Wht is this part about?
  • berniedd
    • Mar 2007
    • 119
    Guys, this part is in the switching power supply section of a Sony thermal printer, in series between the line capacitors and the chopper transformer. As you can see, it looks like a power resistor in a ceramic housing. It is a siamesed twin made of a 12 ohm resistor and something else in series with it in the other half inside the common housing. This other something else is open-circuited, and I have no idea if it is also resistor or a choke. Any ideas?
  • berniedd
    • Mar 2007
    • 119
    Re: Wht is this part about?
    Sorry about the huge picture. This is my first time to post an image, and I thought it would come out only a small one. Imagine my surprise when it turned out this size.
    • Wizard
      • Mar 2008
      • 2296
      The pre-T220 transistor package have not made since 1985 (the thin tab) means you have a vintage electronic gear. What is it?
      The resistor is just that, a 12 ohm with temp rating and max current load.
      Cheers, Wizard
      • i4004
        • Oct 2006
        • 2029
        >What is it?
        elephant!
        he said what it is:
        "switching power supply section of a Sony thermal printer".
        bernie, could you post pic of whole primary(or secondary what ever you're aiming at, but 400v cap should suggest it's primary) side of that smps?
        i see it's in line with other coils, probably just another coil...
        • berniedd
          • Mar 2007
          • 119
          Yes, it's in the primary side. I was just wondering about the design. I've measured 12 ohms between one lead at the bottom of the resistor to the top lead. This top lead is soldered to the other top lead, which goes through the other half of the resistor, before exiting at the bottom. It is this half of the resistor that's open. If it's merely a wire that's in there, why would it open circuit? I thought, maybe there's a choke in there too?
          • i4004
            • Oct 2006
            • 2029
            i thought you were asking about the black thing, but it seems you're talking about white thing, which indeed is power resistor.
            and a blown one, according to what you just said.
            you should have 12ohm between two contacts of the resistor that connect to pcb.
            • Toasty
              • Jul 2007
              • 4171
              Autopsy the bad side.
              Does the board have a part number marking? R1, FR1, etc.
              Could be a fuse.
              Can you determine if its on the Mains side or output side?
              veritas odium parit
              • berniedd
                • Mar 2007
                • 119
                It's designated as a resistor, and I think the other half of the thing is a fusible link. This is the first time I've seen a resistor with a current rating (2 A) and a voltage rating (250V). What initially put me off was the label L52D, I thought it might be an inductance rating.
                The resistor is on the primary side. I'm still looking for other defective parts down the line. I know there's another failed part because one of the line fuses was burned out as well.
                • Toasty
                  • Jul 2007
                  • 4171
                  Check the transistor/FET next to it.
                  veritas odium parit
                  • hardwareguy
                    • Jun 2006
                    • 405
                    Its an early fusible resistor. Follow Toasty's advise, check the transistor hooked up to it.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4950
                      • New Zealand
                      Is it a fuse and a resistor in the same package or something?
                      -David VanHorn
                      • hardwareguy
                        • Jun 2006
                        • 405
                        Yes, the part contains a resistor and a fuse wired in series.
                        The resistor limits the available fault current that flows in the milliseconds before the fuse link melts.
                        In theory this helps protect expensive parts like high speed switching FETs. In practice; all it does is prevent said expensive parts from catching fire or exploding when they fail short circuited so you can still read the part numbers to order replacements.
                          • 30985
                          it's a combined fuseable resistor & themal-fuse.
                          if you trash it then you could use seperate parts to replace it.
                          • edugimeno
                            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                            by edugimeno
                            Hi There!
                            I'm trying to help my friend who owns a restaurant be just bought.
                            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                            It's stuck using, I guess, the 2 sided tape that comes with the strip
                            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                            09-05-2024, 09:34 AM
                          • G-Sting
                            iPad Pro A1876 SHORT Part Identify Help Needed
                            by G-Sting
                            So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                            So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                            i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                            SO My main concern is what part should i order what should i search the name for ?
                            on Ipad...
                            05-15-2025, 09:30 AM
                          • jinu_j
                            by jinu_j
                            Hi
                            05-03-2025, 10:51 PM
                          • MidnightRoller
                            Can a resistor lose resistance after hot air?
                            by MidnightRoller
                            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                            02-02-2022, 11:46 PM
                          • artvandalai
                            What resistor ohm will work better to repair this waterpik?
                            by artvandalai
                            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                            01-05-2025, 04:10 PM
