Bars in video
  • pentium
    • Mar 2006
    • 2778
    Bars in video
    the Sony CCD-F77 makes a good mid-range stereo 8mm camcorder which is why whe my first one died I promptly got another one. (that and also the abtteries and accessories are compatible with my other handycam and my CCD-V5000)
    This replacement works very well except that I'm getting bars in the picture.
    So I troubleshooted:
    To translate...
    Code:
    Video from:
    -CCD to Viewfinder: OK
    -CCD to Video Output: OK
    -Tape to Video Output*: OK
    -Video Input to Viewfinder: OK
    -Video Input to Tape**: OK
    -CCD to Tape: BAD
    Pictures: What you see if you record anything from the internal CCD to a tape.
    Okay, so something between the CCD and the tape recorder is wonky but what could there be? It's something so specific that it does not affect the video output as well as does not affect the playback of a previously recorded tape. (In other words, any other part of the camera)
    *A test pattern was recorded to a blank tape on another camcorder then played back on my F77
    **A test pattern was fed into the camera and recorded to a tape, then played back in another camera.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Bars in video
    bad cord? that looks like it might be static interference caused by bad shielding.
    sigpic
    (Insert witty quote here)
      • 31277
      Re: Bars in video
      just look at the boards,
      a very common problem with all old camcorders - specially sony is loads of leaking surface-mount capacitors.
      they are a bitch to replace usually because they are all bunched up together.
      • Wizard
        • Mar 2008
        • 2296
        Re: Bars in video
        Yea. and Smell. Eject the tape and take a sniff in there. ROTTEN fish.
        Cheers, Wizard
        • pentium
          • Mar 2006
          • 2778
          Re: Bars in video
          Sorry. My nose is not tuned to the smell of what a failing cap does smell like.
          Can anyone at least give me a general idea where to start looking? At any given time the CCD has a hlaf dozen wires coming off it.
          Find Nedry!
          • Wizard
            • Mar 2008
            • 2296
            Re: Bars in video
            Have you ever smelled rotting fish? Very prugent.
            Cheers, Wizard
              • 31277
              Re: Bars in video
              or cat piss.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Re: Bars in video
                Originally posted by stj
                or cat piss.
                what if a cat actually peed on his?
                wait- that still results in a trashed camcorder!
                sigpic
                • pentium
                  • Mar 2006
                  • 2778
                  Re: Bars in video
                  All I can smell are electronics and the crisp smell of PCBs that is evident on NOS computer hardware.
                  I honest'y do not know what rotten fish smells like.
                  Find Nedry!
                  • Pyr0Beast
                    • Feb 2009
                    • 406
                    Re: Bars in video
                    Does the camera perform same when you warm it up/cool it, or when it runs for a while.
                    Does it show the same lines when outside (indoor might be a fluorescent lamp interference, but I doubt that)
                    • Wizard
                      • Mar 2008
                      • 2296
                      Re: Bars in video
                      Rotten fish smell is what make you GO PHEW and wave your hand.
                      Not nice in comparsion to poo.
                      Cheers, Wizard
                      • pentium
                        • Mar 2006
                        • 2778
                        Re: Bars in video
                        It's less evident in very low light conditions but in normal light conditions you can see it and in bright conditions it's very obvious.
                        No, the problem is instantaneous. It does not occur or go away after a period of time.
                        Find Nedry!
                        • pentium
                          • Mar 2006
                          • 2778
                          Re: Bars in video
                          If I at least open it up can I get a general idea where to look?
                          Find Nedry!
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            Re: Bars in video
                            all the ccd-f series had bad surface mount lytics.
                            i recapped lots of these units when they were fairly new.
                            they are not wine.they just get worse with time.
                            you have lots of work on your hands or a pretty rifle target.
                            • pentium
                              • Mar 2006
                              • 2778
                              Re: Bars in video
                              Great. Bd surface mounts. I'm sure though I can get that cured somehow.
                              Was the CCD-V series also another line with abd lytics? I got a V5000 here that has the same symptoms but can't record video worht a damn (it's garbled).
                              EDIT: "Yes" is the answer.
                              Find Nedry!
                              • Wizard
                                • Mar 2008
                                • 2296
                                Re: Bars in video
                                Sony had produced bad CCD sensors from 2004 to 2006 era. I had to replace one for my friend of friend's. These IC is out of production by now.
                                Many major makers bought Sony CCD sensors in that time-frame. So this is not isolated to Sony's.
                                It usually is totally white out after few minutes of use or permanently black, streaking then totally blurry. These are the symptoms for bad CCD. The first camera with funny pink streaks is not this symptom. Second camera you mentioned later is probably this if this is in that time-frame.
                                Cheers, Wizard
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Re: Bars in video
                                  The V5000 is from the very early 90's so it's almost a full 15 years before the issue with the CCDs would occur.
                                  Find Nedry!
                                  • schmatzler
                                    • Aug 2011
                                    • 16
                                    Re: Bars in video
                                    I also got a V5000. Can't smell anything when opening the tape deck. All functions are fine, but when I press the Record button, everything is garbled. It also takes some seconds to warm up before it is displaying something in the viewfinder.
                                    I'll try replacing the caps. Hopefully it works again after that. It's a very nice device with a kind of futuristic look. A shame to throw it away.
                                    • howardc64
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
                                      HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                      This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                      09-12-2024, 02:00 PM
                                    • RetroComputingGrotto
                                      IBM LTO 7 Tape Drive - Dust Sensors??
                                      by RetroComputingGrotto
                                      I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                                      I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                                      09-19-2024, 01:54 AM
                                      GeForce RTX2080 Super Aero video gaming card issues help need
                                      by sam_sam_sam
                                      This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                                      Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                                      05-07-2023, 08:12 AM
                                      HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook 1000 Specification for Upgrade or Repair
                                      This specification for the HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                      09-06-2024, 06:20 AM
