Swapping out a NiMh for a LiPo?
  • EasyGoing1
    replied
    Re: Swapping out a NiMh for a LiPo?
    Originally posted by stj
    emergency lighting should have a hidden or key activated switch on the power for routine testing.
    Yes, it has a button that when pressed, the lights come on, but as soon as you let go, it goes right back to normal operating mode where the lights are off and not using the battery.
    replied
  • EasyGoing1
    replied
    So this is interesting ... According to this document, LiIon batteries have a typical life span of only 3 years or around 500 charge cycles, whichever comes first. And according to this document, NiMH has a typical life span of around 5 years. This is the exact opposite of what I was assuming since LiIons are more robust than NiMh ... but I suppose that's mainly in their ability to deliver raw power. And the fact that LiIon doesn't develop a memory.
  • EasyGoing1
    replied
    Originally posted by eccerr0r
    That's true, emergency lighting does have charging requirements that a wall wart USB charger probably doesn't meet either...
    I'd say the drain down should be done with all other building emergency preparedness takes place... however I'd say the drain down is not for draining down the battery but rather checking if the battery is still good - I'm not sure how you found out the battery needed to be replaced in the first place...
    OH I never said it needed to be replaced. This device is brand new, I just bought it and installed it last month. I'm thinking of the future as it sits there month after month, year after year ... eventually (in my thought processes) that NiMh battery will be useless as is the case with cordless phone handsets after only a few years.
  • EasyGoing1
    replied
    Not that much of a benefit as when the li-ion drops to 3.7V nominal voltage you'll be at 3.0V after the diode... then what.
    Good point ... but do you think the voltage of the LiIons will drop significantly after just running some LEDs for a few hours? That, of course, depends on the current draw on the batteries which I would have the measure and figure out.
    However, there seems to be a change of thought here as sofTest posted that in his experience, it's best to leave the battery in these devices as they were built, then just refresh them by letting them drain ever so often...
    ... which gave me an idea ... I have solid state relays designed to work with 120V AC ... an Arduino with an RTC programmed to cut power to the device every so often at high noon until the battery drains might be fun project ...
  • eccerr0r
    replied
  • EasyGoing1
    replied
    Originally posted by sofTest
    Are you continuing using them as emergency fixtures? If yes, I wouldn't bother changing battery technology. In my experience, NiCd does not have a lower life span than other, "newer" type batteries in this application. From my observations, NiCd might be somewhat better in this application.
    That's interesting ...
    Remember, emergency fixtures should be regularly run down to their hourly rated running time to test the battery capacity.
    The only way to actually do that would be to cut power to the device and then let it run the battery down. And since this device is hard-wired into the building's electrical, then I would have to kill the fuse at the fuse box every so often then let the battery drain.
    I'm not opposed to doing this, but the question is, HOW OFTEN should it be done? Every three months? Six? Every year?
  • delaware74b
    replied
    Typical fire/building codes in US require 90 minutes minimum run time on emergency lighting. Although 90 minutes seems like a long time, there have been times where the power was out for extended periods of time such as 4 hours for the utility to replace a failed 3-phase transformer.
  • sofTest
    replied
    ^ If you are referring to legal regulations, in most of Europe, this modification would probably break the regulations regardless, unless it was approved by whoever issued the fixtures EN 60598-2-22 compliance papers. I'm a Technical Property Manager in my professional life. Since the OP is based in the US, I don't know.
    replied
    there are more regulations than that - a visible charge/float led for example
  • sofTest
    replied
    About voltage drop, if the fixtures are to be used for anything where legal code requirements apply, you need to be sure that the new battery type maintain the voltage needed during discharge/usage time. NiCd maintain their full voltage during discharge until they are nearly depleted. Other batteries might have a different voltage drop curve, so unless the fixture is designed to take that in to account, you might find that the light cut out before the fixtures rated time, even with a new battery.
    https://www.mpoweruk.com/performance.htm
    replied
    the voltdrop is dependant on the current actually.
    that's why i cringe when people use diodes to link 5v and 3,3v logic or to drive leds!
  • eccerr0r
    replied
    Originally posted by EasyGoing1
    THE ADDED BENEFIT that I am figuring on getting from having the diode inline, is losing .7 volts across the diode ... since the original battery is 3.7 volts and the LiIon is 4.2 volts, having the diode in place brings the voltage at the emergency light back to 3.5 which is a little lower than the original battery but it certainly won't damage anything.
  • sofTest
    replied
    ... Other thoughts?
    replied
    so if you do that,
    2 things to watch.
    1: keep the usb socket isolated from any metal casing - or your ground will bypass the battery protection.
    2: dont overload the battery protection circuit with your load.
    see the pdf's
  • EasyGoing1
    replied
    If you don't have protection circuitry on the Li-ion then get protection circuitry. And if you can tweak the protection circuitry to stop charging at 4.2 volts (or less), all the better. Other than being a bit inefficient when the cell is fully charged, it should work just fine.
