How to read PCB symbol for 6 pin push-pull switch?
  • LearningToRepair
    • Jul 2020
    • 35
    Hi!
    I am a bit confused how to read PCB markings for 6 pin push pull switch. I had problem with my 6 pin push-pull switch on my UT58A multimeter. It did not lock properly. So I decided to replace it. I forgot the orientation of original button. And now I need some help with understanding PCB.
    I learned from google how to identify orientation of push-pull button:
    But I am a bit confused which way PCB expects it. I expected that PCB would have some kind on intent marked on it. But mine has 3 marked instead. I attached the photo of it where I marked each intent with numbers 1-3. I would like to know what each intent means and which way does this PCB expect me to install this button.
    • Jul 2011
    • 6044
    Re: How to read PCB symbol for 6 pin push-pull switch?
    The way you have the number I would think that this is way it should be put in only because on this it shows the direction and the other two markings would that it a latching switch type
    Although I can not say that I have seen this type of symbol for this type of switching but is a first time for everything
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      test switch with your meter .or look at its diagram
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        normally closed will go to where its marked as switch closed on the pcb
        • R_J
          • 9556
          When the switch is pushed IN, it should connect (2 & 3, 4 & 5 on your meter pcb picture). Pins 1 & 6 are connected together, according to the schematic and as seen in your picture. The switch is in the ON position in the schematic.
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            worst that might happen is the switch will operate backwards
              • 31087
              if thats your power switch then indentation towards the lcd display
              • petehall347
                • Jan 2015
                • 4427
                • United Kingdom
                it would have been easier to just ignore the silk screen .
                • LearningToRepair
                  • Jul 2020
                  • 35
                  Managed to get it in the proper way.
                  Whats that symbol exactly? Like the symbol that I marked with nr 2 on my attached file? Just asking so I know how to read these in future.
                    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 05:30 AM
                  • Natob82
                    Micro Momentary Push Switch?
                    by Natob82
                    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                    12-21-2022, 05:22 AM
                  • grimacelord
                    NEC TurboExpress On/Off Power Switch Replacement Help
                    by grimacelord
                    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                    11-09-2023, 09:49 AM
                  • SluggerB
                    Help making a switch work the opposite way with a relay
                    by SluggerB
                    I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                    I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                    It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                    02-07-2025, 07:57 PM
                    Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                    by sam_sam_sam
                    Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                    ( needs more cam circuits for the machine to work correctly again )
                    https://www.ebay.com/itm/275321870186
                    To
                    3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                    ( not 4 positions but the right amount of cams circuits )
                    https://www.ebay.com/itm/274660439950
                    I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                    03-18-2023, 05:12 PM
