8 pin ic ATH75202CMCN1752GKW Any ideas Please?
  • Ritchie_Uk
    Prawnography
    • Mar 2021
    • 185
    • Uk
    Hi there
    Does anybody recognise what this IC is or it's functionality please?
    I have searched everywhere, and can't make out the Logo manufacturer.
    On the other side of the PCB is, what seems to be a 9 Pin serial D-Type Male connector.
    It seems like a Dongle
    Stay Safe
    • Jul 2011
    • 6040
    Re: Any ideas Please?
    Originally posted by Ritchie_Uk
    Hi there
    Does anybody recognise what this IC is or it’s functionality please?
    I have searched everywhere, and can’t make out the Logo manufacturer.
    Stay Safe
    https://cdn.badcaps-static.com/pdfs/...389c9500e9.pdf
    https://www.szgolon.com/search/xq?id=515510
    This what I have found it might not be correct
    • Ritchie_Uk
      Prawnography
      • Mar 2021
      • 185
      • Uk
      Sam_Sam_Sam Thankyou
      That really helps, let me look and read the Datasheet you sent me and keep you updated.
      Ritchie
      • Ritchie_Uk
        Prawnography
        • Mar 2021
        • 185
        • Uk
        Sam_Sam_Sam
        That could make sense as the IC could be a Programmable one, which means I will try and put it on the new EEPROM blower and see if it recognises it, and also download any info on the Chip?
          • 31043
          what is it from/for??
          • Ritchie_Uk
            Prawnography
            • Mar 2021
            • 185
            • Uk
            Hi stj - It’s a Dongle that I know little to nothing about and asked if I can find any info about it.
            It seems like there is no info or datasheets available, except the lead sam_sam_sam posted
            • Ritchie_Uk
              Prawnography
              • Mar 2021
              • 185
              • Uk
              Does the Manufacturers Logo look familiar at all?
                • 31043
                well if it's a security device then obviously is a microcontroller of some type with either a lookup table or an algorythm in it for processing the data.
                if you have the plastic shell with the name on then finding info to hack it would be possible
                • Ritchie_Uk
                  Prawnography
                  • Mar 2021
                  • 185
                  • Uk
                  Hi stj - I will email a few companies to see if they can recognise and supply 1.
                  I have since found that it’s a dongle for a cd cleaning machine, so I will try and download the code and see if I can disassemble it, and compare with a new untouched ones code.
                  It’s worth a shot
                  • Ritchie_Uk
                    Prawnography
                    • Mar 2021
                    • 185
                    • Uk
                    I Will try and find what machine it could be for
                      • 31043
                      it's probably simpler to get a dump of the harddrive and hack out the checks
                      • Ritchie_Uk
                        Prawnography
                        • Mar 2021
                        • 185
                        • Uk
                        stj - th emost Obvious idea I have overlooked.
                        To simply connect the IC to my EEPROM blower and see what it recognises.
                        Would the Code be Encyrypted?
                        In the old days Games could be hacked with the DOS "Debug" command, and Softice
                        • Ritchie_Uk
                          Prawnography
                          • Mar 2021
                          • 185
                          • Uk
                          As an Update one company has got back to me as stated that the AT at the front could mean it is "ATMEL"
                          • R_J
                            • 9547
                            It appears to be an ATMEL AT24C02C
                              • 31043
                              but a serial port runs at +-12v
                              you would blow the atmel to bits unless the fact that it's a 9way D is just coincidence.
                              we need to see the rest of the hardware.
                              • Ritchie_Uk
                                Prawnography
                                • Mar 2021
                                • 185
                                • Uk
                                R_J Thankyou
                                How did you find that?
                                • Ritchie_Uk
                                  Prawnography
                                  • Mar 2021
                                  • 185
                                  • Uk
                                  Hey stj Ok, thanks for that.
                                  Would you recommend anyway of reading it please?
                                  I still have some RS232 cables, and a serial card/pc
                                    • 31043
                                    unless you can look at what it plugs into then forget it.
                                    and your not going to read a secure device.
                                    software hack is the optimal aproach
                                    • Ritchie_Uk
                                      Prawnography
                                      • Mar 2021
                                      • 185
                                      • Uk
                                      Hi stj, Thankyou I will try and find more info.
                                      • R_J
                                        • 9547
                                        R_J Thankyou
                                        I'm going by the datasheet, Page 13
