Have you tried to socket mosfet?
  • LearningToRepair
    • Jul 2020
    • 35
    Hi!
    I thought about socketing D880 instead of soldering. Would socket like this hold it? Also would short pins of this socket be a problem? I mean I kind of like these because that would fix it against PCB but I am worried if heat of solder would melt the plastic with that short pins like linked product has?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Have you tried to socket mosfet?
    I'd try to figure out why it's failing so often that you'd need to socket it first...
      • 31070
      i have seen fets socketed in the past by using molex KK series connectors.
      but not in anything that pushes them hard, it was in monitor flyback circuits.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Socketing adds in a lot of parasitics that soldering does away with, and you end up with a more robust device without them. I don't think that most sockets of the size we're talking about here will come close to soldering in terms of electromechanical strength and you'll have socket failures.
        • LearningToRepair
          • Jul 2020
          • 35
          What is "electromechanical strength" in this context?
          I also dont have high load.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4974
            • New Zealand
            Why do you want to use sockets? There should be no need. I would not use them for a MOSFET for fear of loose connection. Even at low loads an intermittent connection could cause damage depending on how the circuit works. Those kinds of sockets you have shown are not exactly robust.
            A big beefy socket for a big TO-3 power transistor that's likely bolted in place in a CRT flyback circuit is another matter.
            -David VanHorn
              master hoarder
              • May 2008
              • 12175
              Hold it? - likely YES.
              Reliably? Anyone's guess.
              Those sockets look like the same pitch as what's used on some breadboards. (And in fact, I have built a ton of breadboard projects with MOSFETs stuck into the breadboard for years and had no problems.) So chances are, they will probably work. But depending on how cheap their contact plating is, you may end up with a bad electrical connection in there over time (especially with cheap China stuff that tarnishes very quickly with humidity) - could be months or it could be years. I also don't recommend them for high-frequency circuits, as parasitic capacitance may become an issue.
              Can we have more details in what you are building and why consider sockets instead of soldering in the first place?
              If I'm not mistaken, those sockets were made to be soldered, so they should be able to withstand soldering temperatures for some time... unless the plastic is really garbage cheap stuff... which you don't know sometimes with cheap online stuff like this.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4974
                • New Zealand
                Good point. In the past I bought various cheap connectors with plastic that couldn't stand much heat. Another reason to buy real branded parts from known suppliers. I think Dave Jones did a video on that too. Some cheapo SMT connectors that melted like cheese in the reflow oven.
                -David VanHorn
                • Jane
                  How do you test MOSFET in laptops ?
                  by Jane
                  I tried to use this method:
                  Testing an N-channel MOSFET:
                  Step 1: Discharge the Gate (turn off the MOSFET)
                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                  Step 2: Charge the Gate (turn on the MOSFET)
                  Now, place the red probe on the Gate (G) and the black probe on the
                  09-27-2024, 03:31 AM
                • AppleLover123
                  Asus X712EA 3 volts after the first mosfet
                  by AppleLover123
                  Hey guys,
                  i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                  I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                  Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                  I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                  Now i thought something...
                  12-15-2024, 07:49 AM
                • MicroSMD Lab
                  by MicroSMD Lab
                  I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                  01-10-2024, 06:36 AM
                • Scotchmist
                  Asus GA502D keeps blowing mosfet
                  by Scotchmist
                  I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                  I have removed the mosfet and can run the laptop no problem
                  The MOSFET is FDPC5018SG
                  Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                  08-24-2024, 02:23 PM
                • dougg3
                  Intel DX58SO high side VRM MOSFET keeps failing
                  by dougg3
                  Hi there,
                  I have an Intel DX58SO motherboard that failed last year. One of the high side VRM MOSFETs failed shorted, and it killed my i7 980 CPU. This motherboard has a 6-phase VRM. The parts used on this motherboard's VRM are:
                  • 6 x High side MOSFET: NTMFS4841NH
                  • 6 x Low side MOSFET: NTMFS4834N
                  • 6 x Driver: ADP3121JCPZ
                  It was easy to figure out where the short was, because the bad MOSFET's gate was shorted to the drain/source too. Once I removed it, all the shorts were gone on the motherboard, and I confirmed on the removed MOSFET itself that the gate/drain/source...
                  10-17-2021, 07:39 PM