    OK, check out this diagram on that charging board I referred to:
    Notice that the battery is protected from whatever it's powering by the charge circuit being in the middle...
    So what I was thinking of doing was something like this:
    So that the charger circuit basically becomes the battery that is connected to the emergency light, with the diode preventing any charge current from being back-fed into the output of the charger ... but that charger is designed to monitor the battery at all times and prevent it from being over-discharged (by cutting power to whatever the charger is powering and then continuing to charge the battery) and it prevents the battery from being overcharged because it actually does the charging...
    That circuit by the way ... is meant to be used as a portable power source for whatever ... and when you have 5 volts connected to it, then it won't even let the battery supply the power to the outputs ... it feeds the output directly from its 5 volt / USB input until the input power is cut then it lets the battery take over supplying voltage to the outputs.
    It's a pretty cool circuit.
  • EasyGoing1
    replied
    So does your 'new' lithium pack have protection circuitry?
    It's probably more work to incorporate a built-for-Li-ion charging circuit into an existing design that's tightly coupled with other circuitry.
    So this is where I struggle - though I wholeheartedly agree with this statement, this particular circuit is about as stupid simple as it gets ... we have:
    1) A circuit that connects to standard home AC electricity.
    2) The circuit converts AC to DC (though it's still kinda noisy, I checked).
    3) The circuit has two primary functions:
    a) Keep the battery charged while its AC source is hot.
    b) When the AC source goes cold, switch on the LED lights and power them from the battery.
    I mean ... THAT'S ALL IT DOES... and all I wanna do is replace said battery with batteries that are better suited to constantly being charged without developing memory, and would also provide a longer run time for the lights when the power goes out. Without question, the NiMh battery pack MIGHT provide the 2 hours of run time they claim TODAY ... but next year? That number will be noticeably smaller and it will continue to get smaller the more it develops a memory.
    SO, All I wanna do is replace that battery pack with better batteries, but the problem being, that the connection where the battery connects to the circuit, will be trying to charge the batteries all the time ... and I was hoping that a simple diode properly placed, would block that charge current from getting to the batteries, while I then provide my own method of charging the batteries.
    But so far, No one has told me if my diode theory for blocking charge current would actually work. I suppose I could just test it ... what's the worse that could happen?
    These little gizmo's should do the job...
  • eccerr0r
    replied
  • EasyGoing1
    replied
    Originally posted by delaware74b
    - Agent24 - While the NiCd may handle trickle charging better than NiMH, they do need to be deep-cycled on occasion or they develop memory issues.
    This is exactly why I wanted to replace it with either LiPo or Lion
  • eccerr0r
    replied
    Uh...a bit of confusion here.
    The original battery is NiCd. Apparently OP wants to swap for Li-Ion.
    Likely the current charger trickle charges already which is a no-no for Li-Ion.
    Still the same outcome - likely a re-design is needed.
    If your li-ion battery pack has overcharge protection, it likely will work just fine in its place but likely you'll find its cycle life severely degraded or possibly destroyed. Something that will limit charge voltage to shunt off the trickle charge, whether it be another auxiliary protection circuit or redesign will be needed.
  • Tarot Superstars
    Short Circuit tester
    by Tarot Superstars
    Hello.
    I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
    The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
    Link
    The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
    https://www.youtube.com/watch?v=0eixDdCpiO4
    My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
    09-25-2023, 09:11 AM
  • Alimash
    op amp circuit function?
    by Alimash
    I am repairing a ups which doesn't turn on ,it has the following ICs:
    SG3525 used to drive inverter mosfets.
    couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
    A LM358 and TL074 for control mechanism and of course the uController.
    The SG3525 is shutting down every time the ups is turned on.
    I want your help to know the function of LM358 and TL074 in the system.
    I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
    07-31-2025, 07:45 AM
  • M1NEBLANK SHOW
    MSI B250 Gaming M3 Short circuit in CPU power supply circuit
    by M1NEBLANK SHOW
    Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
    (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
    Schematic and Boardview here
    04-04-2025, 03:57 PM
  • прямо
    Viper22A 5VSB circuit
    by прямо
    So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
    In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
    01-13-2024, 07:05 PM
  • chth96
    Is ESR value different between on Circuit and off Circuit?
    by chth96
    A few days ago, I purchased MESR-100 ESR meter, and When I measured a SMD capacitor on circuit,MESR-100 showed ESR value of 30, But I managed to desolder this SMD capacitor from circuit and measured it then MESR-100 showed ESR value of 18.
    I also measured it with Mega328 Transistor Tester, and It showed ESR value of 17.
    Is my MESR-100 defective, if the ESR value is different between on Circuit and off Circuit?
    11-19-2022, 04:32 AM
