HELP: I accidentally broke a capacitor off of my motherboard...
  • HyperFirez
    • Dec 2020
    • 6
    I can't believe of all things, I would do something like this.
    Anyway, the top of the cap says "M63x 470 6.3v".
    I assume this is 470uf, but I don't know. Also I have no idea where to look to buy a replacement. Thanks.
    Motherboard is: MSI Z170A Gaming M7
    • 31055
    Re: HELP: I accidentally broke a capacitor off of my motherboard...
    got a picture?
    • HyperFirez
      • Dec 2020
      • 6
      Yeah here it is: https://imgur.com/HDROftc
        • 31055
        solid polymer electrolytic.
        with a terrible custom paint job!
        • HyperFirez
          • Dec 2020
          • 6
          So the type of the cap is a "solid polymer electrolytic". Was I right about it being 470uf?
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Yea 470uF 6.3v
            • HyperFirez
              • Dec 2020
              • 6
              Is there anything other spec that I should know regarding it or will any cap that is 470uf and 6.3v work?
                • 31055
                watch the lead pitch and can diameter if you want the new one to fit on the board!
                • HyperFirez
                  • Dec 2020
                  • 6
                  So I actually picked up one from my neighbor across the street. He works on car motherboards. Only problem is I tired to desolder the broken legs on the board today and my iron is trash so I couldn't do it. I got in contact with MSI, so I am hoping to get them to repair it. Not sure if they will though as it is a discontinued item, but the S/N seems to be in their database still so that is a good sign I guess. Thanks for the help anyways. At least I got to learn about capacitors :p
                  • clearchris
                    • Dec 2013
                    • 687
                    You would be better off just bringing it to a local electronics repair shop. Maybe even one of those mobile phone repair shops, especially if you bring the replacement cap with you.
                    • tester272001
                      • 91
                      the easy dirty solution here is to solder a LEADED cap on there - kind of on the surface and make sure its on there pretty solid. its not pretty but it will work and provide years of service. likely will last as long as you use that mobo. use 60/40 lead solder too that will make life easy. the mobo likely uses lead free which is harder to work with. flow a little lead solder and your life will be happy. Of course if your neighbor FIXES mobo it will be a easy fix for him!
                      • tester272001
                        • 91
                        oh and by the way. loosing ONE cap off the mobo will prob not make any difference. there is a HIGH probability that it will boot fine without it.
                        • ChaosLegionnaire
                          HC Overclocker
                          • Jul 2012
                          • 3264
                          • Singapore
                          not true. it depends on where the cap is and what its function does. if its the sole filter cap in a buck regulator, powering it up without the cap will fry the buck regulator because there isnt anywhere for the excess energy to go. this will either make a crater on the board and render the board useless or if u're lucky just a popped mosfet or regulator.
                          • tester272001
                            • 91
                            I stand corrected. Valid point there Chaos!
                            • glovecaps
                              by glovecaps
                              11-25-2024, 04:23 PM
                            • Docus
                              Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                              by Docus
                              Hi everyone 😀,
                              I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                              To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                              Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                              1. I already own the exact same model, but its plastic chassis is badly damaged.
                              06-10-2025, 04:24 PM
                            • Prolog
                              by Prolog
                              12-01-2024, 08:27 PM
                            • Archimedes
                              HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                              by Archimedes
                              Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                              Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                              Fans are spinning. Blindly could install windows11 and got the device manager...
                              07-30-2024, 05:14 PM
                            • djazeiry
                              MSI Z170A Gaming PRo carbon Motherboard
                              by djazeiry
                              hello guys ,
                              i got an MSI Z170A Gaming Pro Carbon that have an issue on it , it's the cpu RED LED issue , and i need a dump for it bios if it is possible , or where to check to see if there any fix for it, everything seems to be fine on it, i checked the resistance of the CPU it was 4ohms(i guess it's fine), thank you
                              06-30-2024, 08:02 AM
