MIG-130 feed motor PCB GI-PCB-H59-A0 repair (old: Help me with capacitor replacement)
    • 31087
    Re: Help me with capacitors replacement
    a pcb mounted fuse is a good idea if this keeps happening
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Originally posted by bohaboha
      Yes there is room but as you said Per I need to take an extra look at your work. but you say "I would put a regular bridge rectifier" of what value if you were to recomendera?
      It does not matter, the original is only rated for 2A so it should be more than that.
      But any bridge rectifier you have in that large package I showed is going to be rated for more than that...
      I would go with one rated for 1000v just because the original seems to be.
      And not because the circuit requires it, but because in a welder you have very large voltage spikes, and that could destroy the diodes...
      Infact it might be good to put some TVS protection, for example a varistor across the bridge rectifiers input.
      • bohaboha
        • Nov 2012
        • 1015
        • sweden
        there is already a fuse but it was not destroyed by the shock
        • bohaboha
          • Nov 2012
          • 1015
          • sweden
          so one of them would fit? but I shall come back to you after a more detailed examination of your picture and of my own circuit
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Yes sure, I'd pick the one with the longer legs, just because I could not find a datasheet for the other one.
            • R_J
              • Jun 2012
              • 9556
              The one with the shorter leads is 6 amp 600v
              • R_J
                • Jun 2012
                • 9556
                The fuse on the board is on the DC side of the bridge, there should also be a fuse on the AC input to the bridge, if not that would explain the destruction of the bridge rectifier. Looks like the board traces were the fuse in this case.
                • redwire
                  • Dec 2010
                  • 3910
                  I can't see upsizing the bridge rectifier because of the high (mains) voltage and the PC board bad design mean the spacings simply are not good enough. You need a couple mm at least or it will just arc. That leaves flying leads to connect to it I guess.
                  Second, then it will start a new problem - what now limits power to the feed motor, when it jams? You need a fuse or circuit breaker, otherwise something new will burn up. The triac has no heatsink either. This is a cheap board.
                  It seems to assume the feed motor only needs say 2A max.
                  What model name/number is this welder?
                  • bohaboha
                    • Nov 2012
                    • 1015
                    • sweden
                    #29
                    here some pictures of the aggregates with some data
                    • bohaboha
                      • Nov 2012
                      • 1015
                      • sweden
                      #30
                      Check the attached photo, the clearance is a joke!
                      I would put a regular bridge rectifier like I have shown if there is room for it.
                      Then remove the traces so the clearance between them is more than a cat whiskers hair!
                      But you need to triple check my work, it is hard to tell if there are more traces on the top of the board...
                      Hi Per you say "Then remove the grooves so that the distance between them is greater than a cat's hair!" What do you mean by removing the grooves here?
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #31
                        I don't know where you got "grooves" from, I said traces.
                        You need to remove the traces according to the picture in my post.
                        Otherwise the clearance is too small and it will just arc over again.
                        This is the reason for using the bigger bridge rectifier:
                        Not because the circuit requires it: but because it will have more clearance and be much easier to solder in the way I showed:
                        https://www.badcaps.net/forum/showpo...7&postcount=17
                        • bohaboha
                          • Nov 2012
                          • 1015
                          • sweden
                          #32
                          Forgive translation errors
                          • bohaboha
                            • Nov 2012
                            • 1015
                            • sweden
                            #33
                            Hello and thank you all who helped Per Hansson solution worked I The machine is working as it should
                              • Jul 2011
                              • 6045
                              Okay here is one thing you can do is to take a dermal tool with a round sander drum at low speed and carefully remove all of the carbon traces not the copper traces you have to be very careful not to remove to much of the board material just to remove the black which is carbon if you have to much material that you remove around the holes then you can put
                              • redwire
                                • Dec 2010
                                • 3910
                                I would check the wire feed motor is working OK. It's looks pretty cheap, small and wimpy, made by Guangzhou Epower Motor Co.
