How different in size can you go for SMD capacitors?
  • SluggerB
    • Aug 2020
    • 747
    • US
    I'm working on bringing an old cell phone back to life. During the repair of the actual damaged part, I accidentally desoldered a few tiny (like grain of sand tiny) cap's off the board which are now forever lost on my basement floor.
    I have the schematic of the board so I looked them up and got some replacements, and despite a half dozen attempts, these damn things are WAY to small for me to get on the board. Every time I try it just gets screwed up, the cap flys off from the hot air, I try to put pressure on it and it pops out and goes flying, etc. I don't have the tools needed to work with stuff this tiny
    Could I get some larger SMD's with the same specs and use them, as long as I can make contact with the solder pads?
  • petehall347
    • Jan 2015
    • 4429
    Re: How different in size can you go for SMD capacitors?
    try holding them down with flux when blowing hot air .
    • R_J
      • Jun 2012
      • 9579
      Sometimes I lay a needle tip across the smd and lay something on it to apply a bit of pressure. the needle tip will hold the smd in place as the solder melts.
      • mmartell
        • Oct 2013
        • 3189
        This works for me as well. If the pads are tinned the component will fall right into place.
        • petehall347
          • Jan 2015
          • 4429
          with the flux there i find i can add solder if needed but a little tricky to get it right . have tried solder paste but getting the right amount is white man's magic to me . can never get it so it's not too much .
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
          • dragon3x
            by dragon3x
            power on.
            Here are some examples :
            switching supply area).
            than 6.3 V.)
            03-21-2025, 02:46 PM
            Copy DMI info easily with Hex editing software and Macro script
            by SMDFlea
            Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
            Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
            02-28-2023, 02:14 PM
          • slybunda
            AA and AAA battery charger capacitors?
            by slybunda
            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
            it has inside:
            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
            2 x 470uf 16v LZ105c branded as G.Luxon
            not heard of these brands are they any good?
            iv attached photos of the charger and the board inside for an idea on the type of...
            12-24-2023, 04:41 AM
