Troubleshooting Question
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I have this circuit that is powered from AC but on the other side of the transformer, is an old school bridge rectifier. The circuit won't power up, so I took a reading at the low end of the transformer and I got 0 volts
    Then, I removed the diodes and took another reading and I got close to 10 volts. and YES, the meter was on AC setting both times.
    I tested the diodes and all four of them came back at .56 volts from the Fluke meter.
    What could potentially cause this problem?
    sigpic
  • petehall347
    • Jan 2015
    • 4448
    Re: Troubleshooting Question
    try new diodes
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      try new diodes
      Well, I didn't have any like that laying around, but I did have a doner Apple laptop motherboard that had some on it, so I pulled four of them off and soldered them on this circuit, and right away I got 6 volts at the low end of the transformer, so I plugged everything back in and it's working like a champ!
      Thank you.
      sigpic
      • petehall347
        • Jan 2015
        • 4448
        thats twice this week i have helped someone with diodes that check ok on a meter and are actually no good . cant remember ever coming across it myself .
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          And what's even weirder, is the diodes that worked, when I checked them in reverse polarity, the voltage kept climbing on my meter until it said OL ... whereas the bad diodes gave me nothing when I reverse-biased them...
          sigpic
            • 31283
            well i'v seen semiconductors that pass on a meter.
            the meter tests at 1.8v or less with no real current.
            also - fluke - again.
            had a guy yesterday bitching on the fone for advice.
            his fluke287 - soon to be sold now, told him a couple of zener diodes were fine.
            his UT-171 said the same diodes had reverse leakage.
            and they did, diodes were fucked and the 500$ fluke didnt see it!
              • Jul 2011
              • 6070
              That is why you voltage test diodes i do not trust the meter diode testing it does not always tell you the truth about if it good or bad
              I have had this issue my self before
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8351
                Look at my PS2 power supply repair. Fluke 289 didn’t see the bad cap. Neither did my Fluke 179 and the Agilent DMM. My Agilent ESR meter found it right away.
                At the same time, my fluke meters never failed to identify a bad diode. What gives?
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  Chinese knock-off?
                  sigpic
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    The diodes I took from the doner board didn't last either. I don't have any new surface mount diodes, so I decided to take some 1n4001's that I have that are brand new ... nice and meaty compared to what was on the board ... I just bent the stems and flush soldered them to the board and they are working fine so far.
                    Hopefully, the third time is a charm...
                    sigpic
                    • redwire
                      • Dec 2010
                      • 3912
                      In-circuit testing can lead you on a wild goose chase. I don't agree with the conclusions here.
                      Multimeter's diode-test has low test current, AN8008 is 1.7mA at 3.2V
                      If a diode is sort of shorted or in-circuit resistance is around 400 ohms, it will read 0.7V and you think this is OK.
                      In reverse, a slowly climbing reading is a capacitor charging up.
                      We don't know the circuit details, but there is a filter capacitor and perhaps more present.
                      Many times a side-effect of replacing parts is resoldering a bad connection that was the actual root cause of the problem.
                      If a rectifier diode was shorted, it overloads the power transformer and gives AC to the filter capacitor. Usually the transformer's thermal fuse pops.
                      If a rectifier diode was open, you would still get 1/2 wave output, but OP got zero. That would mean two diodes were open which is unlikely.
                      I think the transformer had a bad connection.
                      • Dvsr
                        On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                        by Dvsr
                        Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                        I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                        After replacing the caps I started testing out the speaker. It seemed...
                        09-10-2025, 10:20 AM
                      • caspian
                        What Zener Diodes on a Linear Power Supply
                        by caspian
                        Dear members,
                        I have a linear variable power supply with unknown brand name that I used for voltage injection.
                        Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                        In addition, I discovered that its zener diodes are defective.
                        I can replace the burned transistors.
                        But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                        Therefore, I cannot replace the zener diodes.
                        I do not want to test the zener diodes in a test circuit to discover their model or value.
                        no schematics are available...
                        05-26-2025, 12:38 PM
                      • Mark R
                        The Overseas Only Kenwood Model KR 790
                        by Mark R
                        I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
                        The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
                        09-23-2025, 08:27 PM
                      • u666sa
                        HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                        by u666sa
                        Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                        Platform: ipa32 la-m024p rev 1b
                        Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                        I found a short on the other side:
                        10-04-2025, 05:03 PM
                      • learnmore
                        Help choosing replacement transformer for Levoit 600S SMPS
                        by learnmore
                        Hello Community,
                        I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                        Peace
                        LM...
                        11-04-2025, 09:35 AM
