How could I find a FET with specific specs?
    • 31247
    Re: How could I find a FET with specific specs?
    if your going from AVR to Pi or STM32, remember your i/o is 3.3v
    good for displays - you dont need resistors,zeners or buffers anymore - but may need a bit of attention with some sensors
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      I've had two Arduino Due's ... and managed to foul them up pretty nicely because i wasn't being mindful of the 3v limit. However, these Teensy 4.0's I've managed to not damage and they are 3v so ... this old dog can learn some new tricks.
      sigpic
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8703
        Are Microchip/General Instruments PIC8s dead yet?
        If so, good riddance.
        If not, ()#$*#(@#*(@ their memory management.
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          Could you have meant the PIC18 Microcontroller?
          sigpic
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8703
            No, I generalized all PIC 8-bit microcontrollers into the same bin... the trash bin...
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              That's where my Commodore 64 went several decades ago and I still don't regret it ... even if these weirdos are obsessed with the C=64 making a come back... I don't live for the past ... I'm happy to be done with it.
              sigpic
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8703
                Never used a C64 but as a 6502 I don't think that's horribly bad. I do have my qualms with 6502 however, not a great processor either but much better than PIC 8-bit...
                6502s are fast however. Beats the Z80 which I've preferred, but 6502s murder the Z80 MHz for MHz.
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  This new laptop I got has 32 gigs of RAM in it...
                  My first computer, the C=64 had 64k of ram...
                  So TODAY, my computer has 500,000 times more ram than my first one.
                  That's pretty phenomenal to me.
                  sigpic
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • danielgerman681
                    ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
                    by danielgerman681
                    Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
                    08-27-2025, 01:17 PM
                  • nunofcc
                    Logitech G29 Help request to find smd transistor reference.
                    by nunofcc
                    Good night,
                    I am going to ask your help to find out what is the reference of this smd transistor. Or what is an equivalent transistor?
                    Thank you for your help....
                    10-04-2020, 01:59 PM
                  • CoinCoin88
                    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                    by CoinCoin88
                    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                    09-15-2025, 03:36 AM
                  • corrize
                    Where to find a very small fpc connector 0.3mm between 2 pins ?
                    by corrize
                    Hello, I search this connector (oxydated).
                    It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                    I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                    I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                    Do you know how to find this connector please ? What is the exact name for find it ?
                    08-06-2024, 05:25 PM
