DDR2 resistor packs... 0804?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Are those typical resistor packs on DDR2 modules 0804 (2010 metric?) 22Ω x 4?
    Wondering what I need to buy if I can't find a sacrificial board with one... which will be annoying if I only need one, just like buying 1 resistor, except I'd be buying 4...
    • 31137
    Re: DDR2 resistor packs... 0804?
    buying 4??
    you'l be lucky - last time i needed arrays like that i had to buy a bag of 100
    • mon2
      • 14499
      https://www.arrow.com/en/products/tc...C124-JR-0722RL
      We currently have free shipping with Arrow - if interested, send us a PM and can have them drop shipped to you for free. They are not that expensive.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        I'm not that used to working with SMT, hoping that device really is 0804?
        Was looking on my other devices and couldn't find a matching device, would be very sad if I ordered a device and it wasn't the right size...
        Oh, and yeah since these packages hold 4 resistors a piece...so can you just order 25 to hit 100?
        And thanks for the offer mon2, but I have some other stuff I'd like to order so might end up adding it to my other "wishlist" to soften the shipping shock. Yeah this does suck. Hate SMD, mainly because I don't have a stockpile of replacement parts...
        • Lisa Su
          Badcaps
          • Apr 2021
          • 213
          • Taiwan
          Just double checked here. Think you're right!
          https://i.imgur.com/G049R52.png
          https://i.imgur.com/7fXgewT.png
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Oh nice, BOM!
            Thanks, yeah looks like 0804's so if it comes down to ordering from mouser or something, that's what I'll need to order. Else I may just swipe one from that dead PC3200 512M...
            • petehall347
              • Jan 2015
              • 4429
              i always check with calipers for sizes
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Yeah with so little room for error i worry about precision of my calipers and especially the lead-to-lead dimension where solder might affect the measurement.
                And then the conversion from imperial to metric and back when needed... I'm always worried about my imperial-only calipers...
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  by mikey5791
                  Hi to all forum members,
                  12-26-2024, 04:55 AM
                • MidnightRoller
                  Can a resistor lose resistance after hot air?
                  by MidnightRoller
                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                  02-02-2022, 11:46 PM
                • artvandalai
                  What resistor ohm will work better to repair this waterpik?
                  by artvandalai
                  The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                  01-05-2025, 04:10 PM
                • chth96
                  Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                  by chth96
                  I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                  Since then, This AC/DC adaptor have been out of order.
                  But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                  After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                  And Is there any possibility that it will suddenly explode as well as to be out...
                  12-03-2023, 04:40 AM
