Drilled motherboards
  • Askic
    • Sep 2018
    • 187
    • BIH
    I was looking to buy some faulty boards to be used as donor boards for repairs (mainly macbooks but also other manufacturers).
    I was surprised to learn how many boards are offered with holes drilled inside them. I wonder why is that. I could understand if HDD/SDD is drilled to protect any sensitive data, but don't know about logic boards.
    Can anybody shed some light on the topic?
    Thank you!
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Drilled motherboards
    Prevent resale market, especially for big companies that collect their old computers (apple sounds like a good candidate.)
    • Askic
      • Sep 2018
      • 187
      • BIH
      So it seems that in most cases manufacturers themselves are drilling holes. So much about recycling and reusing....
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        They want you to recycle the materials not compete with their new products...
          master hoarder
          • May 2008
          • 12175
          If the motherboards have an SSD or other storage soldered onto the motherboard (such as tablets and many of the modern ultra-thin laptops), then that's probably the reason why... which is silly, because you don't even need to fully low-level format an SSD to make the data completely irrecoverable, unlike on a conventional HDD. Just wiping the file table on the SSD of where all the files are stored is typically enough... and since SSDs are fast, I'm sure there's software out there that can do this on the fly in very little time. But some people/companies are too dumb to learn new ways and would rather smash/destroy stuff than put a little effort and time and recover much of that investment back while also helping the environment and local community.
          Which is bullshit, because majority of the "materials" in the PCB are various non-recyclable organics and very little metal. On top of that, even then a lot of the metal recovery is not very effective... so you end up with a lot of waste.
          • diif
            • Feb 2014
            • 6978
            • England
            They will have been written off against tax, the holes ensure they can't be repaired and any possible data recovered but they can be reused for parts which is better than shredding.
            If it has a T2 chip and wasn't wiped by the previous owner it's scrap anyway.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              This is how business works: "NOT MY PROBLEM... IT'S NOW YOUR PROBLEM!"
                • Jul 2011
                • 6039
                This is so true
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Pisses me off, if they can't get electronics to fail and force people to throw it away, they get software to not run on old hardware anymore and force people throw it away too...why *can't* I still use my P3 and Athlon XP...
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Looks like that will backfire for anything manufactured in the 2010s, with the coronavirus pandemic! Because many people can't even get a later video card!
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • dmill89
                      • Dec 2011
                      • 2534
                      ^This, businesses recycling their own equipment generally don't care what happens to it once the HDD/SSD is removed/wiped so they generally aren't the ones requiring stuff to be destroyed. However manufacture's "official" recycling programs (especially Apple) often specifically require their contractors destroy equipment to prevent it's reuse, this is largely a result of their vendetta against independent repair (Apple is certainly the worst offender in this, but many other manufactures are following their lead), since it is much harder for independent repair shops to operate if they can't get parts, and since Apple won't sell new parts to " non-authorized" repair shops, used parts were often the only source, but now they are attacking that as well.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        hard drives at least tend to be automatically obsoleted by size/speed, so they don't need to destroy them... alas I'm still using old drives despite this...
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          That backfired with the automobile industry! And even for "big-ag", with John Deere, there were revolts.
                          Arc A770 16 GB
                            • Jul 2011
                            • 6039
                            Why don’t we just stop buying this crap if companies want do this kind-a crap oh I forgot that you can not talk bad about a company like that they might retaliate in some way
                            But sure would be nice though
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              problem is that the products are "so good" that getting an alternative is "suboptimal" ...
                              ... until it breaks and suddenly the "so good" item is "suboptimal"...
                              • ugamazing
                                Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                by ugamazing
                                I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                12-17-2024, 07:05 PM
                                by momaka
                                03-15-2023, 10:17 PM
                              • ugamazing
                                Apple M1 Boards & Exclamatory Error?
                                by ugamazing
                                We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
                                Has anyone else run into this...
                                02-20-2025, 09:24 AM
                              • ugamazing
                                Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                by ugamazing
                                I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                08-31-2022, 07:34 AM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
