please tell me what i need to read one of these in the photo and write to a new one ? i would of course prefer to be reading one still on the board .
mcu reading and writing .
Tags: None
Re: mcu reading and writing .
It seems to be an obsolete Renesas RL78-core MCU R5F10268 8KB FLASH. It looks like a chinese make of the IC by Shenzhen Zhouhengli Technology Co.
I see 5V serial-data pad on the PCB which would be used for programming/debug. You'd have to read the MCU programming datasheet to see if reading out the program is possible at all, there can be a code protect bit set to prevent this.
And we have no idea if the original bootloader is still there, it can be over-ridden to free up more memory. -
its in a greenworks 82v battery pack .i have access to working ones ,,this one decided to short at 1.6 ohms between vss and vdd .. think it was maybe ok before i soldered a wire back to a cell in the pack that was broken .
charger reported faulty pack . a jump start normally works but someone had been inside before me .Comment
is there any chance it will write itself like car ecu.s can ? i know it talks to the charger if that means anything. i am having to learn about these things to feed myself .
thinking about it though i guess the charger just switches it on ..Last edited by petehall347; 05-21-2021, 05:15 PM.Comment
doubt it... it would probably need to expose more contacts to the charger to write when there may not be a need to....
Hate it when I work on something that someone else had worked on before...mostly if they made it worse...Comment
what is the best lower price tool i need to at least try and read a good one of these chips and write to a new one ?Comment
specialist shit like that, your best bet is scouring the net for a homebrew solution like an arduino
otherwise only manufacturer tools or very expensive universal programmers are likely to handle it.
start with a datasheet.Comment
been looking at the datasheet and cant see anything about read protect . but i did skip through it . https://cdn.badcaps-static.com/pdfs/...d62d2399f6.pdf
having something that will at least be capable to read it is needed the most .Last edited by petehall347; 05-24-2021, 04:26 PM.Comment
having something that will at least be capable to read it is needed the most .Comment
the suggested interface is a bit expensive at £750, maybe the chinese have a copy one . or does it really need a remesas one ?Comment
from what i read last night it appears it can be read if not being written to at the same time . its uses uart by the looks of it .also there appears to be a debug and admin mode maybe i should email renesas to ask them to clarify things .
suppose i could throw the battery pack into the spares box and forget it for now . i guess i will be seeing more and more of these things to repair .Comment
programmingComment
maybe i should be researching open source programs that will work with this bms pcb .Comment
From what I take from the datasheet, if the code on the chip does not provide a read API, then you can't read it directly. You can indirectly read it however, but it's the equivalent of hacking passwords bruteforce and this probably would take years to complete...Comment
not sure if these can help me but looks interesting . https://foxbms.org/Comment
reverse engineering is what's needed as far as i can see .. its fairly easy to work out what's expected from the program but my limited knowledge with programming is holding me back ..i could learn how to do it but i don't want to tax my brain doing so . this battery charging and monitoring must be pretty much the same for all similar battery packs .Comment
You can read out a bootloader in many cases, but often not the main code. You upload the new program, the program reads the bootloader and copies it to a section of memory that you can read or dumps via serial port.Comment
by ahmedtouHi everyone,
help me please
I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
I will share all the details with you, including the disc information.
Code:HL-DT-ST BD-RE GGW-H20N XA02 (ATA) Current Profile: BD-R Disc Information: Status: Empty State of Last Session: Empty Erasable: No Free Sectors: 12,219,392 Free Space: 25,025,314,816 bytes Free Time: 2715:27:17 (MM:SS:FF) Next
by JoWedHello Community,
I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...-
Channel: BIOS Requests ONLY!
by testaccgtaHi, everyone!
I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...-
by petehall347brain dead garden tractor ,, pic16f871-i/l mcu and plug in too ..
anyway here goes .tried mcu from different revision board and its gives a strange readout on the led thingies . so will have to wait till one comes in thats same revision .
what i want to know if someone has the kit and knows how to do it will do it for me ?
in case you wondering its from a c series countax ride on mower .. -
by hasel17So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
Code:Checking for blank... (Press
- Loading...
