Re: How could I find a FET with specific specs?
The OP was using PWM except was not letting it through to the end device, insisting that the conversion happen early in the chain, thus wasting energy as well as increasing the dissipation requirements of the switching elements. The same problem was encountered in one of the previous projects the OP was working on yet persists on here.
In any case, proper drive needs to be figured out. OP apparently still hasn't figured out how to properly turn LEDs fully on and off - a requirement for PWM.
This might seem like a stupid suction but why not use PWM function ( if this controller has this option) and
only have one output
You do have use the right setup for the transistor or mosfet that you would using
I have done this a few time with a Basic Stamp and using the PWM function but you have to have output setup correctly I have even done this with an optic sensor ( like a 4N25 or something similar )
For give me for saying this but you might be making this hard than it needs to be
unless you have a special reason for doing it this way
One note you do have to set parameters correctly with the PWM signal for this to also work correctly
You might not be able to to go all the way down to 0% duty cycle and see the LEDs light very dimly but maybe down 10% depending on the controller and maybe as high as 75 to 80 for full on brightness in appearance to naked eye
One other note you might even have to put a 1uf ( or less ) capacitor on the output pin of the controller and the negative side of the power supply to smooth out the pulses coming from the controller if they flicker to much ( see below )
I once had to use this method for a solenoid valve coil hook up to Basic Stamp Controller using the PWM output to control a portioning hydraulic valve coil because the controller board for this machine took a crap for controlling this valve and to replace it would have cost to much money
One final note this valve portioning power amplifier version has a feature that you can hook pot control to but because of the way valve works it would not always work correctly all the time and this was the reason for using a controller with a PWM controller function so it would work correctly most of the time
The company that I worked for at the time really appreciate the fact I was able to fix this machine issue without having to spend a lot of money to do it ( this machine was about 20 years old )Last edited by sam_sam_sam; 01-25-2021, 03:28 PM.Leave a comment:
Before you test that circuit and find it may not work as well as planned, do recall one LED turned on is dimmer than 2, and 2 on is dimmer than 3... so you may also be overthinking the problem.Leave a comment:
What do you guys think about something like this ... where picking different values for RO1, RO2 and RO3 as current limiting resistors for high, medium and low brightness in the LEDs, turning on only one of the three transistors at any given time?
:-)Leave a comment:
Well, computer and keyboard are your friend so just do the research on those subjects.
You have no idea how lucky you are have internet to access the knowledge world wide, in my days I would be lucky to find the info without waiting for months to get info on pieces of paper or spend lots of money at College book stores.
And for the record, I did immediately look up current monitor feedback and was reading eagerly until I realized I started getting completely lost .... what I got from it though, was that a voltage feedback monitor basically takes a voltage and feeds it back to an opamp using a high impedance input on the opamp so that it would be the small voltage differences that guide the output of the opamp causing it to provide a more stable voltage, and current feedback would do something similar only it would be fed back into a low impedance on the op-amp so that it would be the current changes guiding the output of the opamp ... that's about as much as I was able to register before the propeller head tore off into all kinds of hieroglyphics ...Leave a comment:
You have no idea how lucky you are have internet to access the knowledge world wide, in my days I would be lucky to find the info without waiting for months to get info on pieces of paper or spend lots of money at College book stores.Leave a comment:
Correct, need a common emitter or common source for mosfets. So that means low side, or use a p channel/pnp transistor. OP can use n channel/npn on the high side if they make a driver for them, which may complicate the circuit considerably.
I'm facepalming because we're seeing the same problems that needs to be solved as the magnetic stirrer problem. Nothing learned... Insisting the final driver must be driven by an analog signal...
Does OP actually build the circut? If OP really wants to learn then build the circuit and report the results, the Voltage readings, the condition of the signals, etc. then you can analyze why the circuit is not doing what you want to do.Last edited by budm; 01-24-2021, 07:11 PM.Leave a comment:
Well, clearly now you don't have a low side control of the load. What you do have is 'high side' where the transistor switch element is controlling the positive rail to your device as it blocks the electrons after it flows through your load(LED) (or described by classical electrical flow, current is blocked before it goes through the load).
I have to leave it up as an exercise to the reader to convert this to a 'low' side control.
