Swapping out a NiMh for a LiPo?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Swapping out a NiMh for a LiPo?
    Not sure if I myself is actually using it in public is a problem, unless someone thinks I might be a target, but wouldn't it have already done what it was going to do?
    Now, leaving it out for someone else to use, however, ...
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Originally posted by eccerr0r
      Paper clips, shoe string, and of course, duct tape!
      (though a 3d printer might be involved...)
      Now THAT would be interesting to see!
      I'm currently in 3D printer hell ... I decided to try using ABS and after doing a lot of reading up on how to print with ABS, It seems that keeping the print warm while it's printing is the big deal with ABS. I don't have a heated print bed on this printer, so I decided to make a little modification...
      I had already modified the printer with a 12 vold regulator that I placed inline with the extruder fans power source, because the fan was way too loud and I discovered it was being fed 19 volts, so I cut it down to 12 and have been running it like that for the last almost two years without any issue.
      Well ... in order to keep the ABS print warm while printing and since I don't have a heated bed, I decided to step up my fan mod a notch. I implemented an LM317 with a POT for R2 so that I could turn the fan way down so that it doesn't cool the print while it's printing. Well, I turned the fan off completely and started a small 45 minute print with a new spool of ABS... and I watched the first couple of layers go down and they were fine so I walked away until the job was done and when I came back, the first few layers were still there ... but nothing else.
      The ABS had snapped above the extruder feed hole and I couldn't clear it out ... so I had to take the whole assembly apart and what I discovered wasn't pretty...
      I THOUGHT that what I was looking at was the melting of the housing assembly itself with the abs feed stuck in the middle of the melted plastic ... but looking closer, I realized that I was looking at the ABS itself. It had pooled up just above the heat blocks heat sync in a perfect circle. With some pliers, I was able to break it loose ...
      What I thought was really weird about this, is that the fan blows air just under the extruder nozzle which is nowhere near the heat sync for the heater block ... but somehow, obviously, it keeps that heat sync cool enough so that it won't melt material above it ... lol
      I also noticed that the wires coming from the thermocouple had somehow broken off mid-way to the circuit board. So I ordered a new one. I also tested the heater element with a power supply and it's heating just fine, so I think once I get the new thermocouple I'll be back in business with this printer.
      However, I ordered a new printer that has a larger build plate - heated of course and I'll just use it to do my ABS printing. This Flashforge Finder is a great printer, but its build surface has been too small for many projects and I don't think it's very good for ABS.
      sigpic
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        BTW I charged it with the original charger meant for NiCd up to about 4V and stopped, it charged!
        Now THAT's interesting ... Though I guess that makes sense since the charger is only going to feed it current until the voltage reaches the level it expects. possibly with some heat detection as well as is common with NiMh battery chargers. I always thought it was kinda funny that a charger would be configured to give enough current to a battery that it became common practice to include a heat sensor to cut back on the current feed if the battery gets too warm ... but I guess it's fine since that's how it seems to be done in almost all NiMh chargers.
        sigpic
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          Originally posted by sofTest
          The duty cycle for an emergency light is way different from a cordless phone. Typically there are three discharges these batteries experience; self discharge, testing and loss of mains power.
          How often you discharge/test the emergency lights, should be set by assessing the consequences of a fixture failure between the tests (risk management), not to optimize battery life. Typically somewhere between quarterly and monthly is normal.
          The code here is that emergency lights shall be connected to the local general light circuit, so a loss of power to general lighting, the emergency lights switches to battery power. As you said, if connected directly to the same general light circuit, it would be somewhat cumbersome to test them. Some type of fixtures are easy to unhook from the socket so one can just unhook and lay them to the side and time them. As stj says, if planned before install, it is better to branch of a separate cable from the general lighting where one could install a test switch (not generally available), and perhaps use a relay for a little more elegant design. Otherwise, as you says, you would be relegated to trip the fuse. Some types of fixtures are self testing; they run down their batteries once a month, and flashes a diode if there is a failure.
          The three last complete building emergency light refits I've managed, we installed automatic central monitoring and testing. The local building technician will get a warning with a fixture address after each test if a fixture fail, without running around in the building. His job besides this, would be to check the fixtures for if anybody has physically damaged them.
          I already designed a little project using an ATTiny 85 (since I have 10 of them), a 5 volt activated solid-state relay, and an RTC with an I2C interface. I'll have it discharge the batteries by cutting the main AC power to the circuit at 12:00 noon either once a month or once a quarter, I'm not sure yet... but in order to not cut power to the Arduino circuit itself, I'm going to use this 120V ac to 5 volt DC buck converter so that the Arduino doesn't kill itself when it cuts power to the main circuit.
          And instead of hassling the part of trying to figure out if the battery has fully drained or not, I'm just going to leave it disconnected for 4 or 5 hours because at least I know they will be drained by that time. And by choosing to cut power at 12 noon, I know I won't be killing the battery when it's dark outside.
          sigpic
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3264
            • Singapore
            #45
            just one issue with that... if u cut power at noon, by the time u leave it aside and disconnected for 4-5 hours like u said, its going to be 4-5pm already then. in winter, its already dark by that time. how are u going to charge the battery fully then before it gets dark? the math and practicality of that doesnt seem to sound right or work out right to me...
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              I could change the time to 8 am... I mean ... it's not like this is an industrial application. I've got the light installed in the hallway next to the smoke alarm. Sure came in handy twice this week so far ... for some reason, Edison can't seem to keep the power on in this neck of the woods ... guess we're the red-headed stepchildren of the grid out here.
              sigpic
                • 31196
                have you seen the conversion kits?
