Wind generator charger schematics (or load of baloney ?)
  • madan1
    • Nov 2016
    • 698
    • Bulgaria
    Re: Wind generator charger schematics (or load of baloney ?)
    Hot water has already been invented. You will find what you need in... motorcycles. Basically all pre-2000 (I'm not sure about the newer ones) have a magneto with 2 or 3 coils. I guess you can get the rectifiers from a motorcycle scrapyard or pick one of the many schematics available in google ( https://www.google.com/search?q=moto...=lnms&tbm=isch )
    • petehall347
      • Jan 2015
      • 4434
      • United Kingdom
      motorbikes are 3 phase .
      • madan1
        • Nov 2016
        • 698
        • Bulgaria
        Yes, I also have seen bikes with only 3 phases/coils (japan made), but apparently there are some with 2 and single phase ... like scooters, old ussr ones, etc.
        p.s. my bad - now checked again the schematics, what I though that was a diagram of a 2phase rectifier was a single phase. So I guess even the ruskies did not make such a unicorn.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          Great...the notification emails about this post suddenly ended up in my spam folder for whatever reason, so I had no idea people replied FAIL
          True, I haven't seen a single one of this guy's inventions so far, so I too have no idea what's supposed to happen there....and I'm not curious to find out anyway, since that's NOT what I'd use for this project to begin with as far as the electronics are concerned.
          I also agree with not wanting to reinvent the wheel here. As much as I like the idea of DIY turbines as a hobby and for a bit of fun and experimenting in the name of science, I'm not ready to put in a lot of time and effort into something that's already been invented AND is much better off the shelf than I'd ever be able to make it. The idea of a bridge rectifier on the output still seems to go right past this guy
          I also had a brain-fart: last summer, I upgraded the motor on my E-bike to a bigger one and I remember such motors are BLDC motors, which conveniently have 3 wires for power. Although I no longer have the old motor to experiment with, because I sold it, it got me thinking whether such an E-bike motor would function as a generator.
          Wattevah...
            • Jul 2011
            • 6059
            It might if it has a permanent magnet in the motor
            • petehall347
              • Jan 2015
              • 4434
              • United Kingdom
              #26
              shouldn't matter if the field coils can be excited .
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                #27
                I doubt it's got field coils. It's most likely a BLDC with the magnets stuck to the outer casing that spins around the stator coils. It's backed up by the fact that it's got 3 main wires coming out of it and although it has another connector with a bunch of smaller pins as well, that's most likely for some sort of speed/position sensors, as the wires are way to fine a gauge to be anything else, like power. Field coils would probably waste power to begin with, which isn't something we want. I was thinking about a car alternator, but it's the same problem: no permanent magnets, unless I modify it...
                Right now, I'm still waiting for the guy to tell me what happens to the joule thief circuit once he tries it out
                Wattevah...
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  #28
                  Here's how I'd imagine a small-ish DIY charge controller for home use. The components can be up-scaled as needed for bigger stuff, of course. That battery switch is a little tricky, as it has to open when the turbine turns (charge mode) and close when the wind stops (battery mode). I see an op-amp in there somewhere maybe...
                  Victron already has this stuff pre-made from what I gather.
                  Wattevah...
                  • motormayhem
                    Lenovo T460 Only Charges on One Charger
                    by motormayhem
                    Laptop Question
                    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                    05-12-2023, 01:46 PM
                  • flat-earther
                    how to prevent a connected charger from draining battery when not charging?
                    by flat-earther
                    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                    So the battery is backfeeding the charger and being drained.
                    How can I prevent...
                    08-07-2025, 01:04 PM
                  • flat-earther
                    ASUS X54H laptop thinks it's always charging even with charger unplugged
                    by flat-earther
                    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                    Windows also shows ''Plugged in'' when charger is not connected.
                    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                    If I let battery run out and say it has 3% Windows will...
                    06-24-2025, 09:32 AM
                  • Johndill
                    Dell Inspiron 7567 LA-D993P odd charger issue
                    by Johndill
                    Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                    There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                    I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                    Here are the tested scenarios:
                    1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                    2. With the laptop off, plug in charger (LED says on) & the front charging...
                    11-16-2022, 10:55 PM
                  • AJ847.63e
                    Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                    by AJ847.63e
                    Hi Folks,
                    Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                    I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                    The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                    05-06-2025, 10:37 PM
