How could I find a FET with specific specs?
  • eccerr0r
    replied
    Re: How could I find a FET with specific specs?
    The OP was using PWM except was not letting it through to the end device, insisting that the conversion happen early in the chain, thus wasting energy as well as increasing the dissipation requirements of the switching elements. The same problem was encountered in one of the previous projects the OP was working on yet persists on here.
    In any case, proper drive needs to be figured out. OP apparently still hasn't figured out how to properly turn LEDs fully on and off - a requirement for PWM.
    replied
    This might seem like a stupid suction but why not use PWM function ( if this controller has this option) and
    only have one output
    You do have use the right setup for the transistor or mosfet that you would using
    I have done this a few time with a Basic Stamp and using the PWM function but you have to have output setup correctly I have even done this with an optic sensor ( like a 4N25 or something similar )
    For give me for saying this but you might be making this hard than it needs to be
    unless you have a special reason for doing it this way
    One note you do have to set parameters correctly with the PWM signal for this to also work correctly
    You might not be able to to go all the way down to 0% duty cycle and see the LEDs light very dimly but maybe down 10% depending on the controller and maybe as high as 75 to 80 for full on brightness in appearance to naked eye
    One other note you might even have to put a 1uf ( or less ) capacitor on the output pin of the controller and the negative side of the power supply to smooth out the pulses coming from the controller if they flicker to much ( see below )
    I once had to use this method for a solenoid valve coil hook up to Basic Stamp Controller using the PWM output to control a portioning hydraulic valve coil because the controller board for this machine took a crap for controlling this valve and to replace it would have cost to much money
    One final note this valve portioning power amplifier version has a feature that you can hook pot control to but because of the way valve works it would not always work correctly all the time and this was the reason for using a controller with a PWM controller function so it would work correctly most of the time
    The company that I worked for at the time really appreciate the fact I was able to fix this machine issue without having to spend a lot of money to do it ( this machine was about 20 years old )
  • eccerr0r
    replied
    Before you test that circuit and find it may not work as well as planned, do recall one LED turned on is dimmer than 2, and 2 on is dimmer than 3... so you may also be overthinking the problem.
  • EasyGoing1
    replied
    What do you guys think about something like this ... where picking different values for RO1, RO2 and RO3 as current limiting resistors for high, medium and low brightness in the LEDs, turning on only one of the three transistors at any given time?
  • EasyGoing1
    replied
    Originally posted by eccerr0r
    I have to leave it up as an exercise to the reader to convert this to a 'low' side control.
    Low side control?
    Thank you for putting the correct polarity/channel semiconductor in the schematic. Very important when dealing with the drive needed to turn on low/high side semiconductor switches.
    You're still upset over that little mistake? That was like ... 5 topics ago wasn't it?
  • EasyGoing1
    replied
    Originally posted by budm
    Well, computer and keyboard are your friend so just do the research on those subjects.
    You have no idea how lucky you are have internet to access the knowledge world wide, in my days I would be lucky to find the info without waiting for months to get info on pieces of paper or spend lots of money at College book stores.
    Hey I was there too ... I remember when Al Gore proposed his bill to fund the "Information Super Highway" - which was a federal budget created specifically to expand the Internet from the privileged few (governments and public education) out to the home via the Telco's. I was in my second year of college back then and didn't actually see Internet access until two years after that when I was a tech at Edwards AFB ... then AOL tapped in and started separating the men from the boys... lol
    And for the record, I did immediately look up current monitor feedback and was reading eagerly until I realized I started getting completely lost .... what I got from it though, was that a voltage feedback monitor basically takes a voltage and feeds it back to an opamp using a high impedance input on the opamp so that it would be the small voltage differences that guide the output of the opamp causing it to provide a more stable voltage, and current feedback would do something similar only it would be fed back into a low impedance on the op-amp so that it would be the current changes guiding the output of the opamp ... that's about as much as I was able to register before the propeller head tore off into all kinds of hieroglyphics ...
    replied
    Originally posted by EasyGoing1
    OK, so in terms of learning, I have no idea what "on the low side of the circuit" means at all ... also, "current monitor feedback" - no idea what that is either.
    replied
    Correct, need a common emitter or common source for mosfets. So that means low side, or use a p channel/pnp transistor. OP can use n channel/npn on the high side if they make a driver for them, which may complicate the circuit considerably.
    I'm facepalming because we're seeing the same problems that needs to be solved as the magnetic stirrer problem. Nothing learned... Insisting the final driver must be driven by an analog signal...
