For an appliance maker to add a snubber or MOV to stop surges, it's $0.25 and would break the piggy bank.Comment
Well... these days the fuxers are even cheaping out on a 25 cent part. The unit just needs to survive the warranty period, end of story. They surely do not want it to last for 25 years. Other than that, they wouldn't make any money.Comment
For not even $0.50 worth of diodes, this part retails at $40 and it's typically $250-350 for the callout. Whirlpool could do much better, it's not that hard.
Are they just making money selling diode harnesses?
I wonder if it's the same as the McDonald's McFlurry machines, the manufacturer Taylor Commercial Foodservice likes them being unreliable to keep their repair network making cash. Proven by Kytch Inc. who installed Raspberry Pi's for IoT and found a secret repair menu and firmware bugs in the cleaning cycle. The franchisees are tired of paying for repairs and losing money with the machines being down all the time. You can't make this stuff up.
Why the McFlurry Machine Company Just Got Hit With a Restraining Order and lawsuit storyComment
"the (Kytch) devices breach a Taylor machine, “creates a potential very serious safety risk for the crew or technician attempting to clean or repair the machine," and that it could cause “serious human injury.”
Death by ice cream machine
Really strange to see how politics and corruption prevent an appliance from working decently, and it's all lawyers and courts that befuddle it.
https://www.wired.com/story/they-hac...arted-cold-war
https://www.wired.com/story/mcdonald...nternal-emails
For OP, have to see the original diode p/n to ascertain whether Whirlpool/Frigidaire/Electrolux is using weak parts on purpose. It looks like they slapped on an ice maker and water dispenser as an afterthought then did a bodge or kludge to wire it all up and ooops need diodes and ooops use the cheapest ones possible.Comment
The hole thing about only the manufacturer can repair your device is totally unacceptable crap I sorry but if I can avoid this kind-of crap I will
Unfortunately they are not the only refrigerator manufacturer who has done this crap as well meaning that they screw up the design and then have a fix for it but you can only get it from the manufacturer really
I once fix a refrigerator for some one ( this also had a switching power supply controller board failure that stemmed from an thunderstorm that the switching power supply regulator and bad capacitors) that the indoor water dispenser keep freezing up and would not dispense water anymore the manufacturer solution was to add a heater to the back of the door panel where the water dispenser was in the freezer door what a pain in the a** this was to do and what made it even worse was that the only recall service notice was on the manufacturer website site which you really had to dig through there website to find a solution for this issue really
This issue that McDonald’s with the ice cream machine BS I would have sued the manufacturer for this kind-a-of crap because this kind of crap needs to be STOPPED before this becomes common placeLast edited by sam_sam_sam; 01-29-2022, 06:30 AM.Comment
Oyyy... that gets me going all right... I am just wondering which manufacturer and when they come out with a subscription based whatever appliance. Like the new Toyota's remote start only works with a subscription.
Now chances aren't looking bad for some idiot at some manufacturer to come up with the idea, that if you buy a fridge you need to subscribe to get ice or water out of the dispenser!?
So really... the manufacturer wants me to buy their crap (most of the stuff you buy these days don't hold up for long anyway) and have to buy a monthly sub to get basic features... Hell no!Comment
To be clear, Whirlpool mega-corp has not locked people out of repairs, they are good in that you can get parts and wiring diagrams for them.
Taylor Food equipment is one keeping their monopoly on repairs, probably even giving kickbacks/racketeering to McDonald's execs, because the franchisees pay the repair bills and not them.
Biden's "Right-to-Repair" exec order from last summer, is hopefully at least going to rattle this monopoly on repairs crap.
Washing machines, dishwashers, refridgerators etc. are more and more computer-controlled and I think there is a need for some diagnostic standard like cars have OBD2. Add a serial port so we can see what is going on in the appliance.
Otherwise, it's an expensive board swap or guessing what sensor is cutting out. Would you pay monthly for this and the software?
John Deere has pissed off farmers doing this for their tractors and only getting repairs only done by Deere-authorized technicians. So much for changing the oil at home. These CEO's need to go.Comment
Silicon Valley is all about the "subscription" monthly fees model. It's ridiculous.
Tesla upped their Full Self-Driving option, was $6,000 to $10,000 now $12,000 or $199/month. As if we're all made of infinite cash like Elon. Hopefully it won't run over a bunch of kids or crash or something.
For a refrigerator, extended warranty seems to be ~10-30% of the purchase price and these third-party warranty companies generally have fine print or go out of business, and you get burned.Comment
kids are safe, tesla's like to target police!
i think either the white/black paintjob or the flashing lights confuses the image processing software.
either way - tesla autodrive does target active police cars!!!!
I am not complaining about this fridge, after all it was purchased in 2005 and its not a daily problem. It just seems odd that at any moment, it can start peeing out the water dispenser and flooding the freezer with ice maker continuous over fill in the middle of the night because these diodes decide to give up the ghost.Comment
That means it's likely the diodes are getting blown due to power surges.
Mains transients from lightning etc. (Texas!) or locally generated i.e. by the fridge itself.
Everytime the compressor stops there is a voltage spike and it could be taking out the ice dispenser/water dispenser diodes.
I can't see Whirlpool spending $0.25 on a MOV to protect things and they end up a liability because they can burn up if hit with a really big power surge.
If other electrical things at home are getting damaged, then I would look at some surge protection.Last edited by redwire; 02-13-2022, 02:13 PM.Comment
Maybe these would work: https://m.aliexpress.com/item/329455...1f925c5&gclid=Comment
by DvsrHi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
After replacing the caps I started testing out the speaker. It seemed...4 Photos-
Channel: Troubleshooting Audio Equipment
09-10-2025, 10:20 AM -
by DennisHThis diode is mounted on a Frigidaire electronic oven control PN:316131600. This diode runs hot enough that the PCB is showing slight burn marks (black soot looking area on PCB above the diode). It looks to me to be coming from the body of the diode.
The oven control is 22 years old and still works, but I can't get a new replacement, so I'm doing preventative maintenance and replacing a few parts on it that I think could fail - and this is one of them.
Can any of you identify this diode (see pic) and suggest a replacement that can handle more heat - or if not, can... -
by caspianDear members,
I have a linear variable power supply with unknown brand name that I used for voltage injection.
Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
In addition, I discovered that its zener diodes are defective.
I can replace the burned transistors.
But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
Therefore, I cannot replace the zener diodes.
I do not want to test the zener diodes in a test circuit to discover their model or value.
no schematics are available... -
by asrHello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks.... -
by unimatrix93Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
The led strips has 9 6V leds.
1 Photo - Loading...
- No more items.
