Op-amp preamp discussion
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Re: Op-amp preamp discussion
    True, that would be a pretty interesting test and since I have 3 boards, I could do that rather easily. That's why I also said we're talking from a purely subjective standpoint, relying on the human ear and each individual test subject, as I'm sure there would be some differences from a purely technical standpoint in a laboratory setting with high-end test equipment and number-crunching, maybe even batches of the same exact components (op-amp, cap, potentiometer).
    Wattevah...
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8666
      Put in a LM358... I'm curious. I've "heard" that it has problems with linearity.
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        Potentiometer imbalance is another thing I've always been bothered by and this project suffers from it as well. The left channel always come in hotter than the right at low volumes and sure enough, measuring the pot confirms the (often wild) difference in resistance between the 2 channels despite these not being the crummiest of pots out there. I THINK they're from a decent brand - Alps. Ironically, I happen to have a big-a$$ Alps pot in my parts box (RK50 series) I ordered of Ali a while ago, not even aware of its full potential (pun intended) and it reads NO imbalance at all indeed. The only reason I don't use it here is because I don't like the bumpy steps it's got - it's not a linear feel when you turn it, but rather an encoder-like feel.
        Initially, I was planning to use some sort of volume control IC, but while that would solve the imbalance issue, I'd introduce unnecessary complexity and possible distortion of its own, so I scrapped the idea, at least for now...
        Wattevah...
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          I started wondering if there's a way to control the volume (gain) on two distinct op-amps with one single pot. Turns out there is, but doesn't look easy: VCA...haven't looked into whether it can be pulled off or is even the right thing for the job...
          Wattevah...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8666
            well, all those radios wih no pots are doing somethingrather...
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              #26
              I found some push-button volume control ICs a long while ago, but that's not really the style I want in this project...I also don't want to go crazy overboard with components and complexity either, but it looks like I'll HAVE to if I choose to go down this road....or just keep trying pots until I find one with least imbalance I guess
              Wattevah...
                • Jul 2011
                • 6023
                I going to suggest something that might not be obvious at the moment but why not replace both pots with new ones with the same exact part number and see if you have the same imbalance
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8666
                  or you can always add trimpots....
                  • lti
                    • May 2011
                    • 2545
                    Trimpots won't help if the imbalance constantly varies like the 100k dual gang pots that Radio Shack sold in their dying years.
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      #30
                      All pots are new. Here they are. I got 5 of them. The problem is most obvious on the volume control for MAX4410 headphone amp, because headphones sit right next to your ear and this thing gets pretty loud pretty quickly, as soon as you turn the volume pot, so to get it to sound somewhat balanced, I'd have to turn it louder than what I'm comfortable with. The main amp on the other hand is harder to notice, since it's louder and I also had the speakers right next to each other during testing, plus I have those individual "downstream" pots which I can tweak to balance it out.
                      I guess at this point I should provide a schematic explaining what I want to achieve. It looks something like this...no inspiration - just came up with it on my own thinking how a car headunit works. It works in practice, save for the imbalance inconvenience. I'll use this setup to drive a subwoofer on the rear channels, hence why I needed a way to shut it off entirely if I want to. Normally that's where a balance control would go, which is NOT what this is, I'm aware of this. That would not be of use to cut off the sub entirely. This is more like individual volume controls for each of the 4 speakers, which is fine - I don't mind that. I'd have the last 4 pots all the way up, so they're basically out of the picture, adjust the main volume at the bottom as needed and simply trim the speaker that sounds louder if needed. The headphone amp is pre-master volume control.
                      Now that I think about it.....can I get away without the op-amps entirely and just parallel the pots on each side ? I think what would happen in that case is adjusting one of the pots, alters the volume on the other one as well. Haven't tried it. Will throw it on the simulator to see...
                      Wattevah...
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        #31
                        Out of curiosity, I went to my parts bin and dug out that big Alps pot I mentioned as being perfect in terms of balance and it turns out it's not really Alps and it's not really a "pot" either
                        First off, there's no info on this part whatsoever - RH2702 only gets me links to random sellers and references to the "real" thing which apparently is the RK271 series. RH is not even an official Alps series of its own, which leads me to believe it's a knock-off. Should come as no surprise given that I got it off Ali and it's common practice for sellers to spoof official names and models by altering a letter, such as Sqny instead of Sony and so on. In this case, it's RH instead of RK.
                        Backing this up is a discussion I found here where they talk about the same exact doubts about the authenticity of said pots. Someone said the real ones do not have a stepped feel and knurled shaft and also a serif font for the ALPS logo on the back....mine has both of the former and plain text as well, so it's deffo fake.
