Turtle beach 600 dongle
  • Paba
    • Mar 2024
    • 7
    • United Kingdom
    Hi there.
    Got dongle with water damage. All corrosion cleaned and broken traces repaired. But I have 3 missing components marked as "PB" it looks like diode but don't know how to find a proper replacement. Please help and thanks in advance
  • chickenhawk88
    • May 2024
    • 86
    • US
    This might be a possible one, ask the guys at digikey for verification, also take a better picture of it in circuit could help.
    • chickenhawk88
      • May 2024
      • 86
      • US
      Here is another possible one but I'm leaning towards the first one.
      https://www.mouser.com/ProductDetail...uctor/KDZTR68B
      • ImpossibleRepairs
        Turtle Beach Velocity one flight universal control system
        by ImpossibleRepairs
        Hi Good peoples;
        Been working on a turtle beach Velocity one flight controller; The slide pot for the throttle (black) isn't calibrating properly, it will register the axis with some wriggle until pressure is released;
        Does anyone know the specifics for these Potentiometers?? I have attached photos;
        Board number is LBX-19500,
        C-V1.1 202011
        please and thanks as always...
        05-07-2024, 02:19 AM
      • jeremy96
        PS4 Power Button Traces
        by jeremy96
        I recently bought a used PS4 and discovered that the power button is broken. Upon closer inspection, I found that the traces for the power button on the PCB are damaged and torn.
        Does anyone know where these traces lead or have any advice on how to repair them?
        Thanks in advance for your help!​...
        05-26-2024, 05:01 AM
      • B2L_Repairs
        Huawei D15 no power found corrosion damage
        by B2L_Repairs
        I got a huawei D15 that came in for no power repair. Device charges , charging led flashedms but doesn't turn on. I found corrosion on an IC (ic name is BDJCY1...I can't find out much info about it online). I removed this ic and two pads are corroded but they can be repaired. To my knowledge inductors never short to ground (i might be wrong and please those that are more knowledgeable than me can correct me). I found few inductors short to ground when my multimeter is in beep mode ,indicating a short in the line of those inductors...but I don't know how to go about to find the shorted component...
        02-06-2025, 01:05 PM
      • Comp_Pro
        A2159 Macbook Pro 820-01598 stuck on 5V
        by Comp_Pro
        This is a mid 2019 Macbook Pro touchbar model. Motherboard is 820-01598. Technical information is going to be attached below including power sequencing graph.
        I am having the issue of no 20V on the USB C port. USB-C Stays at 5V permanently. Current draw is 130mA. If I connect and disconnect in a certain way I can sometimes obtain a 300mA draw.
        This laptop came in for water damage and although there was some corrosion it was not very bad. The board was ultrasonic cleaned but is not powering on. Laptop was having 20V prior to cleaning but there was no signs of charge...
        03-02-2021, 02:51 PM
      • philtvman
        Turtle Beach 420X Blown Ferrite Bead
        by philtvman
        Working on this pair of headphones that will not stay powered on.
        A ferrite bead inside looks like it's fried and will need to be replaced (who knows if that's all that's bad). My question is, is there any safe assumption for a replacement? I don't think there are schematics for the board anywhere online unfortunately, so I have no idea the exact specs of it.
        Any advice would be much appreciated....
        01-22-2020, 12:31 PM
