Swapping out a NiMh for a LiPo?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Re: Swapping out a NiMh for a LiPo?
    Originally posted by eccerr0r
    What the... didn't even see you used a i2c rtc in the design... I would have just did the RTC in software and omitted a chip since it doesn't even need to be that accurate.
    So when the power goes out and your software RTC doesn't know what time it is when the power comes back on ... then what?
    Other thing is that I probably would have added an LED that blinks while it's self-testing. Then the user wouldn't wonder why the light was on unexpectedly...
    The light has an LED that indicates when it's getting power from main ... so when the lights are on and that LED is off ... yet their TV is still on ... probably a good indication that we're refreshing the battery ....
    sigpic
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8694
      A, isn't that what the battery is for? You have two batteries after all!
      and B, does it really matter?
      As long as it's clear, but this does not seem very clear. Then again for personal use it doesn't matter though.
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        I was talking about YOUR design where you said you would have skipped the RTC chip and just implemented the RTC in software ... you usually can't battery back the microcontroller, but the RTC chips are designed for that.
        And NO, I only have ONE battery.
        And YES, it does matter, because I want the circuit to discharge the battery when the day starts so that it can discharge, then charge and be ready to go by sundown ... as opposed to the unit discharging the battery at 6 pm then when the power goes out at midnight, I have no lights because my SOFTWARE RTC forgot what friggin time it was when the power went out...
        Why in the world would you invest all that time writing a software RTC when you get the chips for a couple of bucks?
        sigpic
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8694
          You have two batteries: the CR2032 and ... the Li-ion pack!
          Up to you. Your money. Could have made the board smaller, less components, and thus cheaper... BTW yes this is depending on a low power microcontroller like the atmels, attiny, etc.
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            There is no "LiIon Pack" The light itself is runs from a NiMh pack when AC is removed from the light ... maybe this will help ...
            sigpic
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8694
              "wonderful" design...
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                It works
                sigpic
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8694
                  and it still needs an external device to set the time...
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    Are you intentionally being obtuse?
                    sigpic
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8694
                      Are you intentionally thinking your design is the world's next unicorn product?
                      BTW this topic has gone off topic...where's the LiPo... I think we're done.
                        • Jul 2011
                        • 6031
                        You do not need a time keeping chip if you just a photo cell and if there is daylight then do it program and when dark then a different part of the program it does not have to difficult to unless you want to do something different
                        • brethin
                          • Dec 2008
                          • 1907
                          He never does things the simple way
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            My design refreshes the battery exactly once every six weeks. Power interruptions will not change the schedule, and the location of this light is in a hallway where it's fairly dark all the time ... but I wouldn't even consider doing this without an RTC chip ... I don't see what the big deal is ... trying to do something with accuracy and reliability ...
                            As far as cost goes, this was a personal project ... I'm not trying to market the thing .. I had fun doing it, so the cost was irrelevant.
                            sigpic
                            • Tarot Superstars
                              Short Circuit tester
                              by Tarot Superstars
                              Hello.
                              I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                              The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                              Link
                              The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                              https://www.youtube.com/watch?v=0eixDdCpiO4
                              My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                              09-25-2023, 09:11 AM
                            • M1NEBLANK SHOW
                              MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                              by M1NEBLANK SHOW
                              Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                              (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                              Schematic and Boardview here
                              04-04-2025, 03:57 PM
                            • прямо
                              Viper22A 5VSB circuit
                              by прямо
                              So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                              In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                              01-13-2024, 07:05 PM
                            • chth96
                              Is ESR value different between on Circuit and off Circuit?
                              by chth96
                              A few days ago, I purchased MESR-100 ESR meter, and When I measured a SMD capacitor on circuit,MESR-100 showed ESR value of 30, But I managed to desolder this SMD capacitor from circuit and measured it then MESR-100 showed ESR value of 18.
                              I also measured it with Mega328 Transistor Tester, and It showed ESR value of 17.
                              Is my MESR-100 defective, if the ESR value is different between on Circuit and off Circuit?
                              11-19-2022, 04:32 AM
                            • vrasp
                              Issues in PWM circuit with LC filter to drive Peltier
                              by vrasp
                              I've been trying to build a Peltier circuit that I can control with arduino and create cooling ramps. I've never built a circuit before and only have a basic knowledge of electronics.
                              I've been researching how to do this and attempted to build it. My circuit is basically a PWM signal sent to a motor driver with an LC filter to smoothen the signal. Since very low temperatures are required, I added another Peltier on top of the first one. The top Peltier needs to be driven at a lower voltage to limit the amount of heat produced and effectively lower the temperature....
                              10-27-2022, 08:11 PM
