Spectra S1+ Breast pump - No suction
  • caphair
    • Nov 2011
    • 1249
    Re: Spectra S1+ Breast pump - No suction
    Top of Q9 does not connect to Q7 or any other leads.
    Top of R21 connects to the Source pins of Q7
    R21 and R30 are in series and bottom of R30 is connected to the Gate of Q7
    I’ve attached pics to show the operations of Q9-12 when powered on and off.
    Seems like Q9 possibly cycling whatever’s plugged into connector SOL? Looks like maybe an actuator. But that’s the clicking I hear when powered on without suction pump.
      master hoarder
      • May 2008
      • 12170
      • Bulgaria
      Do any of the resistor leads of R21 or R30 connect to top pin of Q9? If not, what about Q11? I'm curious what drives Q7.
      I've attached pics to show the operations of Q9-12 when powered on and off.
      Seems like Q9 possibly cycling whatever's plugged into connector SOL? Looks like maybe an actuator. But that's the clicking I hear when powered on without suction pump.
      Hmm. So the 0-4V fluctuation is consistent with the clicking?
      Can you trace where the Emitter/Source pin of Q11 goes to? (Should be pin 3, the one on the right when the SOT-23 device is viewed with the single pin at the top, and two at the bottom.)
      • caphair
        • Nov 2011
        • 1249
        R21 and R30 do not connect to the top pins of Q9 or Q11.
        The 0-4v fluctuation is consistent with the clicking, as well as small fluctuations with the main power ~11-8-11.5v
        Pin 3 of Q11 goes up to the drain pins of Q2 (top right of the board) which happens to be the same ic as Q7.
        • redwire
          • 3907
          These parts would have resistors inside:
          Q9, Q12 SOT-23 marking NF, NPN digital transistor KRC106S or DRC2124X
          Q11 SOT-23 marking PF, PNP digital transistor KRA106S
          Q8 SOT-23 marking AO7? likely N-ch mosfet driving the solenoid.
          My take on the pcb board:
          Q9 drives Q7 for the motor.
          Q12 drives Q11 for... braking?
          Q10 drives Q8 for the solenoid.
          It seems to have motor current-sense R32/R45 back to the MCU.
          • caphair
            • Nov 2011
            • 1249
            So would Q9 be the suspect for the motor not turning on?
            • caphair
              • Nov 2011
              • 1249
              #26
              I’m now wondering if Q9 does drive Q7 if there’s maybe a break to Q9 to Q7 gate within the PCB. I measure 57Mohm from those two points.
              Also my meter has a duty cycle option that I probed the bottom left pin of Q9 (base?) and can see duty percentage change as I change the speed of the vacuum motor through the up/down controls
              Bottom right pin of Q9 connects to ground so maybe it’s supposed to be grounding the voltage of Q7 gate to turn the motor on?
              • redwire
                • 3907
                This is how the circuit looks to me. To turn on the pump motor, Q9-C should go to ground. You could try tap a 1k resistor to GND and see if the mosfet Q7 turns on.
                • caphair
                  • Nov 2011
                  • 1249
                  #28
                  Tap it to G of Q7?
                  What's the role of R30? Isn't it a 200 ohm? Labeled “201”
                  • redwire
                    • 3907
                    I would tap a 1k resistor between GND and Q9-C which should drop Q7 gate voltage so it turns on.
                    R30 is to slow down the mosfet switching a little bit. It could be 200R.
                    • caphair
                      • Nov 2011
                      • 1249
                      #30
                      Pump did not turn on but I suspect that's because there's no voltage on Q9-C which is why I was suspecting a break within the Pcb possibly.
                      I tried jumping Q9-C to R30 and heard a whining noise measuring voltage at pump connector saw oscillating 0-2v. Possibly because 1k was too high dropping the voltage?
                      Didn't want to just try jumping from Q9-C directly to R30 without first reporting back and seeing if that would be a good idea or if I could damage something
                      • caphair
                        • Nov 2011
                        • 1249
                        #31
                        So out of curiousity I wondered if the trace from Q9-C to R30 was on the backside of the board. I had to remove one of the push buttons and there it was, corroded.
                        Cleaned it up but the trace going to R30 was too far gone. Ended up soldering a jumper wire and it's back to life!