                                I can't read the feeder part number, "___SSJ27"? to see what voltage the motor is. The only ones less than 1A are 220VDC, all the others are all 12-42VDC and several amps.
                                If you connect a DC power supply to the feed motor and see if it's not jamming or has bad brushes etc. that would prevent the new bridge rectifier from burning up. I think you have to mount it off the board and run wires to it, the PCB is wrecked too much.
                                • R_J
                                  • Jun 2012
                                  • 9556
                                  It is likely a 28SSJ27, 24v 10w (1/2 amp?), I don't think the fault is with the motor etc. if it was the dc fuse would have blown. More likely a good spike on the ac input took out the unprotected bridge rectifier. (copper traces for fuses)
                                  • redwire
                                    • Dec 2010
                                    • 3910
                                    There's a good chance the transients are made by the welder itself.
                                    Is OP's board for mains phase-control to power the DC feed motor? I see the welding transformer output is 20VAC low/30VAC max. but they didn't use it for the feed motor I guess.
                                    Anyhow, it seems the spacings on the PC board are inadequate for mains voltages, and the bridge rectifier would not survive a jam on the feed. The fuse value we don't know.
                                      • 31087
                                      so it needs a new board layout, and a polyfuse.
                                      and an led+series resistor across the polyfuse to indicate an overload
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        #39
                                        With my previous post here doing a Google search you can find this page linked below for example.
                                        That was why I wrote this welder seems to be designed like crap, especially no protection for the bridge rectifier when it comes to spikes and that a varistor should be added to it:
                                        https://www.mig-welding.co.uk/forum/...-please.85827/
                                        Here is a video of someone modding it with a transformer so the wire speed does not change as you are welding, based on the previous pages mods:
                                        https://www.youtube.com/watch?v=y7UXTctu8V8
                                        • redwire
                                          • Dec 2010
                                          • 3910
                                          I drew a schematic for the MIG-130 feed motor control pc board GI-PCB-H59-A0. OP's is almost identical, just a couple resistors deleted.
                                          It's a cheapened copy of a Clarke 130EN MIG welder feed motor board. That welder also has a DC output, cooling fan.
                                          Overall, not a decent design - I have seen it's easy to get 1k+ spikes out of a 24VAC transformer (welding) which kills rectifiers. Also missing is a back EMF diode across the motor.
                                          So if this was mine, I would add an MOV or snubber across the transformer's output as well as 1N4007 across the feed motor.
                                          The circuit has some silly parts it's obvious they are all copying each other without knowing how it actually works lol.
                                          The SCR is normally full on, and the potentiometer voltage turns on the transistor which turns off the SCR. The big resistor gives some feeder load (jam?) sensing.
                                          • juergenb
                                            Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                                            by juergenb
                                            i am asking for some Help.
                                            I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                                            The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                                            So i got a few of these from Banggood.
                                            I swapped the motor and now i have a new fault condition.
                                            In a working Frother you would press the start button, it will light red and work for a few minutes.
                                            If you press longer it will light blue and just mixup the milk.
                                            With the new Motor it just starts...
                                            03-23-2021, 11:24 AM
                                          • sbt123
                                            charnwood w821 mini wood lathe motor problem
                                            by sbt123
                                            hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                                            10-27-2024, 03:43 AM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
                                          • the_rem
                                            Unknown transformer : how to find a good replacement part ?
                                            by the_rem
                                            Hello guys,
                                            I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                            I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                            04-23-2025, 01:48 AM
                                          • Per Hansson
                                            Motor run capacitor physical size vs voltage rating & measurements?
                                            by Per Hansson
                                            (TL;DR skip the first paragraph)
                                            I encountered my first dead motor run capacitor at a customer this week.
                                            For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                                            (Unless a servo motor makes more sense that is).
                                            But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                                            The pump would run but sometimes trip the 10A breaker.
                                            I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                                            Then it could...
                                            09-20-2020, 06:32 AM
