12v 1uo941243c Relay repairable?
  • petehall347
    • Jan 2015
    • 4427
    #61
    Re: 12v 1uo941243c Relay repairable?
    P0725 rpm sensor also known as crank sensor . this will prevent engine starting .
    don't worry about transmission codes yet
    • bohaboha
      • Nov 2012
      • 1009
      • sweden
      #62
      thank you i´ll start with that one
      • bohaboha
        • Nov 2012
        • 1009
        • sweden
        #63
        Hello again I have not made any progress because there is a fuse that destroys all the time it is no: 29 on the fuse plate and I do not know to which relay it belongs the schematic on post 47 that you posted differs a little from my plate. can you
        or do you have the schematic of the fuse plate?
        • redwire
          • Dec 2010
          • 3910
          I think this car is totalled?
          • bohaboha
            • Nov 2012
            • 1009
            • sweden
            #65
            lol no not at all just a little patience and you get out of the misery thanks to petehall347 help
              • Jul 2011
              • 6040
              On some cars there is camshaft sensor and a crankshaft sensor and they give you the same exact error code for both at least this is the case with the car that I have so do not over look this when I get this code I change both of them
              One note some times it can be the wiring harness plug that can give you a bad headache if it has a bad connection in the plug as well and it can be hard to detect and determine if this is your issue or not
              On note about a fuse that blows as soon as you apply power to it you need to find out what is causing this issue use the incandescent light bulb ( or a test light ) instead of the fuse to see if it is a direct short or not you will need a wiring diagram for this car to be able to know all of what is on this circuit
              I have a pickup truck that has an issue when you leave the truck sitting for a couple of weeks and go to start it the battery is completely dead no power what so ever I going to have to figure out what the issue is but two things come to mind first one is the radio and the second one is the alternator bad diodes in it and Ford alternator are the worst for this issue I have had this issue several times in the past
              A few years ago I had issues with the charging system on this truck and it was one of the pins in the wiring harness to the alternator that was near the battery that was the issue that time I had to bypass this pin connection in the wiring harness and put a inline fuse on it
              But this is where a wiring diagram comes in very handy to help you figure out what could be the problem in a given circuit you can troubleshoot it with out a wiring diagram but it takes a lot longer to do
              Here is a case in point I once worked on a car that all of the dashboard lights were on the charging system was not working at all and it turns out to be a wire that goes from the alternator to the dashboard underneath the radiator and had burned it self apart due to a short circuit on the heater for the choke on the carburetor but I was lucky enough that it had a wiring diagram that was available on line helped a lot for this issue
              I hope this helps you with your problems with your car
              • diif
                • Feb 2014
                • 6978
                • England
                #67
                Your blown fuse and 3 error codes point to the ECU or it's wiring.
                • bohaboha
                  • Nov 2012
                  • 1009
                  • sweden
                  #68
                  On note about a fuse that blows as soon as you apply power to it you need to find out what is causing this issue use the incandescent light bulb instead of the fuse to see if it is a direct short or not you will need a wiring diagram for this car to be able to know all of what is on this circuit
                  A few years ago I had issues with the charging system on this truck and it was one of the pins in the wiring harness to the alternator that was the issue that time
                  that's right camshaft sensor and a crankshaft sensor could be the cause but as you say i need to have wiring diagrams for this car petehall347 has helped me with that hope he continues with it because now i'm stuck with a fuse that blows all the time
                    • 31070
                    check inside the ecu
                    just in case a cap has leaked - very common in Honda OBD1 era stuff
                      • Jul 2011
                      • 6040
                      Here is how I troubleshoot a short circuit with out a wiring diagram but this takes a long time to do
                      You have to gain access to the back of the fuse box and trace down the circuit that has the issue and start taking of the tape off until you get the first connection point and keep going down the wire path until you find out where or what is causing the short
                      One option you have to getting a wiring diagram for the car in question is go to the dealership and ask them if they will print out the section that you need I have done this myself in the past and have gotten good results from doing this now you might have to pay a fee for them to do this for you
                      What amperage is the fuse in question
                      STJ point is also something to look at as well
                      “ check inside the ecu
                      just in case a cap has leaked - very common in Honda OBD1 era stuff ”
                      • petehall347
                        • Jan 2015
                        • 4427
                        #71
                        which fuse is blowing ? what did you do just as the fuse blew ?
                        • petehall347
                          • Jan 2015
                          • 4427
                          #72
                          there is a workshop service manual for the electrics online .. you will maybe need to make your own breakout box .
                          what i do is find the resistance figures for the sensor and remove and inspect the suspect sensor for damage and check resistance .
                          • bohaboha
                            • Nov 2012
                            • 1009
                            • sweden
                            #73
                            • bohaboha
                              • Nov 2012
                              • 1009
                              • sweden
                              #74
                              do you have any specific link to this workshop service manual? i searched for autodata but they are very expensive even though they have one..very cheap first month. what do you mean by making your own breakout box. the fuse that is no:29 on the fuse box has has to do with petrol engine, engine electronic and ignition according to the manual
                              • petehall347
                                • Jan 2015
                                • 4427
                                #75
                                f29 powers A52 Ignition amplifier. unplug it to test if short gone .
                                its right there on the diagram ,
                                that manual is on google ..its a skoda factory one
                                https://letmegooglethat.com/?q=skoda...cal+pdf+manual
                                • bohaboha
                                  • Nov 2012
                                  • 1009
                                  • sweden
                                  #76
                                  Hi I find no F29 or A52 on the Diagram but you said "f29 powers A52 Ignition amplifier. Pull out the plug to test if there is a short circuit.
                                  It is right there on the diagram, can you point to what you are saying please
                                  • petehall347
                                    • Jan 2015
                                    • 4427
                                    #77
                                    everything is marked on the wiring diagram . there is also a list of everything you can search the pdf .
                                    • bohaboha
                                      • Nov 2012
                                      • 1009
                                      • sweden
                                      #78
                                      Thanks these were not with the others in your last post.I'm trying to put them together so I can understand what it looks like.
                                      Sorry now i see they are here
                                      • bohaboha
                                        • Nov 2012
                                        • 1009
                                        • sweden
                                        #79
                                        Hi again I was wondering if you or maybe someone else here in the forum who knows how to test a 6pins,7pins,9pins and even twin relay. Have searched everywhere only find how does an 8 pins different relay work or maybe refer to something that can help. some pictures to understand
                                        • redwire
                                          • Dec 2010
                                          • 3910
                                          First you would troubleshoot and fix the blowing fuses problem, why are you now suspecting the relays? Look for the short circuits instead of wasting time here.
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                          • valvashon
                                            Repair Success! Middle Atlantic UPS2200R-IP
                                            by valvashon
                                            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                            02-06-2024, 12:54 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • Crystaleyes
                                            LCD TV Power Supply Board question
                                            by Crystaleyes
                                            First off,
                                            Happy New Year everyone!
                                            Someone recently asked me to look at their Philips 42pfl4508g/78 TV which had stopped working.
                                            A quick visual check of the PSU revealed a ceramic cap with a hole burnt through it, and that the output voltages were wonky. The 5.2v Standby was only 3.2v. The 24v - 19.1v and the 12v - 11.2v. We found a cheap 'guaranteed working' replacement PSU online, which they bought and installed but it still the TV didn't switch on, and when I went back to test the new PSU board, it showed the same kind of low output voltages....
                                            01-01-2025, 09:40 AM
                                          • Nikolai Danylchyk
                                            Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                                            by Nikolai Danylchyk
                                            Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                                            Thanks in advance!...
                                            05-08-2025, 06:18 AM
