What solder thickness/flux type do you prefer?
  • jayjr1105
    • 281
    I read article after article in bed last night and It's still confusing on what's good, what's bad, what definitely needs cleaning afterwards, etc.
    I have a spool of MG Chem 63/37 RA 2.2% and that's pretty much my go to for anything I care about. I have some cheap chinese 63/37 as well that I use when priming a joint for suction/removal or stuff I care less about.
    I like .8 and .6mm thickness. Anything thinner and I feel like I'd have to feed a ton more in.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: What solder thickness/flux type do you prefer?
    Dammit, have to feed in several feet of 0.6mm to solder my water pipes!
    But really it depends on what what you're soldering. I'd like to get some 0.6mm to work on really small stuff but can't use that stuff on large solder lugs.
    But for pcb work 0.8mm works good. 0.6mm for some SMT. 1.6mm for large solder lugs.
    2.4mm zinc chloride "acid flux" for pipes...
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • chth96
      Is it good to use chemistronic flux off es835b for flux remover?
      by chth96
      I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
      Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
      11-17-2023, 07:25 AM
      Multifix 425-01 and 450-01 Rework Flux Datasheet
      REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
      - No Clean Formulations
      - Low residue
      - Range of activity to deal with different component solderability
      - Halide free
      - Suitable for dispensing
      - Compatible with solder coatings and/or No Clean flux cored solder wire product range
      Both products are supplied in syringes or cartridges for application by dispensing....
      10-07-2024, 06:02 AM
    • petemanuk
      BGA solder balls not connecting - help pls
      by petemanuk
      So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
      I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
      I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
      11-16-2022, 05:21 AM
    • myth77
      UV solder mask - high temp resistent, recomendation?
      by myth77
      Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
      Is there any solder mask...
      03-28-2022, 04:04 AM
