SVHS Goodness
  • mockingbird
    • Dec 2008
    • 5488
    SVHS Goodness
    So I picked up today for $6 an SVHS VCR, something I have been looking for in bargain bins for a long long time. It's been around ten years since the guy at Sears was gonna sell this to me on "sale" at $200, I offered him $100.
    In case you're curious, the model is HR-S3600U. I know JVCs are not the top pick of the litter but I checked inside, the caps are Japanese, and the picture this thing puts out is excellent.
    I also picked this camcorder up many months ago, but I need an adapter for it (The model I need is PV-A22). This is a Panasonic Omnimovie PV-S445D.
    Anyone also know where to get SVHS tapes?
  • japlytic
    • Oct 2005
    • 2086
    Re: SVHS Goodness
    Do you mean blank ones or precorded ones?
    • mockingbird
      • Dec 2008
      • 5488
      Re: SVHS Goodness
      Blanks. I'm not aware of anyone mass-producing SVHS videos, wasn't it used mainly for personal videos?
        • 31283
        Re: SVHS Goodness
        how do they differ from regular tapes?
        • Rulycat
          • Apr 2010
          • 724
          Re: SVHS Goodness
          Higher resolution.
          Also OP, why not use DVD?
          • mockingbird
            • Dec 2008
            • 5488
            Re: SVHS Goodness
            Oh this is for conversion. I figure if I'm doing a VHS to DVD rip, the SVHS VCR will give me a better picture. Also, with this VCR I can record "SVHS ET" which is SVHS to a normal tape. I tried it results are pretty good. Old school.
            • gdement
              • Jan 2007
              • 690
              Re: SVHS Goodness
              I've bought 3 $5 VCRs in the past year, and they were all fails.
              The first one worked for about a month. The other 2 were DOA. Annoying.
              I haven't seen an SVHS yet, I'd love to get one of those if I happen across a cheap one. But when I do, it probably won't work.
                • 31283
                Re: SVHS Goodness
                dont buy a vcr until you know where to get a new belt-kit, idler & pinch-roller.
                • kaboom
                  "Oh, Grouchy!"
                  • Jan 2011
                  • 2507
                  Re: SVHS Goodness
                  Whatever you do, don't fall for that 'drill a hole' trick, as seen here:
                  http://www.technofileonline.com/text...persvhs90.html
                  SVHS tape is higher coercivity than 'normal' VHS tape. If you cheat and record the hotter, higher frequency, wider deviation with higher carrier freq signal onto regular tape, you're gonna have problems. It'll look minor at first- beading/overmod noise in high contrast areas, with partial self-erasure after the oversaturated domains 'neutralize' themselves.
                  VCR belt/pinch kits:
                  www.studiosoundelectronics.com
                  -Paul
                  Edit- way to bump an old thread!
                  "pokemon go... to hell!"
                  EOL it...
                  All style and no substance.
                  guilty,guilty,guilty,guilty!
                  guilty of being cheap-made!
                  • b700029
                    Banned
                    • Sep 2010
                    • 640
                    Re: SVHS Goodness
                    Dead VCRs (and other discarded electronics) are a good source of various parts. In this case you get a few motors, gears, and miscellaneous mechanicals too.
                    • Longbow
                      • Jun 2011
                      • 623
                      Re: SVHS Goodness
                      SVHS came about in order to obtain a slightly better picture than VHS. SVHS is not a higher resolution picture even though certain advertising materials make that claim. The primary advantage is that the chroma and the video signals remain separated all the way to the tube, (assuming you have an SVHS CRT monitor). The system was intended to reduce chroma noise and crosstalk with the Y signal, and it did improve the picture slightly when used with the proper equipment. As far as your JVC SHVS machine, your main electronic issues will be the switching power supply. A bigger deal is worn parts in the transport and proper adjustment.
                      Is it plugged in?
                      • kaboom
                        "Oh, Grouchy!"
                        • Jan 2011
                        • 2507
                        Re: SVHS Goodness
                        The FM luma carrier on the tape is a higher frequency than non "S." We can deviate more, and still keep the LSB away from the 629 kHz color-under sub carrier.
                        More bandwidth and seperate Y/C.
                        EOL it...
                        • chzuck
                          HP ZBook 15 G3 Freezes When Picked Up
                          by chzuck
                          I have an HP ZBook 15 G3 that has developed a problem. If picked up by the lower left hand corner the screen freezes. nothing responds. The only way to shut if down is to hold the power button down. I can restart and it will work fine until it is bumped or picked up on the left lower side. Looking for some trouble shooting ideas, please.
                          I have eliminated by battery by disconnecting and running on AC power.
                          11-01-2023, 08:14 AM
                        • Syph1979
                          PS5 EDM-031 1216A BIOS Issue
                          by Syph1979
                          Hi all. First post here, so I hope I'm getting this right and operating in the spirit of things here.
                          I've been working on consoles for a while now. Always learning and trying new repairs, but I have one that has been stumped and I wondered if anyone with more experience could help?
                          I picked up a PS5 from eBay recently. It was described as not having the disc drive, but it was also a no power unit. On testing it was clearly an issue with the supply (no 12v), so I replaced that and then when I inserted the power lead, I got 3 beeps. So far, seems all related. As I was...
                          09-25-2025, 05:48 AM
                        • valvashon
                          Sharp R-930CS microwave/convection oven, dim display
                          by valvashon
                          Older microwave/convection oven I picked for free on Marketplace. Previous owner replaced turntable motor which didn't fit in the mounting hole properly. Shaft was at an angle causing plastic thing that fits onto it to eventually break. Filed the hole bigger, fitted the motor correctly, put on a new plastic thing, all (almost) is OK.
                          The fluorescent display is quite dim. The camera doesn't see what the eye sees so these pictures are brighter than what the display really looks like:
                          As you can see even from these pictures, the tops and bottoms of the...
                          Yesterday, 12:34 PM
                        • ldogg
                          need a bios for model tuf516pr
                          by ldogg
                          im looking for a bios for
                          serial: m9nrkd02310938g
                          model:tuf516pr-bs71-cb
                          cn: sw3z
                          mfd: 2021-09
                          its bios locked. my 14 year old son did it and dont know how. tried to reprogram but cant find a bios. attached what i think is the original if i picked the right chip on the mobo...
                          11-04-2025, 04:45 PM
                        • BigPete
                          Panasonic Heatpump Dryer Repair
                          by BigPete
                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                          Unfortunately the whole machine has to come apart to fix it.
                          I have...
                          11-01-2025, 06:40 PM