                        Looking past that, what IS this thing then ? I mentioned how it's got a stepped feel to it and how it's not really a pot. It's a "stepped attentuator" if you ask me. I found a picture of it dismantled here and the way it works is by moving the wiper across a series of fixed value SMD resistors, hence the stepped feel when you turn it. Out of curiosity, I took mine apart as well and sure enough, there's your 22 SMD resistors in series. It works fine, no complaints there and I guess one redeeming aspect is that it offers "true zero" when the wiper is at either end (why can't more pots do this ?), but the stepping is kind of rough and results in large jumps in volume. I also don't like the force required to turn it....
                        This got me thinking of getting a real RK one, since it seems to be praised by audio guys....
                        Wattevah...
                        • petehall347
                          • Jan 2015
                          • 4423
                          #32
                          loudness tap as well ..bargain ..
                          the ones pioneer used were pretty good . think its 60 clicks on my one .
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            #33
                            This one is 22, counting the zero position. I had no idea what the fourth pin was for. Measuring it against the others just gave some random BS reading that made no sense. After reading about it, I learned it's called a loudness tap and it's connected somewhere in the middle of the resistors, so at one point the resistance between the wiper and this pin becomes zero indeed.
                            No idea what I could use that for though...
                            Wattevah...
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8666
                              I'm surprised, thought those pots with tons of little detents were mechanical detents on a continuously variable background; I'm surprised that it's cheaper to make a side switch on a PCB with tons of different little SMD resistors -- though getting a good long lasting log pot isn't easy.
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                #35
                                I thought the same from the moment it landed in my parts bin years ago, until yesterday when I tried looking up a datasheet for it and got nothing other than that page which shows one open.
                                I tried it out as the master volume for the headphone part of my build, just out of curiosity and just as I predicted, after just one CW click (so 50 ohms "away" from GND), it gets louder than how I'd like it to be, at least for these particular earphones and laptop, as I'm sure it'd be adequate if I maybe had higher impedance drivers, a device with a weaker output and the content itself encoded at a lower volume. The channel balance on the other hand is, as I said and as you'd expect from fixed value resistors, BANG on, to the nearest digit ! I'd like to see something else like this but with more steps, hence more resistor values packed in there because the concept is great overall, albeit it's an overall fake part nonetheless !
                                Wattevah...
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8666
                                  nothing is easy, all these workarounds...loudness, or end up just not caring when volume is low and LFE are lost with it.
                                  I highly doubt there will be solutions with more detents because stocking so many resistor values would get kind of expensive.
                                  Sigh audio, it's 100% analog... detents are a digital concept, and that's not analog thing. Or perhaps accurate and precise digital pots is the answer.
                                  • Omron
                                    I want to dim light bulb by 50% I want to learn how to calculate it on my own
                                    by Omron
                                    I have a 5W lamp on 12Volts battery, I want it to be half as bright, so I will add a resistor. What resistor should I supply?
                                    A = W = 5 = 0.416mA
                                    _ _
                                    V 12
                                    R = V = 12 = 28.84 Ohms (R) this is resistance of lamp
                                    _ _____
                                    I 0.416
                                    So I will add one resistor 28.84 Ohms
                                    I will have 28.84 + 28.84 = 57.6 Ohms
                                    Or 28.84 + 28.84 = 14.42 Ohms
                                    I don't know if it will work in series or in parallel
                                    voltage would be 6V and amp current mA = 0.208mA We divide everything by two
                                    W= V * I...
                                    06-04-2024, 01:58 AM
                                    LM358 LM358S-13 Datasheet
                                    The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
                                    Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
                                    10-07-2024, 04:12 AM
                                  • Kesson
                                    Repairing dbx 1066 compressor/gate/limiter
                                    by Kesson
                                    Hi! Hope you're fine! (:
                                    So a friend gave me this unit which had faulty pushbuttons. Sadly I messed things a little up while doing the job.
                                    Here's the schematic hosted:
                                    https://elektrotanya.com/dbx_1066_sch.pdf/download.html
                                    I managed to repair a vias connecting bottom and top with a bridge. After this sound is back on channel 1.
                                    More saddly I managed to destroy channel 2 by an overload occured while testing (too much volume). Now channel 2 is dead and I'm left with channel 1 who seems to work fine.
                                    As I am...
                                    11-16-2019, 06:38 AM
                                  • Curious.George
                                    Adding gain to antenna distribution
                                    by Curious.George
                                    I'd like to drive LOTS of RG6 drops (i.e., 20?) without having to rewire splitters (they are highly inaccessible).
                                    I can't locate anything mains-powered near the splitters so any power has to come via an injector(s).
                                    So, is it better to put ALL the gain between the antenna and splitter; some gain on each drop AFTER the splitter; or a combination of the two? (Or, a multi-tiered splitter with gain between tiers?)
                                    [This is for CATV, OTA TV & FM]
                                    07-07-2019, 12:46 AM
                                  • EasyGoing1
                                    How to calculate current in R2 with an LM317
                                    by EasyGoing1
                                    Given this circuit:
                                    How can I calculate IR2?...
                                    05-20-2021, 01:31 PM
