I need help with designing a 8 channel battery voltage / current datalogger
    • Jul 2011
    • 6057
    I could buy a eight channel battery tester however all grounds are shared
    What I am wanting to do is charger and monitor the voltage / current of at least 4 batteries at a time in series and use a computer for the data-logging
    Does anyone on the forum have any ideas how I could do this
    • 31142
    Re: I need help with designing a 8 channel battery voltage / current datalogger
    voltage is easy, get a microcontroller with enough analog chanels and just tap all the midpoints.
    then use math to seperate the readings.
    so the first cell is direct,
    the second cell you deduct the voltage at the first cell.
    the third cell you deduct the voltage at the second.
    and so-on.
    not sure how you read current without a common rail.
      • Jul 2011
      • 6057
      I want to do this with isolated voltage reading if possible
        • 31142
        why?
          • Jul 2011
          • 6057
          Originally posted by stj
          why?
          Because I want to test BMS balancing protection boards
          Because I want to match battery for the BMS balancing protection board
          Because just how accurate is use a voltage divider are you really measuring the actual voltage is or a rough estimate of voltage
            • Jul 2011
            • 6057
            I still have not found a solution to issue but still looking for one
            Is there a way to monitor the voltage using an optic sensor as isolating barer I am just asking the question if could be done this and if it can how would you do this
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              I just thought of a possible solution but you won't like implementing it if you're not an EE as it has so many pitfalls... (Basically put a multimeter at every battery and read each one on its own) so I think you have to go with stj's method or electromechanical....
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
                NVDC charger configuration...
                11-05-2024, 03:28 PM
                ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                Narrow VDC applications where the system power source is
                either the battery pack or the regulated output of the charger.
                This makes the max voltage to the system equal to the max
                battery voltage instead of the max adapter voltage. Operating
                at lower system voltage can improve...
                11-05-2024, 04:43 PM
                Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                The bq24745 features dynamic power management...
                10-23-2024, 02:50 AM
                How to modify a switching power supply that has voltage/current adjustable but powering it from a battery pack
                I have been pondering this question for a while but now I have see if this doable but I need to answer this question once and for all
                I would like to know how to safely do this undertaking my first thought is to solder wires to the main filtering capacitors and see
                what voltage I am getting and seeing if I can build a battery pack with voltage or not and if
                I can find a BMS balancing protection board at this voltage level and weather or not do I have use more than one BMS balancing protection board...
                05-11-2025, 05:22 PM
