Replacing tantulum capacitors with electrolitic caps?
  • sigmeyer
    • Feb 2020
    • 158
    • Serbia
    Just like the title says can i do it? Im replacing tantulums on ps3 consoles, and im all out of them , but i do have lots of electrolitic ones... Its the supply rail of CPU and RSX video chip , some people say they create alot of noise and maybe they could be used in combination with tantulums and it should work fine? Any thoughts?
    • 31283
    Re: Replacing tantulum capacitors with electrolitic caps?
    tantalums or surface-mount polymers only.
    what are you actually replacing?
    the only things that need replacing in ps3's are the tokin caps - those are ceramic, not tantalum.
    • sigmeyer
      • Feb 2020
      • 158
      • Serbia
      Ye those tokin caps... I have run a wire outside the metal shield and connected up some electrolitics . and it works fine. Im not sure how long these would last... but eh
      Hmm i always thought they were tantulums... interesting...
        • 31283
        those wires will have a high inductance
          What is printed on the body of the cap?
          And yes, a piece of wire is seen as inductor in high frequency circuit.
          • PeteS in CA
            • Aug 2005
            • 3583
            • USA, Unsure of Planet
            And if the Tokin ceramic caps are surface mount MLCCs their ESL is very low.
            PeteS in CA
            • competition
              Replacing capacitors in Evga PSU
              by competition
              I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
              Yesterday, 11:12 AM
            • kotel studios
              TAGAN TG380-U01 PSU - 5v shorted after replacing caps
              by kotel studios
              Hi
              Recently I got this tagan tg380-u01 PSU with bad caps on 3.3v rail (the line was 2.5v no load!). Replaced them but no go, so I've replaced all of them, apart from some smaller ones and one under the secondary heatsink. Even that didn't help so I've replaced the others. All caps are known good ones.
              Powered it on and heard the breaker pop. Opened it up and saw some smaller caps shorted together. Fixed that up but still it trips breakers. Now I get 0ohms from 5v to GND. Secondary heatsink removed and still a short, even with the PWM IC board removed. All diodes on that...
              02-14-2025, 10:10 AM
            • SwedishDiesel
              Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
              by SwedishDiesel
              Howdy folks,
              I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
              10-30-2021, 12:47 AM
            • Delicieuxz
              Replacing caps in an old speaker system. Should I use a higher value here?
              by Delicieuxz
              I'm recapping an old Creative Labs / Cambridge speaker system / subwoofer. At 4:33 in this video, the person looking at what he says are the speaker caps in the system says they are 470 uF, and that he'd use much larger caps if he was building it.
              https://youtu.be/1LRIzePlma0?t=273
              I'm wondering if I should use something larger for the recap job, and what using larger caps will do for it.
              Would 680uF be good value to try in place of the 470uF originals?
              06-25-2023, 08:27 PM
            • yuzupatogik
              Help with replacing Capacitors on Altec Lansing ATP 3
              by yuzupatogik
              I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
              I can't find datasheets for the Samxon in any of the following variants:
              10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
              02-14-2025, 04:11 PM
