My Uni-T died... looking for a replacement
  • DanFen
    • Apr 2017
    • 201
    • Malta
    Hello people, hope you are all doing well!
    I have a lovely Uni-T UT139C, which I've used during the past couple years, but has unfortunately died on me. It comes up with an ErrE error, and upon a quick search, it seems to be related to communication with the main chip (or the chip itself).
    Putting it aside for the time being, I need a replacement (then possibly trying to repair this Uni-T later). And this is where I need your suggestions, because, I'm not an electronics person, but rather an IT one. I am occasionally doing basic electronic component repair to laptop boards, and occasionally trying to repair electronics on random devices for fun... time permitting!
    I'll be honest, the features of the UT139C are far from what I've ever used, and probably also far from what I will ever use. So my question is, which brand/model do you suggest for my needs? Unfortunately I've had a no brand multimeter that worked for years before the Uni-T, so I'm naturally questioning the reliability of Uni-T... although this could very well be bad luck (just like with any other machine).
    Thanks!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: My Uni-T died... looking for a replacement
    Well the big thing is what you are willing to pay?
    The new Brymen BM789 (Or EEVBlog branded Brymen BM786) are very nice meters, more aimed at electricians.
    The Brymen BM869 is more for electronics work, both are really cheap for a top brand meter like this.
    Otherwise you can sometimes get really great deals on eBay for a bit older test equipment.
    Like this Fluke 27 that includes both high voltage & RF probes: https://www.ebay.com/itm/393592090990
    However note that I am in no way recommending this specific meter for you unless you have a need for it:
    It looks like military surplus and the US military sometimes uses average responding meters (not True RMS)
    And they are therefore of limited use outside that niche world.
    But Fluke even sells a version of this model to this day, called Fluke 27-II.
    If you need the TRMS version it is called 28-II.
      • 30977
      for electrical work?
      or electronics?
      your 139c has a bad or corrupt eeprom - very unusual to happen btw
      • DanFen
        • Apr 2017
        • 201
        • Malta
        Thanks! I'll have a look at those Brymen, never heard of that brand before.
        Definitely not worth paying hundreds in my case. Maybe the cost of these Brymen would be the max I'd pay. This is because I don't use the meter on a daily basis.
        Like this Fluke 27 that includes high voltage probes: https://www.ebay.com/itm/393592090990
        • DanFen
          • Apr 2017
          • 201
          • Malta
          Electronics. Yeah I read about it, I'll probably create a dedicated thread about this, hoping to find someone who will be willing to assist with troubleshooting
          or electronics?
            • 30977
            best meter for electronics IMO is UNI-T UT-61e (NOT the new mk2 version)
            very good price too.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8078
              That's debatable… I'd be looking for a Brymen. Some Greenlee's are rebranded Brymen's over here.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8694
                sigh. My hacked Mastech (with a data logging port) died. Now where can I get another cheap DMM that has logging or easily hacked to log. Else I might have to hack my other meter (Tenma) with logging, but it's not as straightforward to log.
                • televizora
                  ghettomodmaster
                  • Nov 2016
                  • 957
                  Uni-T and MG and clones are not bad devices for their price.
                  Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                  1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                  • madfreak
                    Which multimeter to choose : BRYMEN BM 869S OR UNIT UT18B PRO ?
                    by madfreak
                    Hello, there were probably topics like this, but I need opinions about these 2 multimeters or maybe there is another one on the market worth to buy ? .
                    I am going to change the multimeter and I do not know if the 2x higher price for Brymen will convert into speed and comfort of a work ...
                    What would you recommend?
                    Brymen BM869s or UNIT UT18B pro?
                    I care about accuracy and security, and the meter will be used for computer hardware.
                    Thank you very much in advance for your comments and suggestions
                    04-30-2022, 01:10 AM
                  • ngml
                    Repair of an LG split AC system indoor unit PCB
                    by ngml
                    I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                    This indicates an error in the communication between the outdoor and the indoor unit.
                    The outdoor unit is fine, so the problem is the indoor PCB.
                    The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                    I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                    Does anybody have the schematics of this board,...
                    02-01-2025, 12:55 PM
                  • the_rem
                    Unknown transformer : how to find a good replacement part ?
                    by the_rem
                    Hello guys,
                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                    04-23-2025, 01:48 AM
                  • carrzkiss
                    Cyberpower cps1500avr not charging batteries
                    by carrzkiss
                    Hello, all.
                    Cyberpower Battery Backup Unit.
                    I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                    When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                    In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                    Checking the voltage, it was down to 22v.
                    I quickly removed everything...
                    06-15-2024, 02:10 PM
                  • cmlewis89
                    LG 47LB5DF blown power supply board
                    by cmlewis89
                    Hi folks,
                    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                    09-03-2024, 07:50 PM