                        Thanks everyone for your help on this one. Wouldn't have thought to look there without going through how it's configured.
                        • redwire
                          • 3907
                          so that's where the water went! Glad it's fixed, we don't want any starving babies
                            master hoarder
                            • May 2008
                            • 12170
                            • Bulgaria
                            #33
                            Nice job finding the fault fellas! Glad to see another repair success story.
                              • Jul 2011
                              • 6039
                              One more repair that took some doing
                              • caphair
                                • Nov 2011
                                • 1249
                                #35
                                Question about the jumper wire I used, it had a clear tube inside the insulation that the copper wire wraps around. Not sure what it came from, but curious what application something like this would be used for?
                                  master hoarder
                                  • May 2008
                                  • 12170
                                  • Bulgaria
                                  #36
                                  Was there a thin wire inside the thin clear tube as well? If so, this might be some kind of shielded wire. Or it could also be that the clear tube inside was for reinforcement... though I'm leaning more towards shielded wire.
                                  • caphair
                                    • Nov 2011
                                    • 1249
                                    #37
                                    Actually don’t think there was a thin wire inside the tubing. Just a flat looking copper wire that wrapped around it. The copper looked wider than normal strand
                                      • 31014
                                      extra flexible wire - used in places where it will bend - like in robots.
                                      i used to have similar but older wire where the copper was wrapped around a thick cotton cord.
                                      btw, i still think it's a huge waste of technology just to replace a hand!
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        #39
                                        😂😂 agreed. Saw that these go for around $200. Pretty crazy to me
                                          master hoarder
                                          • May 2008
                                          • 12170
                                          • Bulgaria
                                          #40
                                          What isn't today? They are putting "smart" MCUs in everything.
                                          Also, haven't you seen Demolition Man, the movie? With the way things are headed with VR and smart technology... and now with covid-19 measures restricting/limiting how people meet and interact, I suspect it won't be long before we'll be using the three shells instead of toilet paper (remember the TP shortage?) and have sex through VR only. LOL!
                                          • Dannyx
                                            Remote pump control ideas.
                                            by Dannyx
                                            Good day folks. A task was given to me to redesign the control system for a pump system in a remote location. The idea is that there's a tank which has a float or some sort of switch/sensor to detect when it's full/empty and this runs some pumps accordingly. The trouble is the pump and the tank are like 4km apart, from what the chap who inspected them on our behalf told me, so the way this currently works is by using some unknown boards based on SIM cards (see the pictures). From what I can assume, when a contact closes at the "client side" (the tank), it calls up the "server side"...
                                            09-11-2020, 04:10 AM
                                            ZD-915 vacuum pump motor mount service alert
                                            by sam_sam_sam
                                            If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                                            One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                                            Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                                            The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                                            09-19-2021, 02:15 AM
                                          • Dannyx
                                            Another water pump automation project (suggestions ?)
                                            by Dannyx
                                            Good day folks. Some of you may recall that a while ago I was struggling to put together what I considered to be a very basic automation for a water supply system. It didn't work out the way I intended and I learned my lesson to do it properly from the start, rather than try to reinvent the wheel and patch something together myself from scratch, so I'll stick to commercial alternatives for future projects and such a project just came in today !
                                            This one is easier simply because this time the pump and level sensors are in the same place, so they don't require a remote connection....
                                            07-26-2022, 11:39 AM
                                          • betmen
                                            water pump Scala2 - electrical diagram
                                            by betmen
                                            Does anyone have a wiring diagram for the pump mentioned?
                                            The markings on the board are 98800964 r07, two or three capacitors are burnt.
                                            I don't have the board with me yet, but I don't know if the printed lines on the board are visible due to the short circuit that occurred and how the capacitors were connected.​
                                            05-22-2025, 02:56 AM
                                            ZD desoldering station pump rebuild
                                            by stj
                                            just did one.
                                            works great.
                                            so here's the discoveries.
                                            the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
                                            the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
                                            so you need to clean everything to get rid of all the tacky black stuff.
                                            then reassemble it.
                                            *BUT*
                                            you must put the 2 screws into the assembly only finger-tight.
                                            if you tighten it properly the valves dont work....
                                            08-21-2024, 05:59 PM