Thank you for putting the correct polarity/channel semiconductor in the schematic. Very important when dealing with the drive needed to turn on low/high side semiconductor switches.Leave a comment:
Since electricity can be interrupted anywhere in the circuit, there's a choice to be made. Low side control means controlling the "low" or ground/negative side of the device that needs to be turned on/off. High side = "high" or power/positive side of the device. Choice needs to be made, devices need to then follow suit.
If you chose devices before side then circuit topologies are more limited due to device physics.
If you chose devices before side then circuit topologies are more limited due to device physics.Last edited by eccerr0r; 01-24-2021, 10:14 AM.Leave a comment:
OK, so in terms of learning, I have no idea what "on the low side of the circuit" means at all ... also, "current monitor feedback" - no idea what that is either.Leave a comment:
I'm here to learn, not dictate. I only post what I know...Leave a comment:
I'm facepalming because we're seeing the same problems that needs to be solved as the magnetic stirrer problem. Nothing learned... Insisting the final driver must be driven by an analog signal...Leave a comment:
I'm not sure I understand what you're saying exactly.
Take for instance, this schematic, and the transistor is the ztx602...
Based on what I see in the datasheet, once the pin at the base of the transistor hits 1.7 volts, those LEDs will be on as bright as they ever could be in this circuit, meaning that my options for "medium" and "low" light intensity will have to be achieved by telling the attiny pin to drive the transistor at two different voltage levels below 1.7. Correct? Which gives me a lot less headroom for resolution, which is fine, as long as the transistor will do what I'm needing it to do. But I don't know how to drive a transistor with current because to me, current happens when you apply voltage to a circuit but it's not an option, in this case, to say "Im going to drive this transistor with x number of milliamps" because in an Arduino, I can only adjust voltage levels on pins.
You should have the Transistor or the MOSFET on the low side of the circuit and then PWM the MOSFET to control the current through the LED and you also need the current monitor feedback to maintain constant current through the LEDs.
Your circuit is the Voltage source not current source, so if you have fixed Voltage feeding the LED, but since LED Vf will vary with temperature so the current through the LED will change which will cause the LED brightness to change, that is why you need to use constant current source to drive the LED so if the LED Vf varies the circuit will try to maintain constant current through the LED thus maintaining the steady brightness.Last edited by budm; 01-23-2021, 04:27 PM.Leave a comment:
That circuit takes the small current available from the micro-controller pin, and amplifies it with the transistor to drive the LEDs.
This will turn them on full.
But PWM turns them on and off quickly, and varies the duration for which they are on vs off. By doing so it can control the brightness as we perceive it with our eyes due to persistence of vision. So there is no need to control the current linearly.
With a more advanced micro-controller, you can output an analog signal using the onboard DAC, then amplify that with a transistor to control the LEDs but then you will need a transistor with a heatsink so it does not overheat. PWM is more efficient as the transistor is either on or off.
The only other option is to have multiple transistors switching in different resistor values for your different brightness levels but this increases the cost and complexity greatly.Leave a comment:
Based on what I see in the datasheet, once the pin at the base of the transistor hits 1.7 volts, those LEDs will be on as bright as they ever could be in this circuit, meaning that my options for "medium" and "low" light intensity will have to be achieved by telling the attiny pin to drive the transistor at two different voltage levels below 1.7. Correct? Which gives me a lot less headroom for resolution, which is fine, as long as the transistor will do what I'm needing it to do. But I don't know how to drive a transistor with current because to me, current happens when you apply voltage to a circuit but it's not an option, in this case, to say "Im going to drive this transistor with x number of milliamps" because in an Arduino, I can only adjust voltage levels on pins.Leave a comment:
i meant pwm and a fet
as for saturation, like i said - your driving it with variable current - not voltage.Leave a comment:
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by nunofccGood night,
I am going to ask your help to find out what is the reference of this smd transistor. Or what is an equivalent transistor?
Thank you for your help.... -
by corrizeHello, I search this connector (oxydated).
It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
Do you know how to find this connector please ? What is the exact name for find it ?
by sam_sam_samThis Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...-
by ktmmotocrossEVGA 360AIO with LCD. Aio and lcd not work. Cannot find NUC1261NE4AE Nuvoton that have burn mark on it.
Anyone knows where to find it?08-02-2025, 06:40 AM - Loading...
