How to read PCB symbol for 6 pin push-pull switch?
  • LearningToRepair
    • Jul 2020
    • 35
    Hi!
    I am a bit confused how to read PCB markings for 6 pin push pull switch. I had problem with my 6 pin push-pull switch on my UT58A multimeter. It did not lock properly. So I decided to replace it. I forgot the orientation of original button. And now I need some help with understanding PCB.
    I learned from google how to identify orientation of push-pull button:
    But I am a bit confused which way PCB expects it. I expected that PCB would have some kind on intent marked on it. But mine has 3 marked instead. I attached the photo of it where I marked each intent with numbers 1-3. I would like to know what each intent means and which way does this PCB expect me to install this button.
    • Jul 2011
    • 6040
    Re: How to read PCB symbol for 6 pin push-pull switch?
    The way you have the number I would think that this is way it should be put in only because on this it shows the direction and the other two markings would that it a latching switch type
    Although I can not say that I have seen this type of symbol for this type of switching but is a first time for everything
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      test switch with your meter .or look at its diagram
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        normally closed will go to where its marked as switch closed on the pcb
        • R_J
          • 9549
          When the switch is pushed IN, it should connect (2 & 3, 4 & 5 on your meter pcb picture). Pins 1 & 6 are connected together, according to the schematic and as seen in your picture. The switch is in the ON position in the schematic.
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            worst that might happen is the switch will operate backwards
              • 31044
              if thats your power switch then indentation towards the lcd display
              • petehall347
                • Jan 2015
                • 4427
                • United Kingdom
                it would have been easier to just ignore the silk screen .
                • LearningToRepair
                  • Jul 2020
                  • 35
                  Managed to get it in the proper way.
                  Whats that symbol exactly? Like the symbol that I marked with nr 2 on my attached file? Just asking so I know how to read these in future.
                  • Natob82
                    Micro Momentary Push Switch?
                    by Natob82
                    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                    12-21-2022, 05:22 AM
                  • grimacelord
                    NEC TurboExpress On/Off Power Switch Replacement Help
                    by grimacelord
                    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                    11-09-2023, 09:49 AM
                    Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                    by sam_sam_sam
                    Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                    ( needs more cam circuits for the machine to work correctly again )
                    https://www.ebay.com/itm/275321870186
                    To
                    3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                    ( not 4 positions but the right amount of cams circuits )
                    https://www.ebay.com/itm/274660439950
                    I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                    03-18-2023, 05:12 PM
                  • CdDvdFlash
                    LTL Acorn 5210A Trail Camera Power Switch
                    by CdDvdFlash
                    I have an LTL Acorn 5210A trail camera and the power switch needs replacing, there is only one site I found that sell them but they want 12 pounds each I'm in Australia so thats $24 but I see these switches are in all sorts of devices everywhere so I'm hoping to find a cheaper one, I dont know what the pinout is for these switches but I have taken apart the camera down to just the board and removed the switch and hooked up a battery pack (4x AA batteries) to see what the voltages are at the traces where the switch was. In the picture of just the switch it is currently in the off position, it moves...
                    08-06-2023, 09:12 AM
                  • redwire
                    KSGER T12 station shake switch hassles
                    by redwire
                    Ongoing hassles with the shake switch on my KSGER T12 station. In standby, the slightest movement of the workbench would wake it up.
                    Handle has the SW-200D two ball switch, I had installed it gold lead down towards tip/silver up, so it was N.C. when in the stand.
                    But any tiny jiggle and the station would wake up. I think the firmware looks for a rising edge on the signal to wake up.
                    So I took the wand apart and flipped the switch around. Turns out soldering the plastic it melts super easy deforming the end. It totally did not work afterwards, killed the switch. ...
                    02-14-2023, 02:07 PM
