(Multiple Spark Discharge) MSD 6AL Q204 required
  • alltvrepairs
    • Jan 2014
    • 255
    • Malta
    Am after the part number for this unit used in an old Ford Capri for boosting spark ignition.
    Unit is MSD6AL and Q204 is the damaged part.
    If I can figure out at least if it is a Mosfet type or Bipolar Transistor like MJE3055T as used in older Models.
    Any help appreciated!
    • 31262
    Re: (Multiple Spark Discharge) MSD 6AL Q204 required
    try cleaning it.
    what are the others on that pcb edge?
    • alltvrepairs
      • Jan 2014
      • 255
      • Malta
      I think it is a N Channel Mosfet as marked with Mitsubishi Logo and starts with
      FS7........
      FS70KM-2 VDss 100v, Id 70A looks a good contender.
      According to Transformer thick windings that is switched solely from this Q240, 70A seems reasonable.
      This winding is 1 side 12v and the other switchable by Q240 so 100v is also in range.
      What do you think?
      • redwire
        • 3912
        From another MSD 6AL repair blurb:
        TC4627 has voltage-doubler 2.2uF tantalum caps that fail.
        BUP213 IGBT 1,200V 32A or IRG4PH40K
        FS70KM or IRF1010E if you add insulator.
        FS70KM-02 is 100V 70A 20mR
        FS70KM-06 is 60V 70A 7.5mR
        IRF1010E is 60V 84A 12mR
        Plastic TO-220 fullpack aren't great at getting rid of heat. The 1N5244A zener apparently can go too if the mosfet shorts.
        Higher voltage mosfets have higher RDS on, which will make them run hotter.
        • alltvrepairs
          • Jan 2014
          • 255
          • Malta
          Sorry for late reply as just noticed you replied. Many thanks for your feedback. I will post update hopefully very soon!
          • npielawski
            MacBook Pro late 2016 (820-00239) with multiple failure modes.
            by npielawski
            I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
            I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
            10-15-2025, 01:53 AM
          • Axis937
            Accidental slip of the hand caused a spark on Capacitor. Is my PANEL killed in action?
            by Axis937
            Hi folks, newbie here. My intention on a working monitor was to test for voltages on the various pins. Somewhere near the ribbon to the monitor, there we 2 caps. One was reading around 5V and the other was maybe about 12 or 14V . Cant really recall. Then it happened. The multimeter kissed the 5v cap and the other cap. Spark appeared. NOW... the part where the spark happened ( Caps near the Last ribbon cable ) is now totally white. 1/6 part of the screen is white. From my little understanding , i came to learn that there are transistors inside the TFT panel. Could that be a issue then? I have removed...
            11-10-2024, 06:50 AM
          • redwire
            Making a capacitor discharge tool
            by redwire
            I'm making a new capacitor discharge tool. Asking for suggestions for sizing the discharge resistor.
            Mr. Carlson's Lab High Voltage Capacitor Discharge Tool 1 is using 4 of 1kΩ 50W aluminum (mount to heatsink) resistors in series for 4kΩ 200W, so it's big, which is fine.
            His Patreon but I don't have a paid subscription for the project details but it looks straightforward. The plastic box with aluminum plate can't get rid of any amount of that heat though.
            Wirewound resistors can be overloaded by a factor of 5 for 5sec. and a factor of 10 for brief times. I've never tried say...
            06-18-2023, 07:09 PM
            SealSunny battery M150 ( only ) load testing machine review
            by sam_sam_sam
            I recently bought this at full price I am getting paid for this was not free (Lithium Lead-acid Battery Capacity Tester 30V 20A 150W Discharge Battery Tester)
            https://www.ebay.com/itm/38444852660...53.m2749.l2649
            MD150 discharge tester parameters
            Model MD150 discharge voltage 0-30V
            Discharge power 150W, discharge current 0.1-20A freely set
            Equipment power supply: DC12V/2A, operation mode, discharge manual switch
            Error 1% heat dissipation temperature controlled...
            03-13-2022, 04:55 AM
          • wichzen
            Casper c510 mother board code 08N1-18Y4Y00 Rev 2.2 KBC required
            by wichzen
            Casper c510 mother board code 08N1-18Y4Y00 Rev 2.2 KBC required Can someone please share?
            07-28-2025, 05:29 AM
