How could I find a FET with specific specs?
    • 31010
    Re: How could I find a FET with specific specs?
    if your going from AVR to Pi or STM32, remember your i/o is 3.3v
    good for displays - you dont need resistors,zeners or buffers anymore - but may need a bit of attention with some sensors
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      I've had two Arduino Due's ... and managed to foul them up pretty nicely because i wasn't being mindful of the 3v limit. However, these Teensy 4.0's I've managed to not damage and they are 3v so ... this old dog can learn some new tricks.
      sigpic
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Are Microchip/General Instruments PIC8s dead yet?
        If so, good riddance.
        If not, ()#$*#(@#*(@ their memory management.
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          Could you have meant the PIC18 Microcontroller?
          sigpic
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            No, I generalized all PIC 8-bit microcontrollers into the same bin... the trash bin...
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              That's where my Commodore 64 went several decades ago and I still don't regret it ... even if these weirdos are obsessed with the C=64 making a come back... I don't live for the past ... I'm happy to be done with it.
              sigpic
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Never used a C64 but as a 6502 I don't think that's horribly bad. I do have my qualms with 6502 however, not a great processor either but much better than PIC 8-bit...
                6502s are fast however. Beats the Z80 which I've preferred, but 6502s murder the Z80 MHz for MHz.
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  This new laptop I got has 32 gigs of RAM in it...
                  My first computer, the C=64 had 64k of ram...
                  So TODAY, my computer has 500,000 times more ram than my first one.
                  That's pretty phenomenal to me.
                  sigpic
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • nunofcc
                    Logitech G29 Help request to find smd transistor reference.
                    by nunofcc
                    Good night,
                    I am going to ask your help to find out what is the reference of this smd transistor. Or what is an equivalent transistor?
                    Thank you for your help....
                    10-04-2020, 01:59 PM
                  • corrize
                    Where to find a very small fpc connector 0.3mm between 2 pins ?
                    by corrize
                    Hello, I search this connector (oxydated).
                    It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                    I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                    I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                    Do you know how to find this connector please ? What is the exact name for find it ?
                    08-06-2024, 05:25 PM
                    Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                    by sam_sam_sam
                    This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                    Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                    07-07-2024, 02:34 PM
                  • magneh
                    Behringer Eurolive B205D repair - help identifying transistor
                    by magneh
                    Hello
                    Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                    Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                    After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                    I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                    Still, I need to replace this transistor....
                    06-18-2025, 02:34 AM
