Wht is this part about?
+ More Options
Posts
  • berniedd
    • Mar 2007
    • 119
    Guys, this part is in the switching power supply section of a Sony thermal printer, in series between the line capacitors and the chopper transformer. As you can see, it looks like a power resistor in a ceramic housing. It is a siamesed twin made of a 12 ohm resistor and something else in series with it in the other half inside the common housing. This other something else is open-circuited, and I have no idea if it is also resistor or a choke. Any ideas?
    [/IMG]
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Wht is this part about?
    Originally posted by berniedd
    [/IMG]
    fail
    • i4004
      • Oct 2006
      • 2029
      uh, that's pic on your pc, it's still not on the web....
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Originally posted by willawake
        fail
        sigpic
        (Insert witty quote here)
        • edugimeno
          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
          by edugimeno
          Hi There!
          I'm trying to help my friend who owns a restaurant be just bought.
          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
          It's stuck using, I guess, the 2 sided tape that comes with the strip
          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
          09-05-2024, 09:34 AM
        • G-Sting
          iPad Pro A1876 SHORT Part Identify Help Needed
          by G-Sting
          So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
          So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
          i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
          SO My main concern is what part should i order what should i search the name for ?
          on Ipad...
          05-15-2025, 09:30 AM
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • MidnightRoller
          Can a resistor lose resistance after hot air?
          by MidnightRoller
          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
          02-02-2022, 11:46 PM
        • artvandalai
          What resistor ohm will work better to repair this waterpik?
          by artvandalai
          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
          01-05-2025, 04:10 PM
