Active Car Radio Aerials
  • barry wilkins
    • Aug 2009
    • 172
    Does any body have circuits on the amplifiers used in these car radio aerials.
    The unit in my Citreon is low gain,think water got into it.
    I have removed it and dried it out,but it did not make it work any better.
    Now the better weather is on its way . I intend to remove it and look at it again.
    Its a pig to remove bceuase of the roof lining ,so I want to fix it this time.
    Barry
    • 31265
    Re: Active Car Radio Aerials
    very unlikely,
    but you finf some car stuff at radiolocman
    https://www.radiolocman.com/
    • CapLeaker
      Leaking Member
      • 8342
      Are you sure it is the antennas fault and not the radio itself? What type of antenna are you talking about?
        • 31265
        maybe it's not getting power.
        french cars have a habit of letting water into places they shouldnt.
        • barry wilkins
          • Aug 2009
          • 172
          Checked the radio out of the car ,sure it ok
          Bought an inline amplfier ,had to make a biased tee to get the 12 volts from the radio lead.
          But its not that good.
          One of the problems the freq. keeps changing as you drive .Dont think the transmiiters are very good where I live.
          Barry
            • 31265
            you dont use a T, the radio has an output for the antenna that powers down in standby or if you play a tape or cd.
            you can turn off the auto-tune thing, i cant remember what it's called but Pioneer invented that.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8704
              Broadcast Transmitters in developed countries should be under strict laws to be transmitting on fixed frequencies with parts per million accuracy. So they should not be changing, unless you mean they're fading due to distance from the transmitting tower and you need to choose a different station, or you mean a low power personal transmitter (which are annoying when they drift, and really should buy a PLL transmitter that won't drift!)
              Power injection is fairly common practice to reduce wiring needed to enable inline amplifiers, so that shouldn't be an issue...
                • 31265
                car radio's dont use power injection,
                the tuning thing is a function, if the signal gets weak the radio will scan for the next frequency that transmits RDS traffic data.
                • barry wilkins
                  • Aug 2009
                  • 172
                  The cable to the radio is just 50ohm coax .
                  Same as sattelite ,DC voltage on the inner wire to the amp.
                  RF goes back to the radio.
                  So you use a biased tee filter to power the amp.
                  When the weather improves going to remove the aerial again {it aint easy to remove}
                  Found an intersting circuit that use an IC MAX circuit .
                  So might try that.
                  Barry
                  • CapLeaker
                    Leaking Member
                    • 8342
                    What are we talking here? FM? Frequencies only change if you are out of the transmitter range. An FM station surely does not “wander” around, they are rock solid in that aspect. However if the transmitter isn’t properly tuned it can “grow grass” on both sides of the main signal, making it dirty and prevents you from listening to other stations. Also signals can mix and could produce a weaker copy of the main signal somewhere else. However these things are regulated by the government. Chances of that happening is extremely low.
                      • 31265
                      so in the u.k. you have 2 classes of FM station,
                      private and BBC.
                      private stations are usually single-site and use modern transmitters.
                      BBC often use mutiple frequencies from different locations and use old valve crap that has massive overspill and echo on nearby frequencies!!!
                      for some reason they are exempt from the regulations that prevent such crap from comercial transmitters.
                      the BBC really piss me off, they have very few listeners anymore, but they manage to consume atleast 25% of the available frequency space with their wideband ww2 era crap.
                      they dont give a fuck because they are tax-funded - even if they had zero listeners they would still keep runing to pretect their worthless jobs!
                      • redwire
                        • 3912
                        Rare to see phantom power with a bias-tee for cars. Looked at Citroen antennas and there is a FAKRA RF connector and another lead for power, some models have more wires. There is also a dedicated RF amp module, no idea where it's located but not in the antenna or radio.
                        P.S> Whatever happened to AFC? FM didn't work so good without it, everything drifted.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8704
                          AFC not needed with PLLs, as long as you got a good stable crystal...which usually is more than stable enough for receiver use. Transmitters, would be nice to have a TCXO.
                          It's those ancient radios with LC oscillators that drift badly... there I see a couple FM receivers with AFC. I have this one tube FM receiver that drifts, at least when AFC is off. When turned on...well I didn't test it much.
                          I also have a crappy FM transmitter that likewise also uses a LC oscillator and it drifts badly, usually off by 200-300 KHz after warming up. The PLL FM transmitters are much better, not perfect but good enough.
                          • barry wilkins
                            • Aug 2009
                            • 172
                            Hi some pictures
                            The active aerial from the Citreon ,only has a 50 ohm cable.
                            the amplifier inside the aerial
                            and the in line amplifier I bought on line.
                            I had to make a filter to power this up.
                            The intention is to fit this amplfier inside the aerial unit
                            I have seen an aerial that looks exactelty the same with two leads on line
                            It would mean running a cable from the radio to power it up.
                            Barry
                            • redwire
                              • 3912
                              The factory antenna amp looks better than the one you bought IMHO.
                              The OEM has spark gaps, transient protection, 4 transistors and a bunch of inductors.
                              The new board has none of that, and only 2 transistors. So you might want to evaluate it before fitting it in there. I can't see it performing that great.
                              It looks like Citreon is using a tiny antenna and trying to make up for that with the preamp?
                              • shelby5041
                                clock radio / radio lifespan?
                                by shelby5041
                                hi
                                ive got a modern digital clock radio approx 15yrs old
                                my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                it uses very little power just a few watts i would imagine that may have something...
                                09-14-2024, 03:30 AM
                              • UserXP
                                Vintage SONY Digital Clock Radio ICF-C12W no audio
                                by UserXP
                                Dear all,
                                I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                My question is, do you know of this brand of capacitors and how bad are...
                                07-21-2025, 08:35 AM
                                HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                09-12-2024, 02:00 PM
                                Lenovo ThinkPad X1 Carbon + Jabra Elite Active 65T (100-99010000-40) Notebook X Specification for Upgrade or Repair
                                This specification for the Lenovo ThinkPad X1 Carbon + Jabra Elite Active 65T (100-99010000-40) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + Jabra Elite Active 65T (100-99010000-40) boardview and X1 Carbon + Jabra Elite Active 65T (100-99010000-40) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                09-06-2024, 11:51 AM
                                Lenovo ThinkPad X1 Yoga + Jabra Elite Active 65T (100-99010000-40) Hybrid (2-in-1) X Specification for Upgrade or Repair
                                This specification for the Lenovo ThinkPad X1 Yoga + Jabra Elite Active 65T (100-99010000-40) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga + Jabra Elite Active 65T (100-99010000-40) boardview and X1 Yoga + Jabra Elite Active 65T (100-99010000-40) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
