Voltage of stored capacitors
  • yyonline
    • Jul 2009
    • 692
    So I was bored today and was messing around with a new multimeter. I tested some of the caps I had in storage as I was curious how long some of the larger ones from power supplies and the like held a charge.
    Then, just out of boredom I started testing some of the smaller caps I have in my spare parts pile. Well, much to my surprise, I have a bunch of 6.3V 1000uF Rubycon that all measured about 0.25 V. I shorted the leads on a few of them, measured again, and the voltage dropped to 0 as expected. I come back a few hours later and they're 0.25 V again. These are about 3 years old, but unused still on the tape and reel.
    A few questions from the electronics ignorant me...
    Where is it picking up this voltage from? And does it mean anything? None of the other capacitors I have seem to do this, so I was just wondering if it could mean something is wrong with them.
    • 31277
    Re: Voltage of stored capacitors
    nothing wrong with them,
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      They are fine.
      The construction and chemistry is loosely similar to a battery and all that's going on is some charged particles are moving around between the electrolyte and plates.
      Mann-Made Global Warming.
      - Dr Seuss
      • Loretto
        Samsung SMPS BN44-00339A
        by Loretto
        this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
        I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
        I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
        I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
        03-29-2025, 08:30 AM
      • Loretto
        by Loretto
        03-28-2025, 10:28 AM
      • Simplebeans
        Macbook Pro A1989 820-00850-a not powering on
        by Simplebeans
        Hey guys i just got myself a Macbook Pro A1989 820-00850-a 2018, the seller said they had spilt liquid over it and since then it has never turned on.
        I am using a Apple 61W USB-C Power Adapter and USB-C Charge Cable and on my USB tester i can see when i plug into the power i get around 5.21V and stays at 0.24amps. I am currently testing disconnected from the battery and only plugged into the USB-C Charge Cable.
        When opening the machine I was greeted with corrosion on, in and around, in particular the U3100 (USB-C PORT CONTROLLER XA) and U3200 (USB-C PORT CONTROLLER XB)...
        03-26-2022, 01:56 PM
      • hikomalek
        SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
        by hikomalek
        Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
        When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
        Transformer:
        |Info| Primary | Aux | AB | CD|
        |Ratio|1|25|40|12|
        |Voltage AC|230V|9.2V|5.8V|19V|
        |Voltage DC (*1.41)|230V|13V|8.1V|27V|
        I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
        09-19-2025, 03:30 AM
      • Fernon@Repair
        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
        by Fernon@Repair
        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
        VCCIO voltage ok
        VCCSA Voltage OK
        VCCPLL Voltage OK
        Ram Voltage ok
        RamVTT OK
        VPP 2.5 OK
        But No Core Voltage
        and i want to this vrm ic datasheet or pinout (ISL69269)
        anyone have this ic pinout voltages?...
        06-25-2025, 07:19 AM
