Cleaning Off Blu Tac
  • Ritchie_Uk
    Prawnography
    • Mar 2021
    • 185
    • Uk
    Hi there
    Just a Tip..
    I had a Logitech Webcam that had rubber feet, which was on top of my monitor.
    It made such a mess on the base of the Camera, but I found that WD-40 cleaned it spotlessly.
    Thanks me later
    • Jul 2011
    • 6057
    Re: Cleaning Off Blu Tac
    Be careful when using WD40 on plastic it can cloud the clear plastic
      • 31157
      and it can de-laminate pcb's and make all the tracks peel off!!!
      • Ritchie_Uk
        Prawnography
        • Mar 2021
        • 185
        • Uk
        Thankyou, Sam, I didnt know that
        • Ritchie_Uk
          Prawnography
          • Mar 2021
          • 185
          • Uk
          Ohh..
          Thankyou stj
            • Jul 2011
            • 6057
            You can sometimes use brake cleaner to remove glue but spray on the paper towel and wipe but if it is clear plastic it can also cloud the clear plastic test a small spot first
            You can sometimes use “ Goo Goo Glue and Tape Adhesive Remover ” but some time it might make the plastic tack-e to touch if you do not use enough of a few times but test it on clear plastic first to see if it makes it cloudy looking
            • redwire
              • Dec 2010
              • 3912
              WD-40 is 50% Kerosene aka jet fuel and mostly solvent Naphthalene aka lighter fluid, with a teeny tiny bit of mineral oil.
              Brakleen is 50% acetone, the rest naptha and toluene.
              Plastic chemical compatibility chart
              • Ritchie_Uk
                Prawnography
                • Mar 2021
                • 185
                • Uk
                Thankyou Sam - Is Brake cleaner safe in plastic?
                I need to find something that cleans those double sided sponge things that almost weld to plastic
                • Ritchie_Uk
                  Prawnography
                  • Mar 2021
                  • 185
                  • Uk
                  Hi Redwire - Has the WD-40 secret been leaked?
                  Excuse the pun.
                  I love WD-40 it has so many uses
                    • 31157
                    for removing sticker glue i use white spirit - very cheap at toolstation
                    but test it on a hidden area first - it can fog some plastics and make pressed cd's explode!!!
                    • redwire
                      • Dec 2010
                      • 3912
                      You can see the chemical ingredients listed on the MSDS.
                      The worst mistake with WD-40 is thinking it's useful as a lubricant - it all evaporates fast.
                      • Ritchie_Uk
                        Prawnography
                        • Mar 2021
                        • 185
                        • Uk
                        Would anyone ever use WD-40 as a a switch cleaner?
                        I used to use Electrolube in the old days to clean Volume pots on TV's
                          • 31157
                          WD40 is only good for spraying on rusted bolts outdoors.
                          and even that is probably not as good as 50/50 acetone and ATF fluid.
                          • Ritchie_Uk
                            Prawnography
                            • Mar 2021
                            • 185
                            • Uk
                            Thankyou stj
                              LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
                              This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                              09-12-2024, 01:58 PM
                            • rumi409
                              LG OLED C1 Pixel Cleaning Made Picture Worse
                              by rumi409
                              ​​​​​​ Hi,
                              I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
                              11-15-2024, 01:09 AM
                            • Widget
                              Logitech R20 speakers - Replacing one of the speakers.
                              by Widget
                              Hi guys,
                              I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
                              Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
                              Printed on the back of the Logitech speaker is;
                              LOGITECH...
                              05-29-2024, 07:07 AM
                            • dreamlayers
                              Weird clipping on Logitech Z-10 speakers
                              by dreamlayers
                              I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                              05-22-2025, 11:41 AM
                            • howardc64
                              Macbook Dust-Gate Preventive Cleaning
                              by howardc64
                              Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
                              Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
                              https://www.ifixit.com/Guide/MacBook...leaning/177920
                              10-09-2024, 10:10 AM
