How flash atmega238 on rt809f
  • mo000
    • Nov 2017
    • 273
    • algeria
    hi
    plz someone tell me how to PROGRAM ATMEGA238 on RT809F programmer .
    • 30978
    Re: How flash atmega238 on rt809f
    you mean just the chip?
    or the chip on a board?
    • mo000
      • Nov 2017
      • 273
      • algeria
      just the chip
      i bought usbasp to program the atmega an i connect the wires gnd vcc miso ... from uabasp to the atmega 238 but avrdude can't read the atmega .
        • 30978
        the atmega cant run without a clock, if your using an isp programmer like an asp you also need an 8-16Mhz crystal and a couple of 10-22pf ceramic caps
        • Nikan.e
          How to program a specific flash region of a Nations N32G455RE MCU?
          by Nikan.e
          Greetings and salutations!
          I have a device that uses an N32G455RE. Unfortunately, its flash got corrupted. I have a dump of a working chip.
          How can I program a specific region of the flash or the whole flash without touching the RAM, option registers, etc.?
          I do not have a J-Link debugger and won't buy one, as I am not rich.
          I have flashed a Nucleo board with an ST-Link to a J-Link just to find out that the ST-J-Link only supports ST chips.
          What would be the cheapest and easiest option to program the Nations chip's flash without touching registers etc.?...
          05-23-2024, 11:51 PM
        • ekozeko333
          [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
          by ekozeko333
          I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
          🔥 The Problem Started After Suspected ESD/PD Fault
          I experienced a power issue or ESD event through a USB-C charger
          After that, the NX20P5090 power switch was visibly burned and was replaced
          Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
          🧠 What I’ve Done So Far
          Flashed...
          06-21-2025, 02:48 AM
        • corrize
          Nikon D800 camera - flash don’t work and capacitor don’t charge
          by corrize
          Hello, I'm stuck in troubleshooting…
          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
          10-01-2022, 10:02 AM
        • shakib200
          Program NOVOTON NPCE388NA1DX I/O with rt809f ?
          by shakib200
          Is it possible to program npce388na1dx io chip by rt809f programmer ? Is there any way ?
          08-21-2024, 01:41 AM
        • abajor
          Canon VIXIA HF S10 A read data from inernal flash memory.
          by abajor
          Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
          Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
          The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
          I think my best shot is to figure out a way to read the internal flash memory outside...
          07-20-2024, 12:04 AM