    That seems to be the case, isn't it?
    Does OP actually build the circut? If OP really wants to learn then build the circuit and report the results, the Voltage readings, the condition of the signals, etc. then you can analyze why the circuit is not doing what you want to do.
  • eccerr0r
    replied
    Well, clearly now you don't have a low side control of the load. What you do have is 'high side' where the transistor switch element is controlling the positive rail to your device as it blocks the electrons after it flows through your load(LED) (or described by classical electrical flow, current is blocked before it goes through the load).
  • EasyGoing1
    replied
    Since electricity can be interrupted anywhere in the circuit, there's a choice to be made. Low side control means controlling the "low" or ground/negative side of the device that needs to be turned on/off. High side = "high" or power/positive side of the device. Choice needs to be made, devices need to then follow suit.
    If you chose devices before side then circuit topologies are more limited due to device physics.
    OK, then when budm says, "You should have the Transistor or the MOSFET on the low side of the circuit" how does that change this schematic? What would be different?
  • eccerr0r
    replied
  • EasyGoing1
    replied
    And HEY - I got that pill to spin did I not? Gotta give me some credit... :-)
  • EasyGoing1
    replied
    You should have the Transistor or the MOSFET on the low side of the circuit and then PWM the MOSFET to control the current through the LED and you also need the current monitor feedback to maintain constant current through the LEDs.
  • EasyGoing1
    replied
    I'm here to learn, not dictate. I only post what I know...
  • eccerr0r
    replied
    replied
    I'm not sure I understand what you're saying exactly.
    Take for instance, this schematic, and the transistor is the ztx602...
    Based on what I see in the datasheet, once the pin at the base of the transistor hits 1.7 volts, those LEDs will be on as bright as they ever could be in this circuit, meaning that my options for "medium" and "low" light intensity will have to be achieved by telling the attiny pin to drive the transistor at two different voltage levels below 1.7. Correct? Which gives me a lot less headroom for resolution, which is fine, as long as the transistor will do what I'm needing it to do. But I don't know how to drive a transistor with current because to me, current happens when you apply voltage to a circuit but it's not an option, in this case, to say "Im going to drive this transistor with x number of milliamps" because in an Arduino, I can only adjust voltage levels on pins.
    You are doing Emitter follower (Common Collector), so the Base Voltage with ref to ground will way higher than 1.7V Vbe junction. if you look at your circuit you will have Vbe, Vled, Vrs. The output Voltage on the Emitter will be = Vbase drive - Vbe.
    Your circuit is the Voltage source not current source, so if you have fixed Voltage feeding the LED, but since LED Vf will vary with temperature so the current through the LED will change which will cause the LED brightness to change, that is why you need to use constant current source to drive the LED so if the LED Vf varies the circuit will try to maintain constant current through the LED thus maintaining the steady brightness.
  • Agent24
    replied
    That circuit takes the small current available from the micro-controller pin, and amplifies it with the transistor to drive the LEDs.
    This will turn them on full.
    But PWM turns them on and off quickly, and varies the duration for which they are on vs off. By doing so it can control the brightness as we perceive it with our eyes due to persistence of vision. So there is no need to control the current linearly.
    With a more advanced micro-controller, you can output an analog signal using the onboard DAC, then amplify that with a transistor to control the LEDs but then you will need a transistor with a heatsink so it does not overheat. PWM is more efficient as the transistor is either on or off.
    The only other option is to have multiple transistors switching in different resistor values for your different brightness levels but this increases the cost and complexity greatly.
  • eccerr0r
    replied
  • EasyGoing1
    replied
    Originally posted by stj
    i meant pwm and a fet
    as for saturation, like i said - your driving it with variable current - not voltage.
    replied
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
  • danielgerman681
    ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
    by danielgerman681
    Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
    08-27-2025, 01:17 PM
  • nunofcc
    Logitech G29 Help request to find smd transistor reference.
    by nunofcc
    Good night,
    I am going to ask your help to find out what is the reference of this smd transistor. Or what is an equivalent transistor?
    Thank you for your help....
    10-04-2020, 01:59 PM
  • CoinCoin88
    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
    by CoinCoin88
    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
    09-15-2025, 03:36 AM
  • corrize
    Where to find a very small fpc connector 0.3mm between 2 pins ?
    by corrize
    Hello, I search this connector (oxydated).
    It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
    I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
    I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
    Do you know how to find this connector please ? What is the exact name for find it ?
    08-06-2024, 05:25 PM
