need mcu reading/writing
  • petehall347
    • Jan 2015
    • 4427
    brain dead garden tractor ,, pic16f871-i/l mcu and plug in too ..
    anyway here goes .tried mcu from different revision board and its gives a strange readout on the led thingies . so will have to wait till one comes in thats same revision .
    what i want to know if someone has the kit and knows how to do it will do it for me ?
    in case you wondering its from a c series countax ride on mower ..
    • 31087
    Re: need mcu reading/writing
    well a programmer is cheap, £10-40.
    dont you have a tl866 or similar?
    but the chips are probably protected from being read out.
    • petehall347
      • Jan 2015
      • 4427
      yes i did wonder about the read protect . programming isnt in my job description . i did read the data sheet and it spun me out .
      it is rather annoying when i am asked to see if i can fix these things and its a software issue that is holding me back . got me thinking that i need a programmer to write a program that does what it should it do . not much involved really . its just an hours counter and rpm monitor and other stuff like service due and maybe deck height . shit like this is second nature for some folk but not me . it could be but no way am i going there . i could thinking about it redisgn it a little bit and do away with the digital display like they used to be . cutting grass is getting far too complex for my liking .
      • keepread
        SPD reading/writing under Linux and/or Windows
        by keepread
        Where can I find the mysterious 'eeprom' kernel module that some use under Linux to read/write SPD?
        I installed 'i2c-tools' and got 'decode-dimms' tool under Debian but not under Fedora, but both of them are missing the 'eeprom' module.
        Also tried the SPD.exe tool from EVGA, which correctly lists all of the DIMM slots but reads zeroes from all of them.
        Basically I need to dump SPD from some modules that were sold to me as DDR-1866 but are made of DDR-1600 chips, and they do not work. There is no access to RAM clock rate in the BIOS, so I am SOL unless I can rebin...
        01-20-2025, 08:07 AM
      • petehall347
        mcu reading and writing .
        by petehall347
        please tell me what i need to read one of these in the photo and write to a new one ? i would of course prefer to be reading one still on the board ....
        05-21-2021, 03:14 PM
      • Carlos#2003%
        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
        by Carlos#2003%
        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
        02-15-2024, 07:52 PM
      • pippo-pitbull
        XGecu TL866II Plus not reading and not writing
        by pippo-pitbull
        I bought a TL866II Plus eeprom programmer, I tried to read an Eeprom 24lc64 ( MANUFACTURING MICROCHIP ) the software Xgpro v11.50 don't show me any error in the read but the file read is empty.
        I tried to program and I receive an error. I tried with a different chip but I had the same result. Anyone can give me help please?...
        10-26-2021, 07:52 PM
      • SuperAman
        PS5 HDMI port diode reading?
        by SuperAman
        I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
        02-03-2024, 10:16 PM
