Test power lines with diode mode
  • corrize
    • Apr 2021
    • 303
    • France
    Hello, I have a noob question about troubleshooting (for laptop in my case but, it's could be general).
    I saw someone on video testing power lines witn diode mode. He saw 0.1v on 5v line and said « it's too low », and compared with 3.3v line and find 0.3v (seems OK for him). How did he know it's too low or not pls ?
  • redwire
    • Dec 2010
    • 3912
    Re: Test power lines with diode mode
    Semiconductors have a (IC substrate diode) threshold voltage of about 0.3V-0.7V and using a multimeter on diode-test it will first charge up capacitors and then settle on a voltage reading for that line.
    Anything less than 0.3V is considered a short.
    • corrize
      • Apr 2021
      • 303
      • France
      Thanks, it's clear.
      • Syseng
        Lenovo P14s Gen 5 SVP unlock
        by Syseng
        This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
        The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
        06-22-2025, 07:44 AM
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
        🛠 Original Issue
        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • dj8452000
        How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
        by dj8452000
        I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
        02-18-2025, 08:28 AM
      • jolivares
        NEEDED IPAD7 A2197 DIODE MESURAMENTS VCC_MAIN, VCC_BATT, VDD_BOOST
        by jolivares
        I sent IPAD 7 WIFI-2019, model A2197 to a techincal service, but they did not repair it, so i am trying to fix it. The problem is the IPAD is not booting and no turn on.
        This is what i found until this moment:
        1) with battery connected, the current draw from the power supply is about 450mA from the charging port.
        2) no short circuit in lines VCC_MAIN, VCC_BATT.
        3) with the power supply, or with the battery, the 3.7V of VCC_MAIN and 1V8_ALWAYS are generated without problem.
        4) the current draw from the power supply, without battery, is about 26mA from the charging...
        07-15-2024, 09:24 AM
      • joelz
        pin Setting parameter line or set lines menu for adding ITE5571e on RT809F programmer
        by joelz
        Hi, sorry if i here to request if anyone know number of pin to set lines for reading ITE7751e on RT809F..i try to see on schematic but i dont know how to choose it..pleasee..
        11-18-2024, 06:02 AM
