Wind generator charger schematics (or load of baloney ?)
  • madan1
    • Nov 2016
    • 659
    • Bulgaria
    Re: Wind generator charger schematics (or load of baloney ?)
    Hot water has already been invented. You will find what you need in... motorcycles. Basically all pre-2000 (I'm not sure about the newer ones) have a magneto with 2 or 3 coils. I guess you can get the rectifiers from a motorcycle scrapyard or pick one of the many schematics available in google ( https://www.google.com/search?q=moto...=lnms&tbm=isch )
    • petehall347
      • Jan 2015
      • 4422
      • United Kingdom
      motorbikes are 3 phase .
      • madan1
        • Nov 2016
        • 659
        • Bulgaria
        Yes, I also have seen bikes with only 3 phases/coils (japan made), but apparently there are some with 2 and single phase ... like scooters, old ussr ones, etc.
        p.s. my bad - now checked again the schematics, what I though that was a diagram of a 2phase rectifier was a single phase. So I guess even the ruskies did not make such a unicorn.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          Great...the notification emails about this post suddenly ended up in my spam folder for whatever reason, so I had no idea people replied FAIL
          True, I haven't seen a single one of this guy's inventions so far, so I too have no idea what's supposed to happen there....and I'm not curious to find out anyway, since that's NOT what I'd use for this project to begin with as far as the electronics are concerned.
          I also agree with not wanting to reinvent the wheel here. As much as I like the idea of DIY turbines as a hobby and for a bit of fun and experimenting in the name of science, I'm not ready to put in a lot of time and effort into something that's already been invented AND is much better off the shelf than I'd ever be able to make it. The idea of a bridge rectifier on the output still seems to go right past this guy
          I also had a brain-fart: last summer, I upgraded the motor on my E-bike to a bigger one and I remember such motors are BLDC motors, which conveniently have 3 wires for power. Although I no longer have the old motor to experiment with, because I sold it, it got me thinking whether such an E-bike motor would function as a generator.
          Wattevah...
            • Jul 2011
            • 6018
            It might if it has a permanent magnet in the motor
            • petehall347
              • Jan 2015
              • 4422
              • United Kingdom
              #26
              shouldn't matter if the field coils can be excited .
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                #27
                I doubt it's got field coils. It's most likely a BLDC with the magnets stuck to the outer casing that spins around the stator coils. It's backed up by the fact that it's got 3 main wires coming out of it and although it has another connector with a bunch of smaller pins as well, that's most likely for some sort of speed/position sensors, as the wires are way to fine a gauge to be anything else, like power. Field coils would probably waste power to begin with, which isn't something we want. I was thinking about a car alternator, but it's the same problem: no permanent magnets, unless I modify it...
                Right now, I'm still waiting for the guy to tell me what happens to the joule thief circuit once he tries it out
                Wattevah...
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  #28
                  Here's how I'd imagine a small-ish DIY charge controller for home use. The components can be up-scaled as needed for bigger stuff, of course. That battery switch is a little tricky, as it has to open when the turbine turns (charge mode) and close when the wind stops (battery mode). I see an op-amp in there somewhere maybe...
                  Victron already has this stuff pre-made from what I gather.
                  Wattevah...
                  • motormayhem
                    Lenovo T460 Only Charges on One Charger
                    by motormayhem
                    Laptop Question
                    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                    05-12-2023, 01:46 PM
                  • Johndill
                    Dell Inspiron 7567 LA-D993P odd charger issue
                    by Johndill
                    Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                    There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                    I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                    Here are the tested scenarios:
                    1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                    2. With the laptop off, plug in charger (LED says on) & the front charging...
                    11-16-2022, 10:55 PM
                  • AJ847.63e
                    Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                    by AJ847.63e
                    Hi Folks,
                    Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                    I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                    The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                    05-06-2025, 10:37 PM
                    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:20 PM
                    HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                    09-06-2024, 10:56 AM
