SVHS Goodness
  • mockingbird
    • Dec 2008
    • 5484
    SVHS Goodness
    So I picked up today for $6 an SVHS VCR, something I have been looking for in bargain bins for a long long time. It's been around ten years since the guy at Sears was gonna sell this to me on "sale" at $200, I offered him $100.
    In case you're curious, the model is HR-S3600U. I know JVCs are not the top pick of the litter but I checked inside, the caps are Japanese, and the picture this thing puts out is excellent.
    I also picked this camcorder up many months ago, but I need an adapter for it (The model I need is PV-A22). This is a Panasonic Omnimovie PV-S445D.
    Anyone also know where to get SVHS tapes?
  • japlytic
    • Oct 2005
    • 2086
    Re: SVHS Goodness
    Do you mean blank ones or precorded ones?
    • mockingbird
      • Dec 2008
      • 5484
      Re: SVHS Goodness
      Blanks. I'm not aware of anyone mass-producing SVHS videos, wasn't it used mainly for personal videos?
        • 31003
        Re: SVHS Goodness
        how do they differ from regular tapes?
        • Rulycat
          • Apr 2010
          • 724
          • United Kingdom
          Re: SVHS Goodness
          Higher resolution.
          Also OP, why not use DVD?
          • mockingbird
            • Dec 2008
            • 5484
            Re: SVHS Goodness
            Oh this is for conversion. I figure if I'm doing a VHS to DVD rip, the SVHS VCR will give me a better picture. Also, with this VCR I can record "SVHS ET" which is SVHS to a normal tape. I tried it results are pretty good. Old school.
            • gdement
              • Jan 2007
              • 690
              Re: SVHS Goodness
              I've bought 3 $5 VCRs in the past year, and they were all fails.
              The first one worked for about a month. The other 2 were DOA. Annoying.
              I haven't seen an SVHS yet, I'd love to get one of those if I happen across a cheap one. But when I do, it probably won't work.
                • 31003
                Re: SVHS Goodness
                dont buy a vcr until you know where to get a new belt-kit, idler & pinch-roller.
                • kaboom
                  "Oh, Grouchy!"
                  • Jan 2011
                  • 2507
                  Re: SVHS Goodness
                  Whatever you do, don't fall for that 'drill a hole' trick, as seen here:
                  http://www.technofileonline.com/text...persvhs90.html
                  SVHS tape is higher coercivity than 'normal' VHS tape. If you cheat and record the hotter, higher frequency, wider deviation with higher carrier freq signal onto regular tape, you're gonna have problems. It'll look minor at first- beading/overmod noise in high contrast areas, with partial self-erasure after the oversaturated domains 'neutralize' themselves.
                  VCR belt/pinch kits:
                  www.studiosoundelectronics.com
                  -Paul
                  Edit- way to bump an old thread!
                  "pokemon go... to hell!"
                  EOL it...
                  All style and no substance.
                  guilty,guilty,guilty,guilty!
                  guilty of being cheap-made!
                  • b700029
                    Banned
                    • Sep 2010
                    • 640
                    Re: SVHS Goodness
                    Dead VCRs (and other discarded electronics) are a good source of various parts. In this case you get a few motors, gears, and miscellaneous mechanicals too.
                    • Longbow
                      • Jun 2011
                      • 623
                      Re: SVHS Goodness
                      SVHS came about in order to obtain a slightly better picture than VHS. SVHS is not a higher resolution picture even though certain advertising materials make that claim. The primary advantage is that the chroma and the video signals remain separated all the way to the tube, (assuming you have an SVHS CRT monitor). The system was intended to reduce chroma noise and crosstalk with the Y signal, and it did improve the picture slightly when used with the proper equipment. As far as your JVC SHVS machine, your main electronic issues will be the switching power supply. A bigger deal is worn parts in the transport and proper adjustment.
                      Is it plugged in?
                      • kaboom
                        "Oh, Grouchy!"
                        • Jan 2011
                        • 2507
                        Re: SVHS Goodness
                        The FM luma carrier on the tape is a higher frequency than non "S." We can deviate more, and still keep the LSB away from the 629 kHz color-under sub carrier.
                        More bandwidth and seperate Y/C.
                        EOL it...
                        • chzuck
                          HP ZBook 15 G3 Freezes When Picked Up
                          by chzuck
                          I have an HP ZBook 15 G3 that has developed a problem. If picked up by the lower left hand corner the screen freezes. nothing responds. The only way to shut if down is to hold the power button down. I can restart and it will work fine until it is bumped or picked up on the left lower side. Looking for some trouble shooting ideas, please.
                          I have eliminated by battery by disconnecting and running on AC power.
                          11-01-2023, 08:14 AM
                        • mrtek
                          Samsung UN43NU6950FXZA No power
                          by mrtek
                          Hi
                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                          Main fuse = OK
                          Back light LED = OK. Power them with aux power source
                          LED output = OK 156V
                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                          07-20-2025, 08:06 PM
                        • mrtek
                          Vizio M65-C1
                          by mrtek
                          Hi.
                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                          07-14-2025, 07:28 PM
                        • cheebster
                          Samsung OLED QN77S90 Bad Power Supply
                          by cheebster
                          Hello, picked up this tv a nice Oled QN77S90. However, it's blowing fuses like crazy (got the whole room lights go out the first time). So i digged and it seems this tv has the BN44-01264A PSU that often fails. However, replacements are costly (samsung replaces it for the BN44-01329A revised psu).
                          I'd like to troubleshoot that one. Here is a picture of it, but honestly i don't know where to start. It blows a 12A fuse in a split second, it's really a hard short on this one. Thanks for any guidance ! ...
                          07-10-2025, 09:29 AM
                        • mrtek
                          Samsung QN50Q6DTA
                          by mrtek
                          Hi I just picked up a Samsung QN50Q6DTA. The issues was a 2 red flashes on the power button as the TV tried to turn on. Power supply OK. Backlight LED OK. If I remove the data cable from panel , sound is ON. I was able to identify the issue within one side of the panel. Used the tape fix and I placed the tape on 4 pins on one side of the flat cable. The TV ran great for 4 days and then the same problem appeared again...2 red flashes on the power button LED. Took the back panel off again and this time mode the tape on a different location and now the TV is running again. Am I missing something?...
                          07-10-2025, 09:17 AM
