G502 lightspeed not working except for battery lights
  • omeggga
    • Mar 2025
    • Spain
    Good morning, I signed up for this forum because I need help fixing my LogitechG502 Lightspeed.
    So I got a cheap used G502 under the pretense that the USB was busted and while it would charge, on wired mode it would not work, windows would not recognize it, or even give the little jingle when plugged in... but it would charge.
    So I think "ok challenge accepted, it's probably that the data bus on the usb is busted. I solder in a new one and I get a cheap wireless G502 that I've been wanting for years!"
    Nope, wireless doesn't work either, G-hub detects the dongle but that's it, It turns on but it doesn't pair with the dongle, it's like the firmware is stuck in some weird infinite loop. The battery indicators are always on and the Logitech logo light is always off. Switching it on and off does almost nothing as well, all it achieves is flickering off the battery indicators for a split second before they turn right back on. If I do it quick enough then maybe the logitech logo light will flicker on for just a nanosecond.
    I opened up the device to see if I could figure out what I'm dealing with, here are pictures:
    So yeah, and since it's second hand I doubt Logitech is gonna let me RMA this. Any ideas?
    The button daughterboards seem fine btw.
  • omeggga
    • Mar 2025
    • Spain
    I fixed the mouse by removing the soder on the test pads
    :Click image for larger version
      LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
      This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
      09-12-2024, 01:58 PM
    • Widget
      Logitech R20 speakers - Replacing one of the speakers.
      by Widget
      Hi guys,
      I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
      Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
      Printed on the back of the Logitech speaker is;
      LOGITECH...
      05-29-2024, 07:07 AM
    • koriwi
      P14s Gen 2 AMD; no boot, no image, no backlight, no charge
      by koriwi
      Hi guys, I am new here, but I've tried my best to read up on the beginner guides and reading some other threads. So here the base information i can provide.
      -Lenovo P14s Gen 2 AMD
      -Ryzen 7 5850u
      -16GB soldered (32GB stick added, removed for debugging)
      -256GB SKHynix SSD (removed and swapped for debugging)
      -NM-D451 Motherboard (P/N: 5B21C82277)
      -S/N: PF-34N64A
      -Model: 21A0-000QGE
      History and symptoms:
      I had this Laptop for some time but stopped using it (installed Linux, worked perfectly) as I changed company and got a MacBook...
      03-08-2025, 05:22 PM
    • Francesc V.
      Christmas lights - Something I am doing wrong
      by Francesc V.
      Hi:
      i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
      I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
      If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
      Could...
      03-11-2023, 07:38 AM
    • dreamlayers
      Weird clipping on Logitech Z-10 speakers
      by dreamlayers
      I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
      05-22-2025, 11:41 AM
