How flash atmega238 on rt809f
  • mo000
    • Nov 2017
    • 283
    • algeria
    hi
    plz someone tell me how to PROGRAM ATMEGA238 on RT809F programmer .
    • 31131
    Re: How flash atmega238 on rt809f
    you mean just the chip?
    or the chip on a board?
    • mo000
      • Nov 2017
      • 283
      • algeria
      just the chip
      i bought usbasp to program the atmega an i connect the wires gnd vcc miso ... from uabasp to the atmega 238 but avrdude can't read the atmega .
        • 31131
        the atmega cant run without a clock, if your using an isp programmer like an asp you also need an 8-16Mhz crystal and a couple of 10-22pf ceramic caps
        • Nikan.e
          How to program a specific flash region of a Nations N32G455RE MCU?
          by Nikan.e
          Greetings and salutations!
          I have a device that uses an N32G455RE. Unfortunately, its flash got corrupted. I have a dump of a working chip.
          How can I program a specific region of the flash or the whole flash without touching the RAM, option registers, etc.?
          I do not have a J-Link debugger and won't buy one, as I am not rich.
          I have flashed a Nucleo board with an ST-Link to a J-Link just to find out that the ST-J-Link only supports ST chips.
          What would be the cheapest and easiest option to program the Nations chip's flash without touching registers etc.?...
          05-23-2024, 11:51 PM
        • ekozeko333
          by ekozeko333
          🧠 What I’ve Done So Far
          Flashed...
          06-21-2025, 02:48 AM
        • corrize
          Nikon D800 camera - flash don’t work and capacitor don’t charge
          by corrize
          Hello, I'm stuck in troubleshooting…
          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
          10-01-2022, 10:02 AM
        • shakib200
          Program NOVOTON NPCE388NA1DX I/O with rt809f ?
          by shakib200
          Is it possible to program npce388na1dx io chip by rt809f programmer ? Is there any way ?
          08-21-2024, 01:41 AM
        • spmetroil
          Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
          by spmetroil
          I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
          The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
          I have a CH341A programmer and I already attempted the following steps:
          1. Identified the correct chip (W25Q128, 3.3V SPI flash).
          2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
          3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
          08-19-2025, 09:23 AM
