MIG-130 feed motor PCB GI-PCB-H59-A0 repair (old: Help me with capacitor replacement)
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    #41
    Re: MIG-130 feed motor PCB GI-PCB-H59-A0 repair (old: Help me with capacitor replacem
    Nice work!
    I changed the thread title to make it more visible for Google searches...
    • redwire
      • Dec 2010
      • 3910
      I noticed search engine's web crawlers are picking up the site, which is good for the tech and repairs.
      It's just a few minutes to figure what the feed motor board is doing and draw up a schematic. I couldn't see all parts/traces but got enough.
      A few boards burn up parts and welder-types not sure what the problem is to fix it. But defo need to add some transient protection, or spend more money on a better MIG welder.
      • bohaboha
        • Nov 2012
        • 1015
        • sweden
        #43
        Nice work!
        very good idea thank you
          • Jul 2011
          • 6045
          This is an issue with some very well known brands the feed motor circuit fry’s some portion of the circuit board for some reason I have repaired a couple of them that this type of failure but never figured out exactly what the issue was
            • Jul 2011
            • 6045
            It should be repairable but be careful when removing the carbon from the board on both sides not to remove to much of the board material so you have something to work with and trying not to remove any of soldering traces if possible because the more of this you remove the harder it going to be to repair this board
            I done this type of repair many times before in the past and had very good results but you have to have patience and can not be in a hurry to get the job done quickly because it will not be done correctly
            Please let us know if you were able to get it back up and running again
            • jmribault
              • Jan 2023
              So, that board is just to control the feed motor, controlled by the switch on the handle. I had the same issue and I simply replaced the board with a few things.
              1 - a 12VDC / 2 amp power supply. I had plenty laying around. I had to modify the power line to ensure the that was powered from the AC.
              2 - I replaced the speed potentiometer with a PWM 12VDC / 10 amp self-contained controller (https://www.amazon.com/mxuteuk-Contr...s_id=306530011)
              3 - I opened and cut the trace in said controller between the on/off switch and the power to the 555 timer. There is a small trace there, but this is where I decided to solder the trigger switch.
              This is involved, but that cost me a total of an hour of assembly and about $20.00 of parts). I had most of those, but there are some 12VDC PWM controllers with an on/off button available. The feed is super quiet and the PWM does a much better job of controlling the speed. No loss of power, so no large resistor and high current to waste and burn that board.
                • Jul 2011
                • 6045
                Good work on coming up with a solution for this issue let hope that it can survive the harsh environment
                One issue that can cause this is that the trigger switch wires could break and short to the high tension welding wire and burn up the speed controller board
                One solution is to use a flat two wire cable and wire it directly from the trigger switch to the speed controller board on the high tension welding wire as your support for switch wires
                • juergenb
                  Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                  by juergenb
                  i am asking for some Help.
                  I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                  The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                  So i got a few of these from Banggood.
                  I swapped the motor and now i have a new fault condition.
                  In a working Frother you would press the start button, it will light red and work for a few minutes.
                  If you press longer it will light blue and just mixup the milk.
                  With the new Motor it just starts...
                  03-23-2021, 11:24 AM
                • sbt123
                  charnwood w821 mini wood lathe motor problem
                  by sbt123
                  hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                  10-27-2024, 03:43 AM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • the_rem
                  Unknown transformer : how to find a good replacement part ?
                  by the_rem
                  Hello guys,
                  I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                  I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                  04-23-2025, 01:48 AM
                • Per Hansson
                  Motor run capacitor physical size vs voltage rating & measurements?
                  by Per Hansson
                  (TL;DR skip the first paragraph)
                  I encountered my first dead motor run capacitor at a customer this week.
                  For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                  (Unless a servo motor makes more sense that is).
                  But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                  The pump would run but sometimes trip the 10A breaker.
                  I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                  Then it could...
                  09-20-2020, 06:32 AM
