Troubleshooting Question
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I have this circuit that is powered from AC but on the other side of the transformer, is an old school bridge rectifier. The circuit won't power up, so I took a reading at the low end of the transformer and I got 0 volts
    Then, I removed the diodes and took another reading and I got close to 10 volts. and YES, the meter was on AC setting both times.
    I tested the diodes and all four of them came back at .56 volts from the Fluke meter.
    What could potentially cause this problem?
    sigpic
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Troubleshooting Question
    try new diodes
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      try new diodes
      Well, I didn't have any like that laying around, but I did have a doner Apple laptop motherboard that had some on it, so I pulled four of them off and soldered them on this circuit, and right away I got 6 volts at the low end of the transformer, so I plugged everything back in and it's working like a champ!
      Thank you.
      sigpic
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        thats twice this week i have helped someone with diodes that check ok on a meter and are actually no good . cant remember ever coming across it myself .
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          And what's even weirder, is the diodes that worked, when I checked them in reverse polarity, the voltage kept climbing on my meter until it said OL ... whereas the bad diodes gave me nothing when I reverse-biased them...
          sigpic
            • 31086
            well i'v seen semiconductors that pass on a meter.
            the meter tests at 1.8v or less with no real current.
            also - fluke - again.
            had a guy yesterday bitching on the fone for advice.
            his fluke287 - soon to be sold now, told him a couple of zener diodes were fine.
            his UT-171 said the same diodes had reverse leakage.
            and they did, diodes were fucked and the 500$ fluke didnt see it!
              • Jul 2011
              • 6041
              That is why you voltage test diodes i do not trust the meter diode testing it does not always tell you the truth about if it good or bad
              I have had this issue my self before
              • CapLeaker
                Leaking Member
                • 8214
                Look at my PS2 power supply repair. Fluke 289 didn’t see the bad cap. Neither did my Fluke 179 and the Agilent DMM. My Agilent ESR meter found it right away.
                At the same time, my fluke meters never failed to identify a bad diode. What gives?
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  Chinese knock-off?
                  sigpic
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    The diodes I took from the doner board didn't last either. I don't have any new surface mount diodes, so I decided to take some 1n4001's that I have that are brand new ... nice and meaty compared to what was on the board ... I just bent the stems and flush soldered them to the board and they are working fine so far.
                    Hopefully, the third time is a charm...
                    sigpic
                    • redwire
                      • 3910
                      In-circuit testing can lead you on a wild goose chase. I don't agree with the conclusions here.
                      Multimeter's diode-test has low test current, AN8008 is 1.7mA at 3.2V
                      If a diode is sort of shorted or in-circuit resistance is around 400 ohms, it will read 0.7V and you think this is OK.
                      In reverse, a slowly climbing reading is a capacitor charging up.
                      We don't know the circuit details, but there is a filter capacitor and perhaps more present.
                      Many times a side-effect of replacing parts is resoldering a bad connection that was the actual root cause of the problem.
                      If a rectifier diode was shorted, it overloads the power transformer and gives AC to the filter capacitor. Usually the transformer's thermal fuse pops.
                      If a rectifier diode was open, you would still get 1/2 wave output, but OP got zero. That would mean two diodes were open which is unlikely.
                      I think the transformer had a bad connection.
                      • caspian
                        What Zener Diodes on a Linear Power Supply
                        by caspian
                        Dear members,
                        I have a linear variable power supply with unknown brand name that I used for voltage injection.
                        Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                        In addition, I discovered that its zener diodes are defective.
                        I can replace the burned transistors.
                        But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                        Therefore, I cannot replace the zener diodes.
                        I do not want to test the zener diodes in a test circuit to discover their model or value.
                        no schematics are available...
                        05-26-2025, 12:38 PM
                        I am looking for a transformer secondary of 60 volts @ 30 amp
                        by sam_sam_sam
                        The primary voltage is 480 single phase the second voltage needed is 60 volts
                        Now it could be 30 volts 0 volts 30 volts preferred
                        Or it could be 60 volts 0 volts 60 volts and just use one side of
                        Output amp need to be at least 30
                        Dose anyone know where I can find one
                        This is what is the device I am working on
                        The problem with this one is that it is over heating and smelling like it is over heating
                        When it has a load on it...
                        07-01-2020, 08:14 PM
                      • ohren
                        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                        by ohren
                        Hello!
                        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                        Measured voltages with no load:
                        After rectifier diodes
                        12V: 6.17 V
                        5V: 5.67 V
                        Secondary transformer pins AC measurement (really don't know if this says anything)
                        12V: 2-2.5 V
                        5V: 1.04 V
                        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                        03-18-2023, 10:33 AM
                      • mikey5791
                        Is it possible for transformer substitution?
                        by mikey5791
                        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                        My questions are
                        1. How do i test to see if the transformer is in good working condition?
                        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                        Hope you guys understand what i was asking. My intention is...
                        11-03-2022, 02:11 AM
                        ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                        This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                        09-06-2024, 04:40 PM