                20w DC invertors
                https://www.tlc-direct.co.uk/Main_In...its/index.html
                  • Jul 2011
                  • 6064
                  Why put a photo diode and write the program that while the sun is out playing you are charging the battery and then while the sun is not out playing it stops charging this does two things one you do not have to set a time clock and when the season change you do not have to rest the time clock
                  I use to have this setup on my pool pump timer and it worked very well
                    • 31196
                    why do you need a photodiode when you can just monitor the solar cell output?
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      20w DC invertors
                      OK, that's pretty awesome! It looks like a beefy battery too ... one thing though, it says that it will not work on units that have resistive drivers. How do I find out if mine has that? And what is it?
                      sigpic
                        • 31196
                        go watch big clive.
                        switching psu will run off dc because it starts with a rectifier,
                        capacitive dropper needs ac.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Damn. Was hoping to be pleasantly surprised, but a diode dropper shunt amplifier was insufficient to prevent overcharge.
                          Guess I'll need to locate custom zeners, or tune a TL431...
                            • Jul 2011
                            • 6064
                            If you tune TL431 please post your results
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              I'll need to see if I have one somewhere...ugh...
                              ... and nope, dont think this open loop common emitter shunt regulator is accurate enough... need to have full control loop
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                An update on this thread ...
                                One of the circuit boards I ordered recently was the one to do this project... Though I screwed up on the schematic and cross-connected the input to the relay so I had to cut traces and jumper across to make it right.
                                Also, R5 ended up not being needed at all ... it was choking the voltage at the relay input and I learned a very important lesson in this venture ... SURFACE MOUNT COMPONENTS CAN REALLY SUCK SOMETIMES!
                                C1 is so friggin tiny, that I can't even pick it up with my fingers ... I must have lost 10 of them just trying to get one on the board ... I ended up just using the oven with some solder paste which actually worked out well.
                                Here are some pics ...
                                And this is the re-design ... got rid of that damn microcap and put a real cap in there ... fixed the leads to the relay, fattened up the traces a bit ... dumped R5 and its cap and bigger resistors cause they're easier to work with also added the ability to connect to serial on the ATTINY ...
                                OH, and those connector blocks ... are REALLY REALLY NICE ... they have some kind of mechanism in them so that when you pull on the wire, it somehow gets tighter ... I tried with all my might to rip the wire out once it was latched in there and it wasn't budging AT ALL. I have so many of them because of the required minimums but I think I had to purchase 50 of them at like 2 cents each or something ridiculous like that .... if anyone is interested in trying them, PM me your mailing address, and I'll send you a few ... they're pretty slick.
                                sigpic
                                  • 31196
                                  you used an smd electrolytic - you terrorist!!!!
                                    • Jul 2011
                                    • 6064
                                    One comment I have is that what I have read about doing circuit traces is that should have rounded curves and not square edges that come to a point
                                    For the life of I can not remember the exact reason for this is
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5037
                                      • New Zealand
                                      #58
                                      Sharp inner corners (45 degrees and below) can create an "acid trap" that could cause undercutting of the trace during etching.
                                      Also, sharp angles are no good for high frequency signals, so traces that must carry them are usually curved around corners instead of angled.
                                      -David VanHorn
                                      • EasyGoing1
                                        Shock Therapist
                                        • Sep 2016
                                        • 977
                                        Not in version 2.0!
                                        sigpic
                                        • EasyGoing1
                                          Shock Therapist
                                          • Sep 2016
                                          • 977
                                          Yes, I've seen that stated before too ... but until someone can tell me WHY this should be the case ... then I call bullshit on it.
                                          Certainly, in high-frequency circuits, trace layout could mean the difference between success and failure... but in raw DC switching applications? BAH!
                                          sigpic
                                          • Tarot Superstars
                                            Short Circuit tester
                                            by Tarot Superstars
                                            Hello.
                                            I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                                            The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                                            Link
                                            The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                                            https://www.youtube.com/watch?v=0eixDdCpiO4
                                            My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                                            09-25-2023, 09:11 AM
                                          • Alimash
                                            op amp circuit function?
                                            by Alimash
                                            I am repairing a ups which doesn't turn on ,it has the following ICs:
                                            SG3525 used to drive inverter mosfets.
                                            couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                            A LM358 and TL074 for control mechanism and of course the uController.
                                            The SG3525 is shutting down every time the ups is turned on.
                                            I want your help to know the function of LM358 and TL074 in the system.
                                            I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                            07-31-2025, 07:45 AM
                                          • M1NEBLANK SHOW
                                            MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                                            by M1NEBLANK SHOW
                                            Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                                            (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                                            Schematic and Boardview here
                                            04-04-2025, 03:57 PM
                                          • прямо
                                            Viper22A 5VSB circuit
                                            by прямо
                                            So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                            In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                            01-13-2024, 07:05 PM
                                          • chth96
                                            Is ESR value different between on Circuit and off Circuit?
                                            by chth96
                                            A few days ago, I purchased MESR-100 ESR meter, and When I measured a SMD capacitor on circuit,MESR-100 showed ESR value of 30, But I managed to desolder this SMD capacitor from circuit and measured it then MESR-100 showed ESR value of 18.
                                            I also measured it with Mega328 Transistor Tester, and It showed ESR value of 17.
                                            Is my MESR-100 defective, if the ESR value is different between on Circuit and off Circuit?
                                            11-19-2022, 04:32 AM
